print driver host for 32bit application has stopped working
Problem solved after update to printer driver and 250 updates to windows.
Using Pegasus ver 4.70 build 546 and I get this error message intermitantly. Any thoughts? This is a reinstall after having to reformat my hard drive.
Its a printer driver problem. Try uninstalling and reinstalling the printer.
Uninstalling and reinstalling printer was the reason I had to reformat my hard drive. will think on it.
What is your os.
I notice that there are articles on the web dealing with 32 bit drivers on a 64 bit system and the associated problems.
<p>What is your os.</p><p>I notice that there are articles on the web dealing with 32 bit drivers on a 64 bit system and the associated problems. </p>
