Hi guys,
Recently we experienced the above mentioned issue again. My users complain either about missing expected mails or get the Mercury "Send Delivery Status Notification" that their mails weren't sent since 1 h. This is the trigger to me to check Mercury at the server. And again, MercuryC (SMTP Client) is sending with reduced speed over port 587 and the mail queue is overcrowded. The TCP connection is still enabled and is sending, but with about 1 kB/s only. This could be checked by visiting the log folder of the SMTP client. Therein I can see a slowly increasing TCP-[date]-[time]-XX.MC log file.
Now the same procedure as every time: Quit Mercury, start Mercury, change to offline mode, change the user credentials for authentication purposes of MercuryC to another of our ISP mail user, leve the offline mode. Then Mercury resumes or restart the sending of all unsend mails within the queue with usual high speed again and the queue is done after a few minutes.
After that I went in contact with our ISP again (unfortunately the more or less success of such an support request depends on the skills of the current support guy which you get on the line). But what I discover again: With our booked standard hosting package (including our e-mail accounts) we could send up to 5000 mails per month, where one single mail must not contain more than 200 recipients (e.g. in cc). And we are far from it. Last month we've sent about 3600 mails to the internet. Nevertheless I asked him about the consequences when exceeding the lines. In that case they would completely refuse the receipt of further mails. They would never throttle down the receiving speed of their SMTP server.
Now I'm as smart as before. Could the issue be on Mercury side? Mostly these losts of SMTP transmission speed happend when Mercury is trying to directly forward an received mail. Many of my users have the FORWARD file in place and active. Due to this also a lot of mails with big attachments will be received, moved to local user mailboxes and simultaneously directly forwarded into the internet again to another address.
Further I experienced a frozen Mercury Core Process when MercuryC is catched in a slow SMTP sending process, means any internal local mails will also not being processed as long as MercuryC is not working properly.
Has anybody another clue for me what I could do or test to enclose the problem?
<p>Hi guys,</p><p>Recently we experienced the above mentioned issue again. My users complain either about missing expected mails or get the Mercury "Send Delivery Status Notification" that their mails weren't sent since 1 h. This is the trigger to me to check Mercury at the server. And again, MercuryC (SMTP Client) is sending with reduced speed over port 587 and the mail queue is overcrowded. The TCP connection is still enabled and is sending, but with about 1 kB/s only. This could be checked by visiting the log folder of the SMTP client. Therein I can see a slowly increasing TCP-[date]-[time]-XX.MC log file.</p><p>Now the same procedure as every time: Quit Mercury, start Mercury, change to offline mode, change the user credentials for authentication purposes of MercuryC to another of our ISP mail user, leve the offline mode. Then Mercury resumes or restart the sending of all unsend mails within the queue with usual high speed again and the queue is done after a few minutes.
</p><p>After that I went in contact with our ISP again (unfortunately the more or less success of such an support request depends on the skills of the current support guy which you get on the line). But what I discover again: With our booked standard hosting package (including our e-mail accounts) we could send up to 5000 mails per month, where one single mail must not contain more than 200 recipients (e.g. in cc). And we are far from it. Last month we've sent about 3600 mails to the internet. Nevertheless I asked him about the consequences when exceeding the lines. In that case they would completely refuse the receipt of further mails. They would never throttle down the receiving speed of their SMTP server.</p><p>Now I'm as smart as before. Could the issue be on Mercury side? Mostly these losts of SMTP transmission speed happend when Mercury is trying to directly forward an received mail. Many of my users have the FORWARD file in place and active. Due to this also a lot of mails with big attachments will be received, moved to local user mailboxes and simultaneously directly forwarded into the internet again to another address. </p><p>Further I experienced a frozen Mercury Core Process when MercuryC is catched in a slow SMTP sending process, means any internal local mails will also not being processed as long as MercuryC is not working properly.
</p><p>Has anybody another clue for me what I could do or test to enclose the problem?
