Hi all
I am using Pegasus for Windows v. 4.7 and Windows 8.
When I use a standard Ctrl-C and Ctrl-V with a normal message, it does not work at all. I can not paste the text in another new mail or even any other windows application (Word, etc). I have to change to RAW view in the message and then copy/paste. It works, then; however, it is useless as it incorporates several symbols.
This Ctr-C/Ctr-V used to work allways in Pegasus (I have used this mail program for several years), of course, but I do not know which is the problem that is really fastidius.
Anyone has had similar problems, or it comes from my own PC.
Thanks to anyone that can help me
Jesus
<p>Hi all</p><p>I am using Pegasus for Windows &nbsp;v. 4.7 and Windows 8.&nbsp;</p><p>When I use a standard Ctrl-C and Ctrl-V &nbsp;with a normal message, it does not work at all. I can not paste the text in another new mail or even any other windows application (Word, etc). I have to change to RAW view in the message and then copy/paste. It works, then; however, it is useless as it incorporates several symbols.</p><p>This Ctr-C/Ctr-V used to work allways in Pegasus (I have used this mail program for several years), of course, but I do not know which is the problem that is really fastidius.</p><p><span style="font-size: 10pt;">Anyone has had similar problems, or it comes from my own PC.</span></p><p><span style="font-size: 10pt;">Thanks to anyone that can help me&nbsp;</span></p><p><span style="font-size: 10pt;">Jesus</span></p><p>&nbsp;</p><p>&nbsp;</p>
