Problems Using Pegasus Mail with Gmail - IMAP.
The only additional suggestion I have is to play around with deletion settings in your Gmail profile in Pmail, i.e. delete immediately etc, to see if that solves the problem.
Dear Friends,
While using Pegasus
Mail with the IMAP protocol of Gmail, I have a problem moving or
deleting messages. When I try and delete a message or move a message
from the Inbox to the Bin of Gmail, I get the following error message
from Pegasus Mail.
Error reported by IMAP
Server
Profile Gmail
The IMAP server that
manages this mailbox or folder has reported an error during the
operation you have attempted to perform.
The operation cannot be
completed.
The window with this
error message has a large red cross mark with the tool-tip “Pegasus
Mail Preferences Package”.
The message which is to
be moved or deleted sometimes remains in the Gmail Inbox.
Can anyone help solve
this problem?
Ravi.
<p class="western" style="margin-bottom: 0cm">Dear Friends,</p> <p class="western" style="margin-bottom: 0cm">While using Pegasus Mail with the IMAP protocol of Gmail, I have a problem moving or deleting messages. When I try and delete a message or move a message from the Inbox to the Bin of Gmail, I get the following error message from Pegasus Mail. </p> <p class="western" style="margin-bottom: 0cm">----------------------------------------------------</p> <p class="western" style="margin-bottom: 0cm">Error reported by IMAP Server</p> <p class="western" style="margin-bottom: 0cm">Profile Gmail</p> <p class="western" style="margin-bottom: 0cm">The IMAP server that manages this mailbox or folder has reported an error during the operation you have attempted to perform.</p> <p class="western" style="margin-bottom: 0cm">The operation cannot be completed.</p> <p class="western" style="margin-bottom: 0cm">----------------------------------------------------</p> <p class="western" style="margin-bottom: 0cm">The window with this error message has a large red cross mark with the tool-tip “Pegasus Mail Preferences Package”.</p> <p class="western" style="margin-bottom: 0cm">The message which is to be moved or deleted sometimes remains in the Gmail Inbox.</p> <p class="western" style="margin-bottom: 0cm">Can anyone help solve this problem?</p> <p class="western" style="margin-bottom: 0cm">Ravi.</p> <p class="western" style="margin-bottom: 0cm"> </p>
A previous suggestion was to turn off "auto expunge" under IMAP in the Gmail settings web interface.
Might be worth a shot.
<p>A previous suggestion was to turn off "auto expunge" under IMAP in the Gmail settings web interface.</p><p>Might be worth a shot. </p>
[quote user="caisson"]
I tried this, as well as increasing the time-out to 300 seconds. Neither worked.
I don't mind the error message as long as the message(s) get deleted or moved to the Bin folder. I would particularly like to be able to delete or move multiple messages at one time.
Ravi.
[quote user="caisson"]<p>A previous suggestion was to turn off "auto expunge" under IMAP in the Gmail settings web interface.</p><p>Might be worth a shot. </p><p>[/quote]</p><p>I tried this, as well as increasing the time-out to 300 seconds. Neither worked.</p><p>I don't mind the error message as long as the message(s) get deleted or moved to the Bin folder. I would particularly like to be able to delete or move multiple messages at one time. </p><p>Ravi.   </p>
