Possible to save open folder positions when using IMAP?
Hmm ... you should ask David :-)
I asume that Pegasus on close first closes  the connection to your IMAP-Account and in consequence has to close the IMAP-box (in "modern" view) or all folderwindows (in "classic" view) depending on that connection. So the windowstate saved on close is only windows of local folders open. I never tried that as I swapped to "modern" view as soon as Pegasus had it available.
It seems it works as designed ...
bye   Olaf
<p>Hmm ... you should ask David :-)</p><p>I asume that Pegasus on close first closes  the connection to your IMAP-Account and in consequence has to close the IMAP-box (in "modern" view) or all folderwindows (in "classic" view) depending on that connection. So the windowstate saved on close is only windows of local folders open. I never tried that as I swapped to "modern" view as soon as Pegasus had it available. </p><p>It seems it works as designed ... </p><p>bye   Olaf</p><p> </p>
We use Pegasus Mail as a POP3 client with the classical folder manager view (version 4.70 under Windows 7 64bit). Several folders are always open as separate windows inside the Pegasus Mail program window. The desktop state is saved, hence all folder windows are re-opened automatically at their former positions when starting Pegasus. Now we are trying to switch to a local IMAP server. Everything is working, except when starting Pegasus, only the windows for local folders are opened, but not the ones for IMAP folders located on the server. The IMAP mailbox is connected automatically and the folder list is displayed, but the folders are not opened as windows automatically. Hence we would have to doubleclick each folder manually every time Pegasus is launched. Is this behaviour a limitation of the IMAP mode or are we missing something?
