Problem with two monitors
Just to say that I have precisely the same setup, and the same minor annoyance applies here too.
David
<p>Just to say that I have precisely the same setup, and the same minor annoyance applies here too.</p><p>David </p>
I am using two monitors for my desktop in WINDOWS 7 prof. Pegasus Mail is normally open on the left side second monitor which is not the main screen. Some dialog windows pop up on the wrong monitor, namely on the right one which is the main monitor. What I found out is that all child windows which size can be changed are opening correctly on top of the Pegasus Mail main window. All other child windows with fixed size are opening on the wrong monitor which is really a pain. It should be possible to fix this problem in the code.
