I have been using the same ISP for years and have my smtp configured as they have specified. But suddenly as of late last night, outgoing mail isn't going. I get the smtp error as below. All the security settings are as they were - nothing changed on my end. My ISP, Frontier, claims that Pegasus isn't supported, yet it is just a POP3 client and I can't see how the problem can be from the client when nothing changed from when email was sending (I am still receiving email). I rebooted and there is no change. I am including my Pegasus Mail 4.70 for Windows information below. Help! Thanks.
Dilip
13:01:56.719: --- 16 Mar 2015, 13:01:56.719 ---
13:01:56.719: Connect to 'smtp.frontier.com', timeout 3000 seconds.
13:02:17.810: 15: Peer connect failure
Pegasus Mail Info screen:
Copyright (C) 1992-2014, David Harris, all rights reserved
WinPMail version: Version 4.70 (Win32), Feb 27 2014, build ID 546
Windows version: 6.1
Home mailbox location: D:\MAIL
New mailbox location: D:\MAIL
TMP environment variable: C:\Users\Dilip\AppData\Local\Temp
TEMP environment variable: C:\Users\Dilip\AppData\Local\Temp
- WINSOCK path: WSOCK32.DLL
Commandline: -A
Active -Z options: 32768
PMR variable: (None)
PML variable: (None)
MAI variable: (None)
NB variable: (None)
Last new mail count: 4263
<p>I have been&nbsp;using the same ISP for years and have my smtp configured as they have specified. But suddenly as of late&nbsp;last night, outgoing mail isn't going. I get the smtp error&nbsp;as below. All the security settings are as they were - nothing changed on my end. My ISP, Frontier, claims that Pegasus isn't supported, yet it is just a POP3 client and I can't see how the problem can be from the client when nothing changed from when email was sending (I am still receiving email). I rebooted and there is no change.&nbsp;I am including my Pegasus Mail 4.70 for Windows information below. Help! Thanks.</p><p>&nbsp;</p><p>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Dilip</p><p>&nbsp;</p><p>13:01:56.719: --- 16 Mar 2015, 13:01:56.719 ---
13:02:17.810: 15: Peer connect failure</p><p>&nbsp;</p><p>Pegasus Mail Info screen:</p><p>&nbsp;</p><p>Pegasus Mail for Microsoft Windows
Electronic mail to <a href="mailto:support@pmail.gen.nz">support@pmail.gen.nz</a>.</p><p>WinPMail version: Version 4.70 (Win32), Feb 27 2014, build ID 546
&nbsp; - WINSOCK version: WinSock 2.0
&nbsp; - WINSOCK path: WSOCK32.DLL
Commandline: -A
NB variable: (None)
&nbsp;</p>
