if 4.91 doesn't work for me can I revert to 4.8?
I see that 4.91 has been out for a while, does Mr. Harris send out notification emails? I'm a fairly frequent donator so my contact info is up to date.
If 4.91 doesn't work for me, can I go back to 4.8 or is this a one way trip?
I see that 4.91 has been out for a while, does Mr. Harris send out notification emails? I'm a fairly frequent donator so my contact info is up to date. If 4.91 doesn't work for me, can I go back to 4.8 or is this a one way trip? Thanks,
edited Nov 7 '25 at 8:06 pm
He does not send out notifications. He announces new versions as newsflashes on this site. Someone will then post it on the PM-Win listserv list.
Yes. Installing 4.81 as an upgrade over 4.91 will work although I am not aware of any show-stoppers in 4.91 that would result in the need to revert to 4.81.
[quote="pid:58205, uid:5513"]I see that 4.91 has been out for a while, does Mr. Harris send out notification emails? I'm a fairly frequent donator so my contact info is up to date.[/quote] He does not send out notifications. He announces new versions as newsflashes on this site. Someone will then post it on the PM-Win listserv list. [quote="pid:58205, uid:5513"] If 4.91 doesn't work for me, can I go back to 4.8 or is this a one way trip?[/quote] Yes. Installing 4.81 as an upgrade over 4.91 will work although I am not aware of any show-stoppers in 4.91 that would result in the need to revert to 4.81.
Thanks for that. I upgraded and my application window would not expand to the screen. I did see normal message windows for unsent drafts at normal size.
I poked around and looked at state.pmj and new mail under [folder] had a negative number right after the equals sign. So I removed the minus sign.
I ran into an issue where I thought W11 notepad saved the file w/o prompting but that was a change from W10 to W11. Actually it didn't save it, only remembering the changes. Once I set notepad to prompt to save on close, I got things working fine.
[quote="pid:58206, uid:28772"]Yes. Installing 4.81 as an upgrade over 4.91 will work although I am not aware of any show-stoppers in 4.91 that would result in the need to revert to 4.81.[/quote] Thanks for that. I upgraded and my application window would not expand to the screen. I did see normal message windows for unsent drafts at normal size. I poked around and looked at state.pmj and new mail under [folder] had a negative number right after the equals sign. So I removed the minus sign. I ran into an issue where I thought W11 notepad saved the file w/o prompting but that was a change from W10 to W11. Actually it didn't save it, only remembering the changes. Once I set notepad to prompt to save on close, I got things working fine.
edited Nov 8 '25 at 1:20 pm
Is 4.81 available for download?
Yes, here: https://www.pmail.com/betas.htm
It doesn't sound like you need it though. I'm glad you were able to resolve the offscreen window position.
[quote="pid:58208, uid:31393"]Is 4.81 available for download?[/quote] Yes, here: https://www.pmail.com/betas.htm It doesn't sound like you need it though. I'm glad you were able to resolve the offscreen window position.
