Two copies of Pegasus on the same machine
See my post about using Pegasus on a NAS Server:
http://community.pmail.com/forums/post/42237.aspx
This should be no different if all the Pegasus files are on your local machine.
You need to have a multi user installation, then set up your users and their associated identities.
Users are administered via " Addresses" menu, choose "User management".
 Note this shows the location of the main mailbox directory, which in our case is a mapped drive (S:) on our NAS Server.
You create "identities" under "Tools" "Identities".
You then add these identities to your User ID, and in that way you can manage multiple email incarnations with ease, even having different colours and fonts for each screen layout.
Hope this helps
<p>See my post about using Pegasus on a NAS Server:</p><p>http://community.pmail.com/forums/post/42237.aspx</p><p>This should be no different if all the Pegasus files are on your local machine. </p><p>You need to have a multi user installation, then set up your users and their associated identities.</p><p>Users are administered via " Addresses" menu, choose "User management". </p><p><img src="http://community.pmail.com/forums/data:image/jpeg;base64,/9j/4AAQSkZJRgABAQEAYABgAAD/4RDmRXhpZgAATU0AKgAAAAgABQESAAMAAAABAAEAAAE7AAIAAAAFAAAIVodpAAQAAAABAAAIXJydAAEAAAAKAAAQ1OocAAcAAAgMAAAASgAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEFuZHkAAAAFkAMAAgAAABQAABCqkAQAAgAAABQAABC+kpEAAgAAAAMxMQAAkpIAAgAAAAMxMQAA6hwABwAACAwAAAieAAAAABzqAAAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMjAxNTowNTowNiAxMTo1NDoxMQAyMDE1OjA1OjA2IDExOjU0OjExAAAAQQBuAGQAeQAAAP/hCxdodHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvADw/eHBhY2tldCBiZWdpbj0n77u/JyBpZD0nVzVNME1wQ2VoaUh6cmVTek5UY3prYzlkJz8+DQo8eDp4bXBtZXRhIHhtbG5zOng9ImFkb2JlOm5zOm1ldGEvIj48cmRmOlJERiB4bWxuczpyZGY9Imh0dHA6Ly93d3cudzMub3JnLzE5OTkvMDIvMjItcmRmLXN5bnRheC1ucyMiPjxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0PSJ1dWlkOmZhZjViZGQ1LWJhM2QtMTFkYS1hZDMxLWQzM2Q3NTE4MmYxYiIgeG1sbnM6ZGM9Imh0dHA6Ly9wdXJsLm9yZy9kYy9lbGVtZW50cy8xLjEvIi8+PHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9InV1aWQ6ZmFmNWJkZDUtYmEzZC0xMWRhLWFkMzEtZDMzZDc1MTgyZjFiIiB4bWxuczp4bXA9Imh0dHA6Ly9ucy5hZG9iZS5jb20veGFwLzEuMC8iPjx4bXA6Q3JlYXRlRGF0ZT4yMDE1LTA1LTA2VDExOjU0OjExLjExNDwveG1wOkNyZWF0ZURhdGU+PC9yZGY6RGVzY3JpcHRpb24+PHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9InV1aWQ6ZmFmNWJkZDUtYmEzZC0xMWRhLWFkMzEtZDMzZDc1MTgyZjFiIiB4bWxuczpkYz0iaHR0cDovL3B1cmwub3JnL2RjL2VsZW1lbnRzLzEuMS8iPjxkYzpjcmVhdG9yPjxyZGY6U2VxIHhtbG5zOnJkZj0iaHR0cDovL3d3dy53My5vcmcvMTk5OS8wMi8yMi1yZGYtc3ludGF4LW5zIyI+PHJkZjpsaT5BbmR5PC9yZGY6bGk+PC9yZGY6U2VxPg0KCQkJPC9kYzpjcmVhdG9yPjwvcmRmOkRlc2NyaXB0aW9uPjwvcmRmOlJERj48L3g6eG1wbWV0YT4NCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgPD94cGFja2V0IGVuZD0ndyc/Pv/bAEMAAgEBAgEBAgICAgICAgIDBQMDAwMDBgQEAwUHBgcHBwYHBwgJCwkICAoIBwcKDQoKCwwMDAwHCQ4PDQwOCwwMDP/bAEMBAgICAwMDBgMDBgwIBwgMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDP/AABEIAUMBagMBIgACEQEDEQH/xAAfAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgv/xAC1EAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+fr/xAAfAQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgv/xAC1EQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/APoyiiivsD4cKKKKACiiigAooooAKKKKACiiigAooooAq694jsPCWj3Gpapf2em6bZp5k9zeTpb29v8A77vVHwd8RvD3xG0+S88Oa3o/iC1t32PNpt6l3HG/9zelcj+1zK9r+z34gZYZJ5I/srpCn+sk/wBKj/v1wHxG8R+J/BGqeI/iNb+Fbzw/fapa6X4X06wuZ7W4vLid7ry/tU6Rz+R+78/ZH5k/+/5dY1KnJPkN6eH54H0LRXz9dfEb4i+A/DWsfb4fEEFrqE+l2Gkal4nTSpLizurq68h/k05/LeOON0ePzI0/ef8APStuXxbrfwl+Kmq2GveNrjVfDln4Un117m/06D7RZuk8cbu/2VI98fl/weX/AM9P9ZR9YH9XmezUV89+EviX8Qo/FGsaJZ/8JJqV1qHhSfVtE/4Sq1063kkukeONNiWPl7I5PPT5J40kj8v/AK6Vd8JfFXVotQ8K2C+J/El9fXHitNJ1uz17S7W01DT/APiXTz+R+4gjjePzEjeN49/mf89JKPa9f6+LlF9X6f1/Me71Hf38Ol2c9zcTRwQW6eY8zv5ccaf368P8W/EHxnqtx4uTSbnWJNN0PxWlhdPo9la3Gqafp39nQTv5CTp5byee/wDzzeTy5JNkf+rrstU16HxR+y3qV/a6xJ4ggvPD11ImpPB9nkvP3EnzumyPZJ/seXHUyxH7qUxew9+EDuNG1qz8R6PBf2F5b31jeJ58FzbT+ZHcJ/fR6NB8R2Hi3R4L/S7+z1KxuP8AUXNnOlxbyf7jpXzR8Pr+88G/CeP4UWdz5F94g+wx6C+/95Hp18nmTun/AFw2X3/fuCtH4c6/N4c+Bfgrw3oN/wCLLXVbifVJLWw8PWVjcXlxBBdSRvvnvv3EEce+P/WfvJP3eyqnU5JB9XPoK/8AEdhpeqWNndX9na32qPJHY2006RyXjonmPsT+P93U+l6zZ69p8d5YXNvfWsn3JoX8yOT/AIHXjXwg+MniTxlb/DL+0rjy5NY/tiDVE8iCP7Q9q+xHfZ5kaSfJv/dyeXXTfsn/APJvfh/AHJ/R70e0J9mdp/wlulf8I3/bH9paf/AGPs8/7f9qT7P5f9/f8A6utKvnfzU/4dvzo/7uSPw88Do/8Af3+Xs/7+fJXTaz4817wv8cHh8Qar4g0fR7idI9BtrbTrW40vWE+y+Y8Dz7JJ4LvzN/8ArJII5PLj2eZ+8o+scvxl/V/5D2Kivn34I/Ev4l/Ea88I+JG03xR/Y/iT9/qMNz/Y8ej2drIkkiPa+RP9v8yP5P8AWb/M/efu4/8Almzw54j+IuqfAfw54n/4SLxBqsmuTpPq/wDY+nWMl5pdiiSfPawPB88kkmzzPM8/lpsjo+sC+rn0LRXP/C/X4fFHw70e/tdYk8QW95apImpPB9nkvP9t02R7JP+mflpXQVsYhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXrnwdL/wDCo/Cvzx/8ge0/5af9MUryOvX/AIOeGUn+EXhWT958+j2jfnClc9Xc9fK9pep5BRW58L/Ac3xV+JGh+G7e/j02TWJ3j+0va+f5eyCSf7m+P+5Xun/DuHUP+h4s/wDwRSf/ACVU1MRCHxnFh8HWrQ54HzfRX0h/w7h1D/oeLP8A8EUn/wAlUf8ADuHUP+h4s/8AwRSf/JVT9fomn9mYn+Q+b6K+kP8Ah3DqH/Q8Wf8A4IpP/kqj/h3DqH/Q8Wf/AIIpP/kqj6/RD+zMT/IfN9FfSH/DuHUP+h4s/wDwRSf/ACVR/wAO4dQ/6Hiz/wDBFJ/8lUfX6If2Zif5D5vor6Q/4dw6h/0PFn/4IpP/AJKo/wCHcOof9DxZ/wDgik/+SqPr9EP7MxP8h830V9If8O4dQ/6Hiz/8EUn/AMlUf8O4dQ/6Hiz/APBFJ/8AJVH1+iH9mYn+Q+b6K+kP+HcOof8AQ8Wf/gik/wDkqj/h3DqH/Q8Wf/gik/8Akqj6/RD+zMT/ACHy74t8JWHjfw/PpuqQ/arG42b4d7x+ZsfzP4P9yjxb4S03x54cvtH1ezt9S03UIPIuraZP3ciV9Rf8O4dQ/wCh4s/AARSf/JVH/DuHUP+h4s/BFJ/wDJVT9cwxp/Z+KPjDVPgPo9h4D1zTbPSpPEUmsQpBPbeIdevriO42fcTz5/Pkg8ve7/ALv/AJaVznwv/Zp+y+INc1LxRpunx/2xpf8AYX2D+27rXvtFrv8AMfz7q6SOR/7kaeX5cf8A20r7y/4dw6h/0PFn/wCCKT/5Ko/4dw6h/wBDxZ/+CKT/AOSqn63hufnD6nieTkPjPS/2afB+lyXUy2GoT3V5pz6a95c6vfXF59ld45NnnvPJIn7xP3f7z93/AAVYl/Z48JS+G59Jks9QnjuL1L97mbVLqTUPPT7j/bXfz/Mj+5/rP9X8lfYn/DuHUP8AoeLP/wAEUn/yVR/w7h1D/oeLP/wRSf8AyVR9cwof2fij4zi/Zp8H2GlyWdrZ6ppsdxe/2lPNZ63fWlxJdeRHA7vOk/mSeZGn7z95+8k+d/3ldPa+CNKtfBf/AAj0VnHDo/2X7B9mT93+42eXsr6l/wCHcOof9DxZ/wDgik/+SqP+HcOof9DxZ/8Agik/+SqPrmFD+z8UfKdr8NNBtdc0fUl023+3eH7J9N06Z98klvA/l70/8cSse/8A2ePCt/p2nW32DULWPR/P+yvZ6pdWlxH57+ZOnnwPHI8ckn8En7uvsT/h3DqH/Q8Wf/gik/8Akqj/AIdw6h/0PFn/AOCKT/5Kq/rmGmH9n4mJ8k+F/gt4Y8G22jppelR2Mfh/7V/ZyQu/l2fn/wCv+T/Pl1qeEvCVh4I8PwaVpcP2Wxs/9RDveTy/n8z+OvqL/h3DqH/Q8Wf/AIIpP/kqj/h3DqH/AEPFn/4IpP8A5Ko+vYUz/s/FHxv/AMM5+D5fEn9pf2beeZ9t/tL7H/al1/Z/2r/Wef8AYt/keZ5nz7/L/wBZ8/8ArKvH4N+Hj44/4SFrbUJNS8/7WiTapdSWcc+zy/PS1d/ISTy/4/L8yvrr/h3DqH/Q8Wf/AIIpP/kqj/h3DqH/AEPFn/4IpP8A5KqPrmFNPqGKPj7wv8AvDHg3xBHqWl2eoWskc888FsmqXX9n27v5m90td/kJ99/9XH/y0en3/wADPDd14T0rRFh1Sx03Q/8Ajy+wavdWFxb/APbeB45P/IlfX3/DuHUP+h4s/wDwRSf/ACVR/wAO4dQ/6Hiz/wDBFJ/8lUvrmG+APqGKPmHw54cs/CWh2um6bbR2tjp6eRBCn/LNKvV9If8ADuHUP+h4s/8AwRSf/JVZPjf9gW/8G+C9Y1j/AITKzuv7Lsp7vyf7BePzNkfmbP8Aj6rT6/RM/wCzMT/KeC0V9JXX/BN6/tbiRf8AhPLP92/l/wDIvP8A/JVN/wCHcOof9DxZ/wDgik/+Sqf1+iH9mYn+Q+b6K+kP+HcOof8AQ8Wf/gik/wDkqj/h3DqH/Q8Wf/gik/8Akqj6/RD+zMT/ACHzfRX0h/w7h1D/AKHiz/8ABFJ/8lUf8O4dQ/6Hiz/8EUn/AMlUfX6If2Zif5D5vor6Q/4dw6h/0PFn/wCCKT/5Ko/4dw6h/wBDxZ/+CKT/AOSqPr9EP7MxP8h830V9If8ADuHUP+h4s/8AwRSf/JVH/DuHUP8AoeLP/wAEUn/yVR9foh/ZmJ/kPm+ivpD/AIdw6h/0PFn/AOCKT/5Ko/4dw6h/0PFn/wCCKT/5Ko+v0Q/s3E/yHzfX098BfDHn/AzwXJ/f0Kxb87dK+a9e0Z/C/ijWNKlmjupNH1G6sfORPL+0eRPJHv2f8Ar7G/Zv/wCTd/AX/Yuaf/6TR1tOpsVgZcrkj5x/ZL/5Od8Ff9drr/0hu6+8q+Df2S/+TnfBX/Xa6/8ASG7r7yrx80/jnpZP/BOF/aY/aZ8E/sgfBHW/iN8Rdb/4RzwX4c8gahqX2Ke7+z+fPHAnyQo7v+8nRP3cf/LSj4gftM+Cfhh8bvh78ONe1r7D40+KX9o/8Ixpv2KeT+1P7Og8+6+dE8tPLjff+8kTzP4PMr5p/wCDhX4U+JvjX/wSB+Lnhfwd4b8QeLfEWqnSBZaXomnzX15ebNbsZH2Qwo8j7ER3z2jSvhP9i7/gmt+0l+zz/wAFff2a/E3xWk8QeL/D3w7XxR8NvD+qWvh61jstM8J6Vok8ej3tzNYvJHAbuTUJ1SG8In3wEO8m/wCTzT1j9rvFHiO28G+F9R1i9j1Ce10u1ku5ksLKe/uJI0TzH2QwJJPNJ/cSON3k/gjrwW7/AOCqfwH0v4jx+Ebzxlfad4qbXfDvheTSr7w3qlpc22qa9ayXWlWskb2v7uSeCF9/mf6jZsn2P+7r8yvHfxF/a98QfF2+1fSdA+O3gvVPGHhj4pweLPCGmab4x1Cy8KXKabfyaCkGqXtzcabdTyXUMElrPosdqgkk8tBsnSOvKNa/Zb+MniX4iad4o8efDv46ahb3njz4B694j1O10DXJNZuIbLwffR63cpPax/bPPt532TyQHz453T/lpsyAf0KUV+PvgL/hoz/hIfht/wAJ9/w0x/wzL/wuP4gb/sP/AAkf/CYf8I19h/4pn7V9i/4qXyPtf27/AF/AEw8/wDd/Za8m8W/8Nq/8KC+Cf8AwkH/AA1l/b/AAq62/4Wn/Yf23+0P7H/AOE0tPsX9ifZfk/4Sz+zfM+1fbv3n2Hf537zz6AP3bryX4V/tufDj45+N9T8P+EtS17X77RfE+qeDdUms/DGqSWel6vpaRve2t1dfZfIh/18ex3kRJ3+SB3evJ/+Cwn/AAs7/hR/w2/4V5/wnn9gf8LQ8O/8LG/4Qz7X/bn/AAifnyfbvI+w/wCn/wCs8jf9g/f7N/8Ayz8yvy78DfCX9o74Zat4w/4Vb4b/AGkvDvhXxF47+Out2u2x8Q2d5qcM/hO0/wCEdu7vz0F3JPJdofssl3md7pH2Hzw9AH77UV+MPxw8CftL2HgX4I2V94o/aW8O+C2/Z2j1C9utE0rxZ4q8QS+PJpI576CdNP1C0u0v9kkfkDVpzYQeXJCkfD7PSdSsfjjb/tJ+NIfjJeftgalqSaF8PU+GF18MrP7H5995f/E7e7gtXfw3BI+pbzdJq0kkaQcRvJB5L0Afpr4F+Knhn4n/ANsf8Iz4k8P+I/8AhG9Un0LV/wCy9Rgu/wCy9Rg/19rPsf5J496b0k/eR+ZXQV+NsPwK+NXwEs/jvb6RoPxm0NfFH7Xlp4o8c/8ACMRauH1P4c3s/ni60t7L55HkfH2g6T/pyIiJPsjj2J0H7Lvhz9pHxX+2N8ArfxHL+0RH8FY/iz8TbvTv7SvNbs5P+EXgtbSfw7/bbu6Xfl/bY7ryE1b95ImU2PA4jIB+uVFfjf8A8EsLP4ueN9U8eTfGjx98ZvFfw5+BOhar8HvGMmg+KPEepah4i8ZQeMJL/wC3adDpcn9pPHBYT2MD3WyGTy32bJIEn2fshQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFcz8bv8AkjHi3/sC33/oiSumrmfjd/yRjxb/ANgW+/8ARElAHWap/wAhK6/67PUNTap/yErr/rs9Q0AFFFFABRRRQAUUUUAFFFFABRRRQB+c/wAT/wDkq/jH/sYdU/8ASqevrT9m/wD5N38Bf9i5p/8A6TR18l/E/wD5Kv4x/wCxh1T/ANKp6+tv2b4/+Md/AX/Yuaf/AOk0de9U+CJ8xT/iT9T5v/ZL/wCTnfBX/Xa6/wDSG7r7yr4N/ZL/AOTnfBX/AF2uv/SG7r7yrjzT+Oejk/8ABOV0bxT4o8RQT3Fho/hv7JHe3VpCbnW545JPInkg37EtX2fc/wCelWvtXjD/AKBPg/8A8H13/wDIVeZ/GX4w6l8Bf2Tta8TaXDp7XFn4intXvL5XfT9DguvET2s+q3SRum+1sYJpL2f54f3Fo/7+D/Xx6P7MvxuvPiD8MND1LVvFPgP4jW/iDVJ7HRPFXw9tbq40PWESCSR53RHu47Hy5ILq1/eXc8ckkEf7xJJ0tI/NPWO7+1eMP+gT4P8A/B9d/wDyFR9q8Yf9Anwf/wCD67/+Qq+UPiZ/wUJ8TeFf2UPgP4m1Hxd8J/hb4i8beKJPBnjvW/FlnPceH/Cmr2OlatJqlrGn9oWn+r1XSHskf7W6P5m9Hn3o79b8Dv8Agono938P9TuvF2taf42a216bStB174beGNU1qz8eWMNrYTzapY6fZf2jOlraT3v9nTzieeBLq32O8bzpBGAfQX2rxh/0CfB/g+u/wD5Co+1eMP+gT4P/wDB9d/ACFXm+u/8FB/hLoXifR9NTxJqGsR+ILrS7G11jQfD2o61occ+qSW8enQT6pawSWFrJP9qtZI0nnT93dwSf6udJH+d/h5/wAFjv8AhYX7EP7PfjaHQfL+JHxc8UeFvC+taD9i/wCRf+13umwajqM9t9q8+GxeC9ge1nkd/wDkNaM7/wDH3HQB9ofavGH/AECfB/8A4Prv/wCQqPtXjD/oE+D/APwfXf8A8hV5v8ff21vBfwat/Gmlarr2oeC9Y8N6De6smr694K1ifQ/3GnSXz+RP5cEGqSRwJJO9raXfnyRwT/c8h9nI/sj/ALYvif41fHDxB4Z8VWXh/TbG4PiIeFGsIZ/M1T+xPFuraNqO/wCeTZ5EH/COv+82b5L+fZvRHjgAPdvtXjD/AKBPg/8A8H13/wDIVH2rxh/0CfB/g+u/wD5Cr4v+Hn/AAWO/wCFhfsQ/s9+NodB8v4kfFzxR4W8L61oP2L/AJF/7Xe6bBqOoz232rz4bF4L2B7WeR3/AOQ1ozv/AMfcde9eBP2xv+Er/a61fwU2nm38FzefoXhvXvJ2W+sa9pyefrFolzv2Tfu7lEgjjTz/AD9C8QI/l/ZKAPVvtXjD/oE+D/8AwfXf/wAhVmeKNE1zx54a1HQ9c8LeAdY0XWLWSx1Gxv8AWJri2vIHTy3gkR9P2SJJH8jpJXjn7A37Y/if9qQ6H/wkFh4ftf7U+DngX4hT/wBmwzx+XqOt/wBrfak+d5P3Ef8AZ8Hlp/rP3km+ST+D6WoA8/8Ahp8Nbr4LeCbLwz4N8C/DXwn4d0wubLS9EvnsLOz8x3eTy4IdPjjj8yR3k/66PXQfavGH/QJ8H/8Ag+u/kKugooA5/7V4w/6BPg/wAH13/8hUfavGH/AECfB/8A4Prv/wCQq6CigDn/ALV4w/6BPg/AMH13/8AIVH2rxh/0CfB/wD4Prv/AOQq6CigDn/tXjD/AKBPg/8A8H13/wDIVH2rxh/0CfB/g+u/wD5CroKKAOf+1eMP+gT4P8A/B9d/wDyFR9q8Yf9Anwf/wCD67/+Qq6CigDn/tXjD/oE+D/AAfXf/yFR9q8Yf8AQJ8H/wDg+u/AJCroKKAOf8AtXjD/oE+D/8AwfXf/wAhUfavGH/QJ8H/APg+u/8A5CroKKAOf+1eMP8AoE+D/wDwfXf/AMhUfavGH/QJ8H/+D67/APkKugooAwvC3iTUr/xDqmm6pZafazafBa3aPZ3r3cbpO88f8cMf/Pr/AOP1W+N3/JGPFv8A2Bb7/wBESVNo3/JVfE/AGCNH/8AR+p1D8bv+SMeLf8AsC33/oiSgDrNU/5CV1/12em2sXm+Y7f6uNPMenap/wAhK6/67PRb/wCpuv8Arj/7OlAAJIP+eM/AH+/+wqjqnijSNBj3XkggT/bm/8AsK+Sv2pf2tPj98OfHGsJ4N+G/he68K6XI8aalfz/AGiS82fx7I545P8AgHl1y37Mn7RFn+2XDa694i1ayha3gS+jj0szxRfI/wDAj/I8cn+/+7/7aV8RxVxlRyjDc9D35/4v/Sj38rySeIU6lb3IH3FpmvaXrMW+1kkmT/Ym/wDsKteZb/8APGf/AL/f/YV8W/sxfFC0+HX7Q1v4D0e+v73w7HZJaWT3EMkkkk8aeY8jz/6tP3flps/4H/y0+T7Mr0eFOIo5vg/rThyHJm+W/Uq3Iibzbf8A543H/f7/AOwo823/AOeNx/3+/wDsKhor6Y8sm823/wCeNx/3+/8AsKPNt/8Anjcf9/v/ALCoaKAJJYvK8v8A6aJ5lR1Ncf6m1/64/wDs71DQB+c/xP8A+Sr+Mf8AsYdU/wDSqevrj9m/k3fwF/2Lmn/APpNHXyP8T/+Sr+Mf+xh1T/0qnr60/Zv/wCTd/AX/Yuaf/6TR19BW+CPofMU/wCJP1PnH9kv/k53wV/12uv/AEhu6+8q+Df2S/8Ak53wV/12uv8A0hu6+8q4c0/jno5P/BPP4dC1zxP8E76z8NeIP+EV8Qf2xqkllqT2Md/HG6axO+yeF/8AWQSbNkiRyRyeXJJsngk8udMT4BfALxN8H59b1XVPFXh/XPEfjvxR/wAJL4vubbw9PY2d7s0uDToINOhkupJLX93p+nO7zz3W947r/V+fH5Hd/wDCqdF855FXWIftE7zukOvajbx73fzJPkSfYn7x3ej/AIVbpHr4i/8ACo1T/wCSq809Y8r179i03/7Vum/Eaw8Uf2bpNv4otfGV3oP9n+Z9t1dPDuraBPdfavM3x+fY3ulJ5fl+XH/ZP+r8y7eSs39t39gjTP2wfFPg7xFNa/DXUtY8F2uo6Za2fj7wRH4w0OSC+ktHnf7F9qtZEu0fT4fLn8/93HJdp5cm9HT2b/hVukeviL/wqNU/+SqP+FW6R6+Iv/Co1T/5KoA+JPFP7H3xO8IfF6x+G/w70HUofhbeeMfBPizXde1rQ9Djs55NA/sLf9imstTgkskktdCtIUtf7CeP7V5mx4LWSOSD0vwJ/wAEnPDPw/8AhR4I0e01vzPEXhTSvAemT6v/AGRDHHef8I1qOm3TzpB/rIJ9Sj0yygnfz5P3em6b/rPsqV9If8Kt0j18Rf8AhUap/wDJVH/CrdI9fEX/AIVGqf8AyVQB8X/tIf8ABFn/AIaC8f8AibVP+Es8B6b/AMJB/wAJLJ/b1z8P/tfjeT+29G1bTfst1rX22Pz7G0/tT9xa+QmyCwsYPM/d+ZXveifsWHw/8PvD2m2vifyNf8K/E/VPiRpmr/2d/wAef9o6zqV3fWPkb/LfzNN1bUdO8+T/AFfn+ekaSImz1X/hVukeviL/AMKjVP8A5Ko/4VbpHr4i/wDCo1T/AOSqAPm/wJ/wSc8M/D/4UeCNHtNb8zxF4U0rwHpk+r/2RDHHef8ACNajpt086Qf6yCfUo9MsoJ38+T93pum/6z7KlXvA3/BL7R/h/YeCdbs/GXiqT4meF9dg8T3uu3OrapPo+oapNPJJr13BoT3r6bZSalBdaon7iD/Rf7SkeH50SvoL/hVukeviL/wqNU/+SqP+FW6R6+Iv/Co1T/5KoA+b/hJ+wR8Tv2ah4VHw7+KfgO1/sP4YeFvhvqP/AAkfgC61b+0P7A+37L2DyNXtfI8z+0H3wSeZjy0+evrCuf8A+FW6R6+Iv/Co1T/5Ko/4VbpHr4i/8KjVP/kqgDoKK5/AIVbpHr4i/8ACo1T/wCSqP8AhVukeviL/wAKjVP/AJKoA6Ciuf8A+FW6R6+Iv/Co1T/5Ko/4VbpHr4i/8KjVP/kqgDoKK5/AIVbpHr4i/8ACo1T/wCSqP8AhVukeviL/wAKjVP/AJKoA6Ciuf8A+FW6R6+Iv/Co1T/5Ko/4VbpHr4i/8KjVP/kqgDoKK5/AIVbpHr4i/8ACo1T/wCSqP8AhVukeviL/wAKjVP/AJKoA6Ciuf8A+FW6R6+Iv/Co1T/5Ko/4VbpHr4i/8KjVP/kqgDoKK5/AIVbpHr4i/8ACo1T/wCSqP8AhVukeviL/wAKjVP/AJKoA6Ciuf8A+FW6R6+Iv/Co1T/5Ko/4VbpHr4i/8KjVP/kqgA0b/kqvif8A7BGj/wDo/U6h+N3/ACRjxb/2Bb7/ANESVqeHfBmm+Erq6nsYbz7RfhI55rnULq7kkRN+xP37yf8APZ/+/lZfxu/5Ix4t/wCwLff+iJKAOs1T/kJXX/XZ6Lf/AFN1/wBcf/Z0o1T/AJCV1/12ei3/ANTdf9cf/Z0oUeZ2C9tT5X+L3xG/4Rfxlrmiaw/yW8z3aJ/0wd5HTZXkP7Hn7K3g/wCL3w81hvCviH7D9j166kutK03/AES3s3R/LSB4U+/HHs/65ySeY/8A1z/NL9mn9pHx148+JPjvxJ4l1rxBH4l8SeJL6O+s7mHy5JEdPnjnff5kH2SSCBEgjT/lpP8Ac2fP9z/s5/ErSv2afBcE1nN5F1b/ALzfv/1j/wCsevWXgLhpU6069X23P8MP5epOO8T61HkpUKPJyfGfZf7Kv7Edt+zneR6lLqt5qusXFlHaXru7/Z7jZ/GiP9z77/6v/npVX/gqDd+LoP2RJrfwH4yv/h94s1jxj4R0bS/EdpB9ofSJLrxTpNrv8jIjnj2TPvgf5J496P8AI9fQNhdfarNJl/5aJWH8R/hpovxZ8Pw6X4gs/wC0rGz1TTtZhh854/LurG+gvrV/k/55z2sMmz/VyeXsf5K+cy/LqOCo/V6EDsxWNrYqftKx8Z23/BSW88H/ABC+LvizWNJ106r4S8C/D3TdU+HkN1dXz+GPFGq63rti9i6QwPK/7ybTt91a2k73dokE8Ed0klrHJu6X/wAFaNYGhW8OrfB/xFo/im80vWDpmm3zajpMGv6vBfeHrHS7K1fUdPtLvyL668SWtr9tntYI4J4J/keCPz6+h/En7H3w18W+JvHetXvhOwTWPiRa6Xa+JL62kktLi/8A7Od306ffA8ckd3aSTb4LqPy54/Lg2SfuIPLTwZ+yN4B+H1p4d+w6PqFxdeGNem8TWV/qOs32qahPqj6fPpr3V1dXU0lxeyfYbp7VDPI/lxpCicQQ7O05TO/ZN/a30X9ryz8X6t4ah8zw3oOp6da6Pqe+T/ieWt7oGk6xBdeTIkckP7vU0TY/z/u9/wDH5cfrVcHpv7OHhPQtAvdK0uHxBo9hqB1t7iHTvEWo2fz6xeyX2oz/ACTJsnkuHd454/3kHmSJBJBG7112jeHLfQdR1W5t31CSTWLr7XP9pvZ7iON/Ijg/cI7+XBH5cCfJHsj8zzH8vzJJJHANS4/1Nr/1x/8AZ3qGprj/AFNr/wBcf/Z3qGgD85/if/yVfxj/ANjDqn/pVPX1p+zf/wAm7+Av+xc0/wD9Jo6+S/if/wAlX8Y/9jDqn/pVPX1p+zf/AMm7+Av+xc0/wBJo696p8ET5ej/ABJ+p84/sl/8nO+Cv+u11/6Q3dfeVfBv7Jf/ACc74K/67XX/AKQ3dfeVceafxz0sn/gnkv7Vv7Y3hn9j3/hW/wDwkth4gvv+FqePNL+H2kf2VBBJ9n1HUfM8h597p5cH7h97x75P+mb0fCH9sbwv8aP2p/jD8I9LsfEEPiT4Kf2J/b1xeQwR2d5/alrJdwfZXR3kfy40+fzI0/ef368p/wCCtv7MnjP9ofwN8EdV8C6K3ia++D/xi8NfEK/0SG8gtbvVdPsZJ0njtZLqSOAT/vjJsnnhj2Rv8+/Yj+C6p+xB8VPjFL+3t441b4X+INOtf2jNL8PaV4b8GXPjm00LX9QTS9K+yXW/UNPe+tIPMeZ0gSSSSOfy3juo0gdzXmnrH6VUV+OOof8ABKX41a98C/2ddN174c30PhLwJ4x8X6h4t8FeG9Q0C7uNU+228kel6umha1NdeG7KQyJO8ljaTzwWpv5JLVI3nkSDuP2Mf+CV/wASPhR+1H4B8R+IvAOoSaP4O/ZsvfBukT+IPiMmoX/h/Xp9cu54NOTWbKCC7tZI9Nuntft1haeXBH5kcLz7PnAP1Wor4R/4IQ/sceNP2NPg7430Xxh8OW+HdvqGqWUmlwz+IYLq8v4EsYE33VrYySaak8H/AB6/2jb+RPqSQJNdWkEnMnB/An9g3xt4E/be8YeIPG3wH/4T7xTrXx3vvHeg/F8+NoNJ/wCEc8LyWMcdra+fBN/a115EaPa/2XJB9hff/rPI/eUAfpVRX4T6d/wSg/ahs/gz8FfhHJ8H2ez+B3gT4taFN4qi8V6O1j4i1DxFYatBZC0gedbhIHL2OJLhI5N90++OBId7+6fCP/gkX8UfDXxM8F3uk+DfD/gPUPD/AOx0fh1pHiCO8tLf/hEvH888/nzxyWjvPDP/AKVdPJewRvv8+f55JJPnAP1krhfjt+0x4L/ZsPg8eNtaOif8LA8T2Xg3QcWM9x/aGr3vmfZbX9wkmzf5cn7yTZH/ANNK/F3U/wDgil8Zrj9gL4k+FfCfwp8d6H4y174Y+FPDWoadqvirwlpul+JNYtNcsLqd4bHS4Ujm+zxwXTpqmpX32uSO78vy5N7unpXxt/4IuePNF+MXjjR/Avwrsb39n3wr8Wvhn418N+Bv7VsXt/Eml6bo9xY68kFrdT+QbuTzIfPkv3g+1i3ffJI+A4B+nH7KX7Y3hn9sL/hZH/CNWHiCx/4VX481T4fav/asEEf2jUdO8vz3g2O/mQfv02PJsk/6ZpXrVfgT+1p+xZ438A/Hi80Fl8Pt8Vvix8dfihYeFfBTavBPeXfhnxtoD6dD4pmS1eeeCxtDZTSSGS3+5HJv8nZz+k37cH7BnxA1j/gh7qP7O3wp17+0PG2h+BNH8J2N+br+xzr8dj9kjuoPvv5P2uCGeDy5H8v9/skfy/MegD3b4Q/tjeF/jR+1P8YfhHpdj4gh8SfBT+xP7euLyGCOzvP7UtZLuD7K6O8j+XGnz+ZGn7z+/Tfjx+2P4Z/Z/wDjh8J/hve2PiDXPGnxm1W6sNB03TLeAeXDZQfaL29meZ440t7ePy3dN8k77/3MElfld8Vv+CSvxe8f/Eb436p4F+COofCX4W+MPiL8NPECeBbC78LW8+vaJpFrfQarapYpdT6TJILqaG9SC/f7PP5e9/MkGw+k/s4/8En/AB14P/ap/ZZ1u++GviC1+Gvw78d/EPxRe6b4t8R6Bq0nhRb20s/7LkjsrGGCwsvMv7U3Udlpsc8dpJJ5nn/88wD9RPhv4u1Dx14HsdU1Lwr4g8GX14X8/RNbnsZLyz2SSR/O9jNPB+82eZ+7nf8Adyf89PkroK/Bf9nz/ggX8WNU+Gml2fxM+Dmn32peEP2avFfhrw9De67ps6WfjK68Qa1cacgRLkxtJ9k1DfHPJ+4jeSN/MSdE2d54u/4JHftCfE/4mNr3xF8O/Evxr4m1jwb8NrTw7ruleOPDtpceDNU060gj1c3Wt6hBe6lp8kd+k19v0WOb7X5773keTCAH6pftW/tjeGf2Pf8AhW/AAkth4gvv+FqePNL+H2kf2VBBJ9n1HUfM8h597p5cH7h97x75P8Apm9etV+P/wARv+CXfxg1L9rm31y8+Ef/AAl3iRf2stO+KafFA6po8htfA0aW+zS/PnuY9S/0TYifZRB5H+j/ALnzP3ef1E/Zj8N6P4R+B2h6foPwx/4U7pVv5/keD/sunWf9j/v5JH+TTp57RPMk/f8A7uR/9Z8/7zzKAO8ooooAKKKKACiiigAooooAKKKKACuZ+N3/ACRjxb/2Bb7/ANESV01cz8bv+SMeLf8AsC33/oiSgDrNU/5CV1/12elsOI50/wCWkifJ/wB90mqf8hK6/wCuz021i83zHb/Vxp5j0AeG/Fv/AIJufDX4xeMpNb1fwvM99JM93J5N3dW8ck7xxpJPsgeNPMeOGBJH/wBZJ5Ef9yOufuv+CT/wzupY2bw5dz+W+dk19fSR/wDfG/y6+lPMg/55Tf8Af7/7CjzLf/njP/3+/wDsK9HD5tmGHhyUa0o/9vHJXwdGr8cCHTPDlzpenwW3k3Enlps+5U/9lXX/AD73H/fFJ5tv/wA8bj/v9/8AYUebb/8APG4/7/f/AGFede+p1i/2Vdf8+9x/3xR/ZV1/z73H/fFJ5tv/AM8bj/v9/wDYUebb/wDPG4/7/f8A2FAC/wBlXX/Pvcf98Uf2Vdf8+9x/3xSebb/88bj/AL/f/YUebb/88bj/AL/f/YUALf8AMcCf8tI0+f8A77qCpJYvK8v/AKaJ5lR0AfnP8T/+Sr+Mf+xh1T/0qnr61/Zv2f8ADO/gLp/yLmn/APpNHXyV8T/+Sr+Mf+xh1T/0qnr6w/ZvtJP+GePAX+r/AORd0/8A9Jo6+iqfBE+Xo/xJ+p86/sl/8nO+Cv8Artdf+kN3X3lXwb+yX/yc74K/67XX/pDd195V5+afxz0sn/gnyf8AFL/gsp8JPhH8YNc8DalpvxS1DXvD+qf2NcppHgjUdVt5brzLCPyI5oUeOR/M1PS49n3/ADL+1T786JXL6P8A8F8vgXrv2H7DpXxovv7TMH2L7L8NtYk+2ef9g8jy/wBx+88z+19L8v8A56f2nY/894/Myf2EPCXjLVv2nv27JfAV3p+geK7z4n+HorTWr7TwbQJDY2MkyTP/AGf/AKUiQPLvtUvvMfzyif2O9wl9P9QftMftBa/+xh/wT+uPFvibVdDXxrpml6Xoz6tr17G+iWut309rpsF3qN1HDYp9gS+uY5rqeK3gPkLM6QIdkI809Y+ddH/4L5fAvXfsP2HSvjRff2mYPsX2X4baxJ9s8/7B5Hl/uP3nmf2vpfl/89P7Tsf+e8fmGj/8F8vgXrv2H7DpXxovv7TMH2L7L8NtYk+2ef8AYPI8v9x+88z+19L8v/np/adj/wA94/M6z9lz9v3z/gDoXg3wLq2gfHDxZpfj6f4S6B4jk8W79H8UfZdHk1y1vr3WYY7uSS4/sOFEu5o7V9+qpPGiRwfv04P9nH/gpN8UvBuga94f1rwLoHibUdF8VX0Gq6hdePbt5LLUdd+IviTw7o+nW2/TH86wgurCCF7lzDJDafPHaSPGtq4BoaP/AMF8vgXrv2H7DpXxovv7TMH2L7L8NtYk+2ef9g8jy/3H7zzP7X0vy/8Anp/adj/z3j8w0f8A4L5fAvXfsP2HSvjRff2mYPsX2X4baxJ9s8/7B5Hl/uP3nmf2vpfl/wDPT+07H/nvH5m9pn/BVDVtY+PmneG/Dfwo1DXvHnia7svBtzav42eHSLTUYLjx1BdPGJIvLFpBd+FLrfexwJd3FrdRv9leS1gsn+qv2aPjV/w0P8KLfxDLpf8AYeo2urapoOp2KXf2u3ttR0vUbrTb0QTbE8+A3VnOY5HjjkeMxu8cLkxoAfG+j/8ABfL4F679h+w6V8aL7+0zB9i+y/DbWJPtnn/YPI8v9x+88z+19L8v/np/adj/AM94/MNH/wCC+XwL137D9h0r40X39pmD7F9l+G2sSfbPP+weR5f7j955n9r6X5f/AD0/tOx/57x+Z+ilFAH516P/AMF8vgXrv2H7DpXxovv7TMH2L7L8NtYk+2ef9g8jy/3H7zzP7X0vy/8Anp/adj/z3j8w0f8A4L5fAvXfsP2HSvjRff2mYPsX2X4baxJ9s8/7B5Hl/uP3nmf2vpfl/wDPT+07H/nvH5n6KV+RfwS/b4+M3jj9gz9l3wrqEl9F8QI9d+HF7498UML7ZqXhi91jw+LKeG7M3nyXepf2pa20zzjyLp9J8Txpn7Km8A9g0f8A4L5fAvXfsP2HSvjRff2mYPsX2X4baxJ9s8/7B5Hl/uP3nmf2vpfl/wDPT+07H/nvH5ho/wDwXy+Beu/YfsOlfGi+/tMwfYvsvw21iT7Z5/2DyPL/AHH7zzP7X0vy/wDnp/adj/z3j8zoP2zf+Cs9j8FdY+JXhi88E6h4k8IWvh/xFBpmveG9W17T/wC0NS0vQdQ1K9sX1NNMhsbOSP8AszUbUyWGpXV3BcQJ+4R0n+y72nfth6p+z5/wTj+JHxD1PXbCTWtO+JHjHw5pGqeK72Q6Tpk8/jrUdH0t9Qmd0ePTbSSa1ExjfMNpBJ5Y+REoA4HR/wDgvl8C9d+w/YdK+NF9/aZg+xfZfhtrEn2zz/sHkeX+4/eeZ/a+l+X/AM9P7Tsf+e8fmGj/APBfL4F679h+w6V8aL7+0zB9i+y/DbWJPtnn/YPI8v8AcfvPM/tfS/L/AOen9p2P/PePzOs/Zc/b98/4A6F4N8C6toHxw8WaX4+n+EugeI5PFu/R/FH2XR5Nctb691mGO7kkuP7DhRLuaO1ffqqTxokcH79OD/Zx/wCCk3xS8G6Br3h/WvAugeJtR0XxVfQarqF149u3kstR134i+JPDuj6dbb9MfzrCC6sIIXuXMMkNp88dpI8a2rgGho/AAXy+Beu/YfsOlfGi+/tMwfYvsvw21iT7Z5/2DyPL/cfvPM/tfS/L/56f2nY/wDPePzDR/8Agvl8C9d+w/YdK+NF9/aZg+xfZfhtrEn2zz/sHkeX+4/eeZ/a+l+X/wA9P7Tsf+e8fmb2mf8ABVDVtY+PmneG/Dfwo1DXvHnia7svBtzav42eHSLTUYLjx1BdPGJIvLFpBd+FLrfexwJd3FrdRv8AZXktYLJ71n/wU0vLjVPH+sab8PymueD9M0u08Rzar4zuoPC+iSR+IvFGj3080iWsxtrG3utDunOpR2XmTQXVq97HaW9rJNbAHJ6P/wAF8vgXrv2H7DpXxovv7TMH2L7L8NtYk+2ef9g8jy/3H7zzP7X0vy/+en9p2P8Az3j8w0f/AIL5fAvXfsP2HSvjRff2mYPsX2X4baxJ9s8/7B5Hl/uP3nmf2vpfl/8APT+07H/nvH5ne+A/27PihJ+0z4i8M33guxm0vxJ8XdI8D6Jaavr0VjqHhSCTwDb+I9ThnS1tbiCaS3MM/l7LqQTz3bp58EEEcj8B8af+CuPizV9RvvCvgXw3Z2utal4g0G88D+IVk1YeH/GOjv4x0HSbnfe32jQweXd2+s2+yfSv7UjWOeSRJhttWnAHaP8A8F8vgXrv2H7DpXxovv7TMH2L7L8NtYk+2ef9g8jy/wBx+88z+19L8v8A56f2nY/894/MNH/4L5fAvXfsP2HSvjRff2mYPsX2X4baxJ9s8/7B5Hl/uP3nmf2vpfl/89P7Tsf+e8fmd98a/wDgqxq3wP8AAfi7x7cfDjT774f2N14x0Lw9cR+J3j1jVNY8NWWs3V1BdWf2LyLO0kOgakkdzHdXUnNqXt0MkiQfXHhWbV7rwzp82u2mn6frkltFJqFpYXj3lrbXBUGSKGZ4oXmjV8hZHjjLjnYmdgAPgnR/+C+XwL137D9h0r40X39pmD7F9l+G2sSfbPP+weR5f7j955n9r6X5f/PT+07H/nvH5ho/BfL4F679h+w6V8aL7+0zB9i+y/DbWJPtnn/AGDyPL/cfvPM/tfS/L/56f2nY/8APePzP0UooA/OvR/+C+XwL137D9h0r40X39pmD7F9l+G2sSfbPP8AsHkeX+4/eeZ/a+l+X/z0/tOx/wCe8fmGj/8ABfL4F679h+w6V8aL7+0zB9i+y/DbWJPtnn/YPI8v9x+88z+19L8v/np/adj/AM94/M/RSigD869H/wCC+XwL137D9h0r40X39pmD7F9l+G2sSfbPP+weR5f7j955n9r6X5f/AD0/tOx/57x+Ze8E/wDBcr4O/Eu+ht/DPhn47eILq8tvt0MOm/C7W7uS4g8i0n8+Py4f9X5GqadJv/5539q/LdN/wCg1eV/ETV/K/aO8K2LXW37R4X1y4Fob3Z55jvNFHmeT9tTf5e8/vPsM/l+Zj7RaeZ5V8AfO3/D1nwr/wBEo/ag/wDDL+I/kWuo+D/APwUB0X43fEnSfC2l/Df496Xfaw22O78QfDTWNG0+32Jvd57q6hSCP5E/wCenz/cTe7oleu+KPiPo/g3VLGzv7yOCfUH/d/9M/8Abf8AuR10Wl/8hK1/67JQBDXM/G7/AJIx4t/7At9/6Ikrpq5n43f8kY8W/wDYFvv/AERJQB1mqf8AISuv+uz0W/8Aqbr/AK4/+zpRqn/ISuv+uz0W/wDqbr/rj/7OlAI+QP2qv2tPj38NPHGqp4I+G/hu+8M6W77NSv7r7RJebP40RJ45P+AfPXaf8E3f267D9vr4Dz+J4obODUtL1F9Nvks/+PeR08uTem/955fz/wDLT/nnJWN8YvH/APwivjPWNH1R/kt5nu0T/pg7yOmyuK/4J06j4D/Z20PVrbS9NuNA0rxn4hnkS5jsktNIt77f5HkR/P8A9METf5flySf8tPMk8uvlMpzzEYjE1qOLhyKB9ZiuG5xw0K2F99n2nRXkZ/be8D/8Ljj8Gi4vPOuLr7Cmq7E/s+S93+X9l37/ADPM3/Jv8vy/M+TzPM/d1j/8FG57xf2a7O1s9V17QzrXjzwTo91c6Lq91pN39lvfFWk2t1Glzauk8PmQTPHvR0fy5K+np1IT+A+dxGErYbkVeHJznulFfH3i39pV/wDgn/r/AMVvDmfFnjjwv4L0Hwhq3hu01K/1HXdX/tDxFrGpaMLR71hdX09r9rsrWb/V3V2n2i6SFJ0S1tU818W/8FSfEGgfEDwn4y17wD488Omw8L+JdGfwqLHXILPxHqk2ueCLTTrqCG606C+ngjk1fyfP/s3z43+3JBBdfJ5+hyn6F0V8Iwf8FRvGVt420bxJ4g8Ba/4R8F+FPAfjzxJ440e5sr60k1BNETw9dw32j/2pp1jd3Xyag9rsuI7FPMkuvnk+ywST+9fsV/tc+If2nU8SQeJvhzr3gW+0H7LJHczafrdvpmppP5/7uGbV9M0q4eePyH89EgeNI57X9+7ySRxgHvVx/qbX/rj/AOzvUNTXH+ptf+uP/s71DQB+c/xP/wCSr+Mf+xh1T/0qnr6y/Zvk/wCMd/AX/Yuaf/6TR18m/E/AJKv4x/7GHVP/Sqevob4C+MLW3+BnguNvte6PQrFT+57i3SvoqnwRPmaUOapP1PH/wBkv/k53wV/12uv/SG7r7yr4N/ZL/5Od8Ff9drr/wBIbuvvKvPzT+Oehk/8E+cf2I/2NfGHwr+PXx4+Jmm+JPB9rafF7x2L1rSbQPttybPTzY2YzdRvbzq7eRrKCKSS5hT7TZzxrEReW937FrvwG8ceOPEvgXVvEviHwFq2oeAtWi1nT5oPCt9aiG6axhsbuWMf2sw/e21zr8SLKJVjOo2TESNYu13e/ZP+Lfh/xx4b8YaTpd+brUPA/jLVdC1qIQyj7FePN9uSLcwxJm2vbVwyFlzLsyHVkX1qvNPWPmr4gfsI6l8Y/Ez694t1jwfceIr6z0azvtX0XS9a0PUo105gyGxu7fWVmsXI1DxPH5sLiQw6xBDK1xFazJe8h4a/4J2ab+z18Oru6mm0LU7HTzpWta2bbQfEusapqsmk63F4jEsYfWbm6nuG1S48QXKoPPlkbU7OJxdLZPHe/YlFAHyz8PP+CdifD/4raT40juPAbeJdP1VNamu4NC1eIPdyTX0128cb6zIieZJ4i8YFEdXSP+2rIESf2aPtPefBz4G+Nvg74XXSdN8QeAY7G41W61fUIbXwtfD7RdX17b32pyRmbVZDH591JrbonzpB9vskw6WTi79pZQw5paAPNdF0H4pRLYnUPGngS6WMQG9+zeDbuDzyPsHn+WTqj+Xv8vVdmd/l/bLLPmfZJPtpoug/FKJbE6h408CXSxiA3v2bwbdweeR9g8/yydUfy9/l6rszv8v7ZZZ8z7JJ9t9KooA810XQfilEtidQ8aeBLpYxAb37N4Nu4PPI+wef5ZOqP5e/y9V2Z3+X9sss+Z9kk+2+Z+Ef2BZPDXw28J+EmPwx/sXwnbeFbKH7L4U1C3umt/D11pl7p0QuW1aSdo7e5t9UeBJ5JVjOoQBxOLe4GofSARzIpI77jg9ODx15/wASD2qagD498Z/8EntN+LHiKa/8X33h3VbfVTetqmj2h8S2GhvJqVjFY6xPbaZHrv2G1uLuC78RgzpB5ok1eGZnkmt55L7vPCH7G+veFl8I7tT+H8n/AAh/iq88a2otvDupxsuraiCdVuYy2rNj7QdS8TbIpPMih/tSyIVvsBF19DUUAfNPj79hXVPjJ4nk17xdqng648RX9rotnfaxoema1ompRrp7KytY3VvrKTWDkah4niEsLCQw6xBFK1xFbTR3uD8L/wDgmLbfCzRINPhuPCF/DPdaJf6rLcWGvXV1qVxpmvR+IY5TcXWuTSmT+1rrX7kNK0hY6laJMbiOydLz60ooA+W/AX/BOZfAvxW0fxvHN4B/4SbTdWXWpbu10HVohJdyTXs13LHHJrEiJ5j+IfGDKrCRYzrdpkSjTVFznxf8ExbWWe7ubq48Iw6jrVxb32p6notjruk6pHcDUZtSuZbG8i1wT2MktzrPizDQOpWLW4IHMsFm8V59aUUAfNfg/wDYLm8G+NPCmuWjfDHTbnwtdaZfQ22h+EtQ0rT457TS4dH86Gzj1b7PHJ/Zs+tWqO0blILjSUfzxpEfn8b4Z/4JS6XoutR3V3e6DfH+y00QWn/FSjT9CtWutDu5o9EtZNdkg0UJPpc0lq9gkbWTHSjGf+Jc/wBr+xqKAPkfxF/wTFs/Huq63J4mvPCesWvi63urXW9KjsNet9G/4mENrDq91Y6edae0067u45PEIN1bxpP/AMTr55Jil2dR9u0XQfilEtidQ8aeBLpYxAb37N4Nu4PPI+wef5ZOqP5e/wAvVdmd/l/bLLPmfZJPtvpVFAHmui6D8UolsTqHjTwJdLGIDe/ZvBt3B55H2Dz/ACydUfy9/l6rszv8v7ZZZ8z7JJ9tNF0H4pRLYnUPGngS6WMQG9+zeDbuDzyPsHn+WTqj+Xv8vVdmd/l/bLLPmfZJPtvpVFAHmui6D8UolsTqHjTwJdLGIDe/ZvBt3B55H2Dz/LJ1R/L3+XquzO/y/tllnzPskn200XQfilEtidQ8aeBLpYxAb37N4Nu4PPI+wef5ZOqP5e/y9V2Z3+X9sss+Z9kk+2+lUUAea6LoPxSiWxOoeNPAl0sYgN79m8G3cHnkfYPP8snVH8vf5eq7M7/L+2WWfM+ySfbaej/DzxpB4ls9a8VeKtB1b+zdKmsJLbSdKvtJgneePTfMm8l9RngP7+1vXTzI3kSO7jhSRNl1JferVm+Jf+QPP/wD/wBDFAHnN18OdHvtQ1W4urOO6k1hEjuvO/uIkfyJ/c+5vrb8K6THocOl2UfmNHaCG3Tf/sUtTaX/AMhK1/67JQBDXM/G7/kjHi3/ALAt9/6Ikrpq5n43f8kY8W/9gW+/9ESUAdZqn/ISuv8Ars9Fv/qbr/rj/wCzpRqn/ISuv+uz0thxHOn/AC0kT5P++6cXZ3A/AD9jv4v+PPjH8ZPHfiDxLrGv2+veIPEl9HfWdynl3AR/vxzvv8xPsnkQIkEcf/LSf7n8fsn7RHxq039l/wCGM1nZajJd6bsktDY3J8y3e6/5b+X/ANMI/n3/AO3sRP49n6feOv2GfBvj3xfJrl1ocyX0lxJdOYZJreOSd0RJJtkb/wCseNESR/8Alp5af880rwj4rf8ABEjwT8T/AIv2HiK6bUptJtXecaLc3DyWaTySb3n2f6zzPk/56eX/AB+X5le3xZmizXBQw1CHIfQeHuOweR5rLNMdzzXLL3P5p/3v7p8C/wDBMT9oLQfjd+2BoelfETxP5Eck8H/CL2aQJb6fHqKP8iPs/wCWn3PI/wCWfmf9NPIr9mfjR8DfDf7Q3wzn8JeLbbULrR7i6sr7/Q9UutMvI57W6gu7WdLq1dJ4JI54IH8yORP9XXzXdf8ABEH4Xxftc6V8YLDS7qDXNPeO4ks8/wDEvkvU/wCX7yNn+v8A+2nl+Z8/l+Z+8r7Ih0m4jijX7PP9dlfI5Xg54ej7GZ6XHXEdDPMx/tChDk5vsfyf4f7p5jo37I3gHR/hHqngtdHv7rR9cu/7Q1C4v9Zvb/V7y+Ty/Ivn1OeaS+e6g8m18i68/wA+D7JaeQ8fkR7Ofi/4J8fCWLT0hl8N6hfXRtb21/tS/wDEWpX+sSfap9Nned9Qnnku3u45NI0vyLqR/PtPsFp5EkGxK9v/ALKuv+fe4/74o/sq6/597j/vivSPjTx7SP2HPhbo+jQWbeGf7Z8v+0Y7q51vUbrVrzXI761jtbqDUbq6nkn1GCSCG1R4LuSePy7Cx/d/6LB5fQfBX9nPwn8Af7Rk0CHX7q+1jyY73Utd8Qaj4h1S4SEyeRB9t1CaefyI/MneODzPLjeed0j3zvv9B/sq6/597j/vij+yrr/n3uP++KAEuP8AU2v/AFx/9neoanv+Y4E/5aRp8/8A33UFAH5z/E/AJKv4x/7GHVP/Sqevqv9nKP/AIx68B/J/wAy7p/AKTR18qfE/8A5Kv4x/7GHVP/AEqnr6w/Zv8A+Td/AX/Yuaf/AOk0dfRVPgifOYf45+p86/sl/wDJzvgr/rtdf+kN3X3lXwb+yX/yc74K/wCu11/6Q3dfeVefmn8c7cn/AIJ4H/wSzGfiJ+1t/wBlxu/AFHPD1fW6LtUDJbAxk96+SP+CWRx8RP2tv8AsuN3/wCo54er60+2RlmG77pweDjPHfv1x9cjsa809YkYbhj19KFXaoHPHHJzSK6scBgcdcHpS0AFFFFABRRRQAUUUUAFFFFABRRRQAUUVHLMyH5Yy+OSAeSOcY7ZyMYzxnNAElFMjm3huCu0nqCO5Hce3+etPzzQAUUUUAFFFFABRRRQAVm+Jf8AkDz/APAP/QxWlWb4l/5A8/8AwD/0MUAcrU2l/wDIStf+uyVDU2l/8hK1/wCuyUAQ1zPxu/5Ix4t/7At9/wCiJK6auZ+N3/JGPFv/AGBb7/0RJQB1mqf8hK6/67PTbaLzfM/gjj/ePTtU/wCQldf9dnot/wDU3X/XH/2dKADyrf8A57XH/fn/AOzo8u3/AOe0/wD35/8As6+Tf2m/+CkWt/ALx5qWlaX8HPFniax0f/X6q7vaWf8A10R0gk/d16j+xb+2HoP7a/we/wCEq0GH7L9nvX029tvP+0fZ508uTZv/AI/3bp89Z06sJ6QNPZzh/EPYfLt/+e0/fn/AOzo8u3/AOe0/wD35/8As6z/ABH4js/COh3Wpalc29jY2aeZPNM/7uNKwvhJ8a/Cvx38MSax4P1qz1zTre6e0nmtn/4950++jp/rEk+5/rP+eiVv7GfJz8vuHP7SHPyHW+Vb/wDPa4/78/8A2dHlW/8Az2uP+/P/ANnUNFQaE3lW/wDz2uP+/P8A9nR5Vv8A89rj/vz/APZ1DRQBJLF5Xl/9NE8yo6muP9Ta/wDXH/2d6hoA/Of4n/8AJV/GP/Yw6p/6VT19G/AOT/ixXgr/ALANj/6Tx185fE/AJKv4x/7GHVP/SqevpL9n7/kgvgn/sAWH/pPHX0sv4cT5zD/ABz9TxP9kv8A5Od8Ff8AXa6/9IbuvvKvg39kv/k53wV/12uv/SG7r7yrzM0/jnbk/wDBPA/+CWn/ACUP9rb/ALLjdf8AqOeHq+sLGPjcRzk/hyc9z37Cvk/AIJaf8lD/a2/7Ljdf+o54er6ys4zHGw3M3PG7r0HsO+T/h0HmnrE1FFFABRRUb3SRttO7PP8Jxx79PxoAkooooAKKKKACiiigAooooAKKKKACiiigAooooAje3V33fN+fTtx6fh61JRRQAUUUUAFZviX/kDz/wDAP/QxWlWb4l/5A8/AAD/ANDFAHK1Npf/ACErX/rslQ1Npf8AyErX/rslAENcz8bv+SMeLf8AsC33/oiSumrmfjd/yRjxb/2Bb7/0RJQB1mqf8hK6/wCuz0W/+puv+uP/ALOlGqf8hK6/67PRb/6i6/64/wDs6Uct9A21Pmb4tePEi1/WNH1Ty4I7O6nkk3/3HfzP/Z647/glZ8DfB/7JfwQ8Y32jXlnY+FbzW7q/2fanuI9Ljj8uPyHd/wB55nyb/wDrpJJX53fs3ftu/EX9rT4w+NPFmr61HdQa5rV1aWVnNA/mW9i6b7WOBNnlpHBs/ef8tJPtf8fz17r+0Houv/s7fBHwro/hLULXWrrxkv225MV7+7sZ3d5PtF15cn9z5/w2ff8ALr1sj8LpZbjJVMZifj/4f/8AZM8740o4jDQoUKPvwPUf2g/+Cg3jD4ufHu38B/Dezt9Yj1OF7WbSryH/AEOSyf5J577+5H8/APkjT55K+n/ANg/9kvR/wBkH4Tz6JoyXEcGoXr6lP8AaX8ySSd/+Wj/APbPYn/XOOOuf/YP/YZ0T9mnwPHct5mq+INU2Xeo6lcp/pGoT/3/APYjj/5Zp/yz/wCunmSSfSFa5xjqNWfssJDkhD+veOLL8LOP7yv8R87eDfjJ8XPF1vJ48iv/AIYR/D28utUgtdBudPvrfXLOC1+0RwT/AG37U8E8kkkKPJa/ZIPLjnkTz5PI/f8AESf8FdtB8CfswW/xC8beBfFGh3Fn/Z0eoWd5qOgaT5n2qx+1x3UD32qRx+RJ8/lwSSfa/wC/BXskX7Dfwzh+I914o/sPVJb28u5797F/EGoyaPb3U+/z7qHTPP8AsMN3Jvk3zxwI++eR/M/eSVD4u/YG+FnjaztYbrQ9Wgjs4IbRG03xHqmmySQQwfZEtXe1mR54PIREeGTej7PnR68D3+WX83u/bHp+77WH8vvf/anGz/8FNfDcPiPW7NvA/xCXTdLR00/WHg077Hr98kNpP8AYbVPtvn+fJ9tgTfPHBB5m/8AeVzvjb/gsz8L/hhrmgaV4u0nxJ4P1jWL26sb6w1vUdDsLjQ/InjgkkkR9R/0r94/3LD7VJJ5e/y/9X5npXxQ/YU8F+MvhHrHhvQ4ZNAvry1uo7LUnnurv+z557WODz9nnxyP+7gg/wBXIkn7vekkcn7yuV+BX/BNbw/8NvAWi2viXxD4q13xVpuoX2oz63ovifX9C+2PdTi48ibZqElxdQfu4/kvp7r/AJaP/wAtJK2932v9wz972X98+nLj/U2v/XH/ANneoamuP9Ta/wDXH/2d6hpdSuh+c/xP/wCSr+Mf+xh1T/0qnr6A+Asv/FjfBf8A2ArH/wBJ0r5/+J/ACVfxj/2MOqf+lU9e9fAgt/wo/wb/wBgKy/j/wCndK+l/wCXcT5vC/HP1PK/2S/+TnfBX/Xa6/8ASG7r7yr4N/ZL/wCTnfBX/Xa6/wDSG7r7yry80/jndk/8E8D/AOCWn/JQ/wBrb/suN1/6jnh6vrO04h6sfr2/Qf8A1q+TP+CWn/JQ/wBrb/suN1/6jnh6vrK1/dnZ8zf7WPQAdf8AEk8Hn0809YmooooAKKKKACiiigAooooAKz9Z8J6X4j1HSbzUNM0++vNBu2v9MnuLdJZNOuGglt2mhZgTHIYJ54i64JjmkXO12B0KKACiiigAooooAKKKZMjun7twjZHJXcOoz+nH40APooooAKKKKACiiigArN8S/wDIHn/4B/6GK0qzfEv/ACB5/wDgH/oYoA5WptL/AOQla/8AXZKhqbS/+Qla/wDXZKAIa5n43f8AJGPFv/YFvv8A0RJXTVzPxu/5Ix4t/wCwLff+iJKAOs1T/kJXX/XZ6LH/AFNz/wBcf/Z0o1T/AJCV1/12eoYpfK+7QB8y+KP+CX/gC6+Il14g0O2k8OSahfT6ndQ6akFvHJdT+Xvf7nmfvNifu/8AV/6x/wDWSSeZzJ/4JEeD7GwtbCzudUsdHs/3cOm2ckFpZxp/cREg+T/tnX2P/at1/wA/Fx/33R/at1/z8XH/AH3XpUc4xlOfPGZyzwdGrrOBnaNYPpelwQt+8kjTy6tVP/at1/z8XH/fdH9q3X/Pxcf9915t7nUQUVP/AGrdf8/Fx/33R/at1/z8XH/fdAEFFT/2rdf8/Fx/33R/at1/z8XH/fdACX3+ptv+uP8A7O9Q0Sy+b96igD85/if/AMlX8Y/9jDqn/pVPXu3wIb/ix/g35f8AmBWX/pOleE/E/wD5Kv4x/wCxh1T/ANKp67L4R+Jr6D4UeGI1m+VNJtVH0EKV9V/y7ifP4WPNOb8yn+yX/wAnO+Cv+u11/wCkN3X3lXwb+yX/AMnO+Cv+u11/6Q3dfeVePmn8c6sn/gngf/BLT/kof7W3/Zcbr/1HPD1fVm/5t25lVcHjjcRgck8cg4weeOPWvlP/AIJaf8lD/a2/7Ljdf+o54er64rzT1goY7Rn09BRRQAUUUUAFFFFABRRRQAUHpxRRQA3L7/urtz13c4x6Y9f89qdRRQAUUUUAFFFFABRRRQAUUUUAFFFFABWb4l/5A8/AAD/ANDFaVZviX/kDz/8A/8AQxQBytTaX/yErX/rslQ1Npf/ACErX/rslAENcz8bv+SMeLf+wLff+iJK6auZ+N3/ACRjxb/2Bb7/ANESUAdZqn/ISuv+uz1DU2qf8hK6/wCuz1DQAUUUUAFFFFABRRRQAUUUUAFFFFAH5z/E/wD5Kv4x/wCxh1T/ANKp69M+Dmiu/wAIvCreT97R7Q9P+mKV5n8T/wDkq/jH/sYdU/8ASqevefgR/wAkP8G/9gKx/wDSdK+qo/Aj5nDz5ZzXmeWfsl/8nO+Cv+u11/6Q3dfeVfBv7Jf/ACc74K/67XX/AKQ3dfeVePmn8c9DJ/4J4H/wS0/5KH+1t/2XG6/9Rzw9X1xXyP8A8EtP+Sh/tbf9lxuv/Uc8PV9cV5p6wUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABWb4l/wCQPP8A8A/9DFaVZviX/kDz/wDAP/QxQBytTaX/AMhK1/67JUNTaX/yErX/AK7JQBDXM/G7/kjHi3/sC33/AKIkrpq5n43f8kY8W/8AYFvv/RElAHWap/yErr/rs9Qxfvfu1Nqn/ISuv+uz0WP+puf+uP8A7OlAC/2Vdf8APvcf98Uf2Vdf8+9x/wB8VnaprNtoNnJc3k0cEEf8bvXDy/tVeA7W7+zN4h0/zP8Arulb08PWq/BAxr4ijS0nM9J/sq6/597j/vij+yrr/n3uP++KxvDniix8WWf2nTby3uof9h60qws0bXvsT/2Vdf8APvcf98Uf2Vdf8+9x/wB8VBRQBP8A2Vdf8+9x/wB8Uf2Vdf8APvcf98VBRQAUVNff6m2/64/+zvUNAH5z/E/AJKv4x/7GHVP/SqevefgMf8Aixvgz/sBWP8A6TpXg3xP/wCSr+Mf+xh1T/0qnr3r4ERf8WP8G9P+QFZf+k6V9dR+A+bo/wASfqeV/sl/8nO+Cv8Artdf+kN3X3lXwb+yX/yc74K/67XX/pDd195V4eafxzuyf+CeB/8ABLT/AJKH+1t/2XG6/wDUc8PV9cV8j/8ABLT/AJKH+1t/2XG6/wDUc8PV9cV5p6wUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABWb4l/5A8/AAD/ANDFaVZviX/kDz/8A/8AQxQBytTaX/yErX/rslQ1Npf/ACErX/rslAENcz8bv+SMeLf+wLff+iJK6auZ+N3/ACRjxb/2Bb7/ANESUAdZqn/ISuv+uz0W/wDqbr/rj/7OlGqf8hK6/wCuz0W/+puv+uP/ALOlAHyPo3xah/aR+IGq63eSfavCuj3T2ml2H/LO42fxv/f/ANys3VP+Ckun+EvhRa+J20ySDwXJq8+hbN/2eS3kTzP+WOzy/L+R/wDlpXif7L+jal4DuNS8MXVzcWuq+F9Rnsb2Hf8AxpJ9/wD7aR1l618TPhf+0h/wUiT4V694x1TWPEnw38PjUbLwc+jyR6XHqX+vnvZ59n7+RLR7Xy0/1ceJ/v76+6xWX044aj7GR+c0c3qfXK3t4fB/6SfRXxP8ef8ACm54PHPhdI7WCN431Gwh/d295A/8ez+Cvqjwb4us/HnhPTdYsH8y01S1S7gf/YdPMr8+f2ubp7DwVqT3FzcTvcJ5EEO/zPMnf92iIlfaX7Jfhy58G/s5+EdKvP8Aj60/S4LR/wDfRI4683ibD06Khb4z1uEsZUxMZ/yGV/w2R4Y/4U/AMJt9g8Qf2V/wnn/AAr3yfIg+0f2j/wk3/CN7/v+X5H2759/meZ5Hz+X5n7uut+Pvxj039nT4EeNPiFrUOoXej+A9CvfEOow2CJJcSQWsEk8iIjukfmeWn7vzJEr49/4dtax/wAKr/tj7N48/wCE6/4Xv/wmf9lf8LB1H+w/7I/4WL/av2r+y/tv9m/8gn9/s8jzPM/5Z/aK8s+NH/BND4leLPEfx4vLbRfHmr+NvGGlePIoNeOoeFbHQ/Edjqllq0Oj6P8AakgOu3nkJdadB9l1KeCxgew3pP5djYxyfLn2B+odFfnr+w38DpPEPx+g8XeF/hGPBt9ofxi+It74u+I4XS7T/hPNL/tfxJaJpe+2nk1Kfy7ubTpPLu4I4P8AiU7xJvjg8z9CqAJrj/U2v/XH/wBneoamuP8AU2v/AFx/9neoaAPzn+J/JV/GP8A2MOqf+lU9e9fAiZP+FH+Df8AsBWX/pOleC/E/wD5Kv4x/wCxh1T/ANKp69s+Bkn/ABZPwf8A9gOy/wDRCV9dhPgPl4y5ak15nnP7Jf8Ayc74K/67XX/pDd195V8G/sl/8nO+Cv8Artdf+kN3X3lXh5p/HPSyf+CeB/8ABLT/AJKH+1t/2XG6/wDUc8PV9cV8j/8ABLT/AJKH+1t/2XG6/wDUc8PV9cV5p6wUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABWb4l/5A8/AAD/ANDFaVZviX/kDz/8A/8AQxQBytTaX/yErX/rslQ1Npf/ACErX/rslAENcz8bv+SMeLf+wLff+iJK6auZ+N3/ACRjxb/2Bb7/ANESUAdZqn/ISuv+uz0W/wDqbr/rj/7OlGqf8hK6/wCuz021l8rzP+Wkcn7t6APlr9tf9lrXta8WR+P/AIc21vH4ujg2XsLv5dvrCJ9xH/6af7deO23xA+J2jXE95L8E7P8A4SOSD7JPqUOqWMdxcJ/c3/6zy/8AY8yv0J8y3/54z/8Af7/7Co/stjKPmtH/AO+k/wDiK9HD5piaUOSB5WLyTB4ifPOJ8H/s+/s5+PPjJ8WLXxJ8RtHt7G10t/M06wSZJLezf+/ALclfc9hYLpdnHDEnlxxp5cdXYfscX3beSP/AIH/APYUebb/APPG4/7/AH/2FcuIxE60+eod2Gw9HDQ5KBDRU3m2/wDzxuP+/wB/9hR5tv8A88bj/v8Af/YVgbkNFTebb/8APG4/7/f/AGFHm2/ADxuP+/3/wBhQAXH+ptf+uP/ALO9Q1JdS+b5f/LOOP8AdpUdAH5z/E/AJKv4x/7GHVP/SqevbPgaf8Aiyng/wD7All/6ISvE/if/wAlX8Y/9jDqn/pVPXu3wItf+LH+Df8AsBWX/pOlfXYT4D5eMeapN+Z5f+yX/wAnO+Cv+u11/wCkN3X3lXwb+yX/AMnO+Cv+u11/6Q3dfeVeHmn8c9LJ/wCCeB/8EtP+Sh/tbf8AZcbr/wBRzw9X1xXyP/wS0/5KH+1t/wBlxuv/AFHPD1fXFeaesFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVm+Jf+QPP/wD/wBDFaVZviX/AJA8/wDwD/0MUAcrU2l/8hK1/wCuyVDU2l/8hK1/67JQBDXM/G7/AJIx4t/7At9/6Ikrpq5n43f8kY8W/wDYFvv/AERJQB1mqf8AISuv+uz1DU2qf8hK6/67PUNABRRRQAUUUUAFFFFABRRRQAUUUUAfnP8AE/8A5Kv4x/7GHVP/AEqnr3r4DSf8WN8Gf9gKx/8ASdK8F+J/JV/GP8A2MOqf+lU9e9fAaP/AIsb4M/7AVj/AOk6V9VR+A+Xo/xJ+p5X+yX/AMnO+Cv+u11/6Q3dfeVfBv7Jf/Jzvgr/AK7XX/pDd195V4+afxz0sn/gngf/AAS0/wCSh/tbf9lxuv8A1HPD1fXFfI/AAS0/wCSh/tbf9lxuv8A1HPD1fXFeaesFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVm+Jf+QPP/wAA/wDQxWlWb4l/5A8/AP/AEMUAcrU2l/8hK1/67JUNTaX/wAhK1/67JQBDXM/G7/kjHi3/sC33/oiSumrmfjd/wAkY8W/9gW+/wDRElAHWap/yErr/rs9Q1Nqn/ISuv8Ars9La/8ALd/+eaeYn/fdAEFFRy+LraKSRGudPjkj++nlpR/wmVn/AM/ml/8AkCp5kt2F0SUVH/wmVn/z+aX/AOQKuf2m39y3/wC/CU1JPYCvRVj+02/uW/8A34Sj+02/uW/AH4SmBXoqx/abf3Lf/vwlH9pt/ct/wDvwlAFeip7qLyo4HX/AJaJUFAH5z/E/wD5Kv4x/wCxh1T/ANKp695+Ax/4sb4M/wCwFY/+k6V4N8T/APkq/jH/ALGHVP8A0qnr3n4DH/ixvgz/ALAVj/6TpX1VH4D5ej/En6nln7Jf/Jzvgr/rtdf+kN3X3lXwb+yX/wAnO+Cv+u11/wCkN3X3lXj5p/HPSyf+CeB/8EtP+Sh/tbf9lxuv/Uc8PV9cV8j/APBLT/kof7W3/Zcbr/1HPD1fXFeaesFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVm+Jf8AkDz/APAP/QxWlWb4l/5A8/8AwD/0MUAcrU2l/wDIStf+uyVDU2l/8hK1/wCuyUAQ1zPxu/5Ix4t/7At9/wCiJK6auZ+N3/JGPFv/AGBb7/0RJQB1mqf8hK6/67PRb/6m6/64/wDs6Uap/wAhK6/67PRb/wCpuv8Arj/7OlC3A/Pn4aeLdB+KmoeJtV8QSaxqU/8Aa/2S1RNevrS3t4EtYJPkSCeP/lo7/PJXq3gP9nTSPidpNxfaH4d1y8t7ebyJH/4TLVU8t9m/+O9/6aV8rf8ABNjxl8NYtTvLD4l65qNjLJdSXFmhjP2C5T7JJ5z3U+z935exNnzp8/l/fr12z/aIt/h7+zP4o/4RvxRq1hr2oeIjN4K8PRX9raeIPFsMyW9pZv5L738kz+e/yIN4jz8mCK/MamIpvE1VV5Z+9U/l5/dkfKvFUqcZTrf3ja+Onw/sfhd8GNR8ZaHDqNrLoGp2sP2608aXepJHN9rgjeCSOS6nR/3byb4/Lr6r+AXiN/Fvwn0e/lfzPtECSJ/uV8WftNJe2n/BMEa1pnibR9d0PxVfWd5dFNHFrqB1F7gG6LzebseRJ4XTY8O/5PL39MfVn7D0rS/sn+A3b948miWu/wD78R19Vw/8E/d5Ph/9u/lPTy2pzG7/AMNS/DH/AIXh/wAKx/4WJ4D/AOFlf9Cr/b1r/bn+o+1/8eW/z/8AUfv/APV/6v5663wv4o03x54Y03W9D1LT9Y0bWLVL/Tr+wnjuLe8gdPMSdHT5Hjkj+dHjr5M/ZW+O/wAKfC3h3VPhL441/wAJSfEOT4seJ7+18DXckd54g3z+M9S1LTb7+zB5k+zy5LTUUuvL2RwbLrfHBH59fPX7CH7VHivw98BvgZocHxE/snxJpelfDXw/4Y+F32fTv+K38NXuj+Hv7U1sQPD/AGnP9k+262/n2k8dpH/Yv7yN/Iu/M+kPXP1Gor81/Gn7cfxUi+DeqyaL8VtAuh/wncGjeI/FurJaeGdI8CQPY6ldf8hCfT7qDS/9Ih06xfS9asJ9SsZ7uS1nnn+3adfV9nfsN+OvFHxN/ZZ8K614w1Xw/wCINcvPtSf2rokk0lnqlol1OlpdpO9ra/avMt0gf7VBaQWk8knnWsfkPBQB7Bcf6m1/64/+zvUNTXH+ptf+uP8A7O9Q0AfnP8T/APkq/jH/ALGHVP8A0qnr3z4Df8kN8Gf9gKx/9J0rwP4n/wDJV/GP/Yw6p/6VT1758Bv+SG+DP+wFY/8ApOlfVUfgPl6P8SfqeU/sl/8AJzvgr/rtdf8ApDd195V8G/sl/wDJzvgr/rtdf+kN3X3lXj5p/HPSyf8Agngf/BLT/kof7W3/AGXG6/8AUc8PV9cV4L+yj8BJP2dNZ+LWpXGs2uqN8UvHU/jJYkhdP7KSTTrGxSDf/wAtP3eniTeQnM+z+De/sn/CUL/07/8Afb/ABFeaesa1FZP/CUL/wBO/wD32/8A8RR/wlC/9O/AH2/wARQBrUVk/8JQv/AE7/APfb/wDxFH/CUL/07/8Afb/ABFAGtRWT/wlC/8ATv8A99v/APEUf8JQv/Tv/wB9v/8AEUAa1FZP/CUL/wBO/wD32/8A8RR/wlC/9O/AH2/wARQBrUVk/8JQv/AE7/APfb/wDxFH/CUL/07/8Afb/ABFAGtRWT/wlC/8ATv8A99v/APEUf8JQv/Tv/wB9v/8AEUAa1FZP/CUL/wBO/wD32/8A8RR/wlC/9O/AH2/wARQBrUVk/8JQv/AE7/APfb/wDxFH/CUL/07/8Afb/ABFAGtRWT/wlC/8ATv8A99v/APEUf8JQv/Tv/wB9v/8AEUAa1FZP/CUL/wBO/wD32/8A8RR/wlC/9O/AH2/wARQBrUVk/8JQv/AE7/APfb/wDxFH/CUL/07/8Afb/ABFAGtWb4l/5A8/AAD/ANDFR/8ACUL/ANO/fb/APxFV9U1xL+xeHdbp5nGd7/ABFAHlPi3/hLdG8QTpo32e+tdc2RwPN/zB32ff8A+uflp/38/wDInb+FLCTS4dLtpJpLqS3EEbzP/wAvH+3U/wBnX/n4t/8Ax/8A+Ip9lHDaXcLtcQny38zhH/8AiKAK1cz8bv8AkjHi3/sC33/oiSumrmfjd/yRjxb/ANgW+/8ARElAHWap/wAhK6/67PRb/wCpuv8Arj/7OlGqf8hK6/67PS2svleZG37vzE8vf/zzoA/CDS4n8B65dabrNtJpt9p8/lz20yeXJG9fSHwV/wCCkniT4G+Djo+l6tod/Ar74f7btp76S0+Ty9kH7+PZH8n3P+ulfpXrPwX8P69qMlxdRQyTyff+/wD/ABFUv+Gf/Cv/ADyh/wC/j/8AxFfFVOCcL9fnmFGtOE5/4ftf9unhvKOWfPCZ+Sfxc/a71z4k+AvEnhTb4dh0XxTrn/CRXNvp1hPH5d6ceZ5O+dwiSSASSJ/z0kk/56V+o37Ful3OjfsteB7O6hkgurPSLWCeF/8Alm6QR103/DP/AIV/55Q/9/H/APiK6nTNDs9GsI7a3kgSCP7ibH/+Ir6DKMphgYThCc58/wDMd2EwPsBaKm+zr/z8W/8A4/8A/EUfZ1/5+Lf/AMf/APiK9U7iGipvs6/8/Fv/AOP/APxFH2df+fi3/wDH/wD4igAuP9Ta/wDXH/2d6hqe6l83y41/eeWnl7/+elQUAfnP8T/+Sr+Mf+xh1T/0qnr374DS/wDFjfBn/YCsf/SdK8B+J/8AyVfxj/2MOqf+lU9e9fAaP/ixvgz/ALAVj/6TpX1VH4D5ej/En6nlf7Jf/Jzvgr/rtdf+kN3X3lX5z/C/x5N8KviRofiS3sI9SfR5nf7M8/2fzN8EkH39kn9+vdP+Hj2of9CPZ/8Ag9k/+Ra83MMPOc/cOzL8ZRow9nM+pKK+W/8Ah49qH/Qj2f8A4PZP/kWj/h49qH/Qj2f/AIPZP/kWuH6hW/kO7+0MN/OfUlFfLf8Aw8e1D/oR7P8A8Hsn/wAi0f8ADx7UP+hHs/8Aweyf/ItH1Ct/IH9oYb+c+pKK+W/+Hj2of9CPZ/8Ag9k/+RaP+Hj2of8AQj2f/g9k/wDkWj6hW/kD+0MN/OfUlFfLf/Dx7UP+hHs/B7J/wDItH/Dx7UP+hHs/wDweyf/ACLR9QrfyB/aGG/nPqSivlv/AIePah/0I9n/AOD2T/5Fo/4ePah/0I9n/wCD2T/5Fo+oVv5A/tDDfzn1JRXy3/w8e1D/AKEez/8AB7J/8i0f8PHtQ/6Eez/8Hsn/AMi0fUK38gf2hhv5z6kor5b/AOHj2of9CPZ/+D2T/wCRaP8Ah49qH/Qj2f8A4PZP/kWj6hW/kD+0MN/OfUlFfLf/AA8e1D/oR7P/AMHsn/yLR/w8e1D/AKEez/8AB7J/8i0fUK38gf2hhv5z6kor5b/4ePah/wBCPZ/+D2T/AORaP+Hj2of9CPZ/+D2T/wCRaPqFb+QP7Qw3859SUV8t/wDDx7UP+hHs/wDweyf/ACLR/wAPHtQ/6Eez/wDB7J/8i0fUK38gf2hhv5z6kor5b/4ePah/0I9n/wCD2T/5Fo/4ePah/wBCPZ/+D2T/AORaPqFb+QP7Qw3859SUV8t/8PHtQ/6Eez/8Hsn/AMi0f8PHtQ/6Eez/APB7J/8AItH1Ct/IH9oYb+c+pKK+W/8Ah49qH/Qj2f8A4PZP/kWj/h49qH/Qj2f/AIPZP/kWj6hW/kD+0MN/OfUlFfLf/Dx7UP8AoR7P/wAHsn/yLR/w8e1D/oR7P/weyf8AyLR9QrfyB/aGG/nPqSuZ+N3/ACRjxb/2Bb7/ANESV4D/AMPHtQ/6Eez/APB7J/8AItZPjf8Ab6v/ABl4L1jR/wDhDbO1/tSyntPO/t55PL3x+Xv/AOPWj6hW/kD+0MN/OfYGp/8AISuv+uz1DXy7df8ABSG/uriRv+EDs/3j+Z/yML/ACLTf+Hj2of9CPZ/+D2T/wCRaPqFb+QP7Qw3859SUV8t/wDDx7UP+hHs/wDweyf/ACLR/wAPHtQ/6Eez/wDB7J/8i0fUK38gfX8N/OfUlFfLf/Dx7UP+hHs/B7J/wDItH/Dx7UP+hHs/wDweyf/ACLT+o1v5A/tDDfzn1JRXy3/AMPHtQ/6Eez/APB7J/8AItH/AA8e1D/oR7P/AMHsn/yLS+oVv5A/tDDfzn1JRXy3/wAPHtQ/6Eez/wDB7J/8i0f8PHtQ/wChHs/AAeyf/ItH1Ct/IH9oYb+c+pKK+W/+Hj2of8AQj2f/g9k/wDkWj/h49qH/Qj2f/g9k/8AkWn9QrfyB9fw3854X8T/APkq/jH/ALGHVP8A0qnr374Df8kN8GfP/wAwKx/9J0r5v17WX8UeKNY1WWGO1k1jUbq/8lH8z7P588kmzf8Ax/fr6L+Ax/4sb4M/7AVj/wCk6V9HR+A8nDfFL1PmqiiiqPLCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvr79nezj/wCGf/AvyL/yL1h/6TR0UVmd2D3kf/Z" alt=""> </p><p> Note this shows the location of the main mailbox directory, which in our case is a mapped drive (S:) on our NAS Server.</p><p>You create "identities" under "Tools" "Identities".</p><p>You then add these identities to your User ID, and in that way you can manage multiple email incarnations with ease, even having different colours and fonts for each screen layout.</p><p>Hope this helps </p>
I have two different email accounts that I need to keep quite separate.
Can I simply install a second copy of pegasus (in a different folder of course), and use each one as needed? This is really a way of asking whether there are any resources that the program uses that are outside of the folder it's installed in. If not, then this should work.
Looking forward to some guidance on this.
thanks
longtime pegasus fan
<p>I have two different email accounts that I need to keep quite separate.</p><p>Can I simply install a second copy of pegasus (in a different folder of course), and use each one as needed? This is really a way of asking whether there are any resources that the program uses that are outside of the folder it's installed in. If not, then this should work.</p><p>Looking forward to some guidance on this.</p><p> </p><p>thanks</p><p>longtime pegasus fan </p>
You have the options of running an additional Identity within your current mailbox or creating an additional User with its own mailbox.
The Help files will assist you in the first instance.
See here also:
 http://community.pmail.com/forums/thread/20847.aspx
<p>You have the options of running an additional <u>Identity</u> within your current mailbox or creating an additional <u>User</u> with its own mailbox.</p><p>The Help files will assist you in the first instance. </p><p>See here also:</p><p> http://community.pmail.com/forums/thread/20847.aspx</p>
You can also run two instances without any problem.  I run three at the office, two from a multi-user network install and one from a USB stick.  Since you have one installation already I would create another user in that instance.  You then then create a second shortcut specifying that user in the command line with the -I option.  You can even run both at the same time provided the -MS option is in both command lines (Multi Session).  One thing you MUST be careful of is that you do not access the same mailbox simultaneously.  One other thing to be aware of is that when you have multiple instances running, a mailto link will trigger the instance that was started last.
BTW, yes you could install a second instance but there really is no need to.  A multi-user install is easier to maintain.  The config files and mail for each user resides in separate mailbox directories so there is no co-mingling.
Note: if your current installation is a single user install you will need to change it to multi-user so you can create the second user.  I have recently seen instructions on how to do that but do not remember where.  A search of this forum might turn them up.  If not, post back and I'll do some digging.
<p>You can also run two instances without any problem.  I run three at the office, two from a multi-user network install and one from a USB stick.  Since you have one installation already I would create another user in that instance.  You then then create a second shortcut specifying that user in the command line with the -I option.  You can even run both at the same time provided the -MS option is in both command lines (Multi Session).  One thing you MUST be careful of is that you do not access the same mailbox simultaneously.  One other thing to be aware of is that when you have multiple instances running, a mailto link will trigger the instance that was started last. </p><p>BTW, yes you could install a second instance but there really is no need to.  A multi-user install is easier to maintain.  The config files and mail for each user resides in separate mailbox directories so there is no co-mingling. </p><p>Note: if your current installation is a single user install you will need to change it to multi-user so you can create the second user.  I have recently seen instructions on how to do that but do not remember where.  A search of this forum might turn them up.  If not, post back and I'll do some digging. </p>
[quote user="Brian Fluet"]
 http://community.pmail.com/forums/thread/20190.aspx
[quote user="Brian Fluet"]<p>Note: if your current installation is a single user install you will need to change it to multi-user so you can create the second user.  I have recently seen instructions on how to do that but do not remember where.  A search of this forum might turn them up.  If not, post back and I'll do some digging. </p><p>[/quote]</p><p> http://community.pmail.com/forums/thread/20190.aspx </p>
