Thanks for that link, and your testing work.
The results page is certainly up to date.
What went wrong re:
Not sure what you mean about out of date, I've both tested and listed the problems with Pegasus Mail.
What happened was that I searched on google - scanned the 1st page and picked up a general vibe that info was out of date and that there were problems.
5th on the list was Wine HQ - Pegasus Mail 4.41
The version number didn't impact (maybe cos it was my version) but either way..... this was going to be the info I was looking for.
To be fair, the page looked very good - professional - tests from 2007 to 2009 plus a warning "The test results you have selected are very old and may not represent the current state of Wine."
The reason I point this out, is that, one of googles 'results display' criteria, is clicks on a result ie to visit the page.
This means that pretty much everybody searching using "wine pegasus mail" will end up reading these old test results - because if they were reading the latest results, then that doc would be on the 1st google results page, and higher than the old results doc.
Which means that people are not realising that other test results exist.
They see PM has problems in Wine, and interest has waned - no more tests after 2009 (ah well, it was worth a try), and then bugger off
I honestly believe that you should contact winehq, and request that they modify the warning by inserting, ahead of it, something like "latest test results available here" with a link to the PM folder .
Here is the google search: "wine pegasus mail"
9 posts - 4 authors - Last post: 31 Oct 2007
From here you can download
Pegasus Mail, download Mercury,
... I am able to open Pegasus via
Wine after the installation only the first time
...community.pmail.com/forums/thread/4565.aspx - Cached - Similar ►23 Feb 2009
... Then click OK, exit and restart
Pegasus Mail. Here are
...wiki.pmail.com/index.php?...Pegasus_Mail/...Pegasus_Mail... - Cached - Similar
So
the main thing still keeping me using windows was the fact that there's
a great piece of software, that does e-mail really well - its Pegasus Mail. ...
www.bytebot.net/geekdocs/pmail-wine.html - Cached - Similar
File:
Pegasus Mail Wine.png. Size of this preview: 800 × 579 pixels
... Pegasus Mail 4.52 running in
Wine 1.1.42 on Ubuntu Linux 10.04 - screenshot taken by
...en.wikipedia.org/wiki/File:Pegasus_Mail_Wine.png - CachedOpen Source Software for running Windows applications on other operating systems<wbr>.<br><span class="f"><cite><span class="bc">appdb.winehq.org › ... › <a href="http://www.google.com/url?url=http://appdb.winehq.org/objectManager.php%3FsClass%3Dcategory%26iId%3D35%26sAction%3Dview%26sTitle%3DBrowse%2BApplications&rct=j&sa=X&ei=IUwETsPBK8bO-Qa2y6m7DQ&ved=0CEEQ6QUoADAE&q=wine+pegasus+mail&usg=AFQjCNGNYqEspYnBxOFYSMl_0FVfHyr0qg">Email, news and Groupware</a> › <a href="http://www.google.com/url?url=http://appdb.winehq.org/objectManager.php%3FsClass%3Dapplication%26iId%3D284&rct=j&sa=X&ei=IUwETsPBK8bO-Qa2y6m7DQ&ved=0CEIQ6QUoATAE&q=wine+pegasus+mail&usg=AFQjCNHYgTZpXrT6OqTmtmCx55VtjmRKEA">Pegasus Mail</a></span></cite> - <span class="gl"><a href="http://webcache.googleusercontent.com/search?q=cache:lNqHl3KYr4kJ:appdb.winehq.org/objectManager.php%3FsClass%3Dversion%26iId%3D6462%26iTestingId%3D20595+wine+pegasus+mail&cd=5&hl=en&ct=clnk&client=ubuntu&source=www.google.com">Cached</a></span><span class="gl"></span></span></wbr>
14 Sep 2004
Wine]
Pegasus Mail sometimes says no HD-memory free, but
...www.winehq.org/pipermail/wine-users/2004.../015116.html - Cached
I had no luck with Pegasus and Wine (neither version 0.9.59, nor 0.9.61, nor 1.0 RC2). When I close a window (compose mail, for exemple), pegasus just ...
pmail.praktit.se/forums/1/15404/ShowThread.aspx
[PDF] File Format: PDF/Adobe Acrobat
Pegasus Mail under the
WINE emulator on a linux system). I occasionally see messages appearing in my new mail folder from “Unknown” with no sub-
...www.chm.tu-dresden.de/edv/manuals/pmail/pmail441.pdf - Similar 13 posts - 2 authors - Last post: 7 May
After much wrangling as to which way to go I relented and installed
Wine and
Pegasus Mail. I installed
Wine using the Synaptic package
...ubuntuforums.org › ... › Main Support Categories › General Help - CachedI used Pegasus Mail and wine and everything was ok. But after system reinstall (<wbr>mdk 9.2) I have some problem. I tried a few <em>wine</em> versions and <b>...</b><br><span class="f"><cite>www.mombu.com/.../<b>wine</b>.../t-<b>pegasus</b>-<b>mail</b>-and-<b>wine</b>-1577633.html</cite> - <span class="gl"><a href="http://webcache.googleusercontent.com/search?q=cache:OL2frGiE8zIJ:www.mombu.com/microsoft/wine-windows-emulator/t-pegasus-mail-and-wine-1577633.html+wine+pegasus+mail&cd=10&hl=en&ct=clnk&client=ubuntu&source=www.google.com">Cached</a></span></span></wbr>
<p>Thanks for that link, and your testing work.
The results page is certainly up to date.</p><p>What went wrong re:
</p><p>[quote user="Thomas R. Stephenson"]
</p><p>Not sure what you mean about out of date, I've both tested and listed the problems with Pegasus Mail.
[/quote]</p><p>&nbsp;What happened was that I searched on google - scanned the 1st page and picked up a general vibe that info was out of date and that there were problems.
5th on the list was Wine HQ - Pegasus Mail 4.41</p><p>The version number didn't impact (maybe cos it was my version) but either way..... this was going to be the info I was looking for.
To be fair, the page looked very good - professional - tests from 2007 to 2009 plus a warning "The test results you have selected are very old and may not represent the current state of Wine."</p><p>The reason I point this out, is that, one of googles 'results display' criteria, is clicks on a result ie to visit the page.</p><p>This means that pretty much <u>everybody</u> searching using "wine pegasus mail" will end up reading these old test results - because if they were reading the latest results, then that doc would be on the 1st google results page, and higher than the old results doc.</p><p>Which means that people are not realising that other test results exist.
They see PM has problems in Wine, and interest has waned - no more tests after 2009 (ah well, it was worth a try), and then bugger off</p><p>I honestly believe that you should contact winehq, and request that they modify the warning by inserting, ahead of it, something like "latest test results available here" with a link to the PM folder .</p><p>Here is the google search: "wine pegasus mail"</p><ol id="rso"><li class="g w0 knavi" style="margin-bottom: 8px; position: relative;"><div class="vsc"><span class="tl"><h3 class="r"><a href="http://community.pmail.com/forums/thread/4565.aspx" class="l noline"><em>Pegasus Mail</em> &amp; Mercury - Pegasus via <em>Wine</em></a></h3></span><div class="s"><div class="f">9 posts&nbsp;-&nbsp;4 authors&nbsp;-&nbsp;Last post:&nbsp;31 Oct 2007</div>From here you can download <em>Pegasus Mail</em>, download Mercury, <b>...</b> I am able to open Pegasus via <em>Wine</em> after the installation only the first time <b>...</b>
<span class="f"><cite>community.p<b>mail</b>.com/forums/thread/4565.aspx</cite> - <span class="gl"><a href="http://webcache.googleusercontent.com/search?q=cache:mN7C8XmCV9cJ:community.pmail.com/forums/thread/4565.aspx+wine+pegasus+mail&amp;cd=1&amp;hl=en&amp;ct=clnk&amp;client=ubuntu&amp;source=www.google.com">Cached</a> - </span><span class="gl"><a href="http://www.google.com/search?hl=en&amp;client=ubuntu&amp;hs=QRN&amp;channel=fs&amp;q=related:community.pmail.com/forums/thread/4565.aspx+wine+pegasus+mail&amp;tbo=1&amp;sa=X&amp;ei=IUwETsPBK8bO-Qa2y6m7DQ&amp;ved=0CCYQHzAA">Similar</a></span></span><div class="fc"><a href="http://community.pmail.com/forums/thread/28981.aspx">Pegasus 4.61 and <em>Wine</em> : no icons on toolbars</a>‎ - <span class="f">6 posts</span> - <span class="f">16 May 2011</span>
<a href="http://community.pmail.com/forums/thread/23300.aspx">Pmail under Linux/<em>wine</em>: SMTP proxy as <b>...</b></a>‎ - <span class="f">4 posts</span> - <span class="f">8 May 2010</span>
<a href="http://community.pmail.com/forums/thread/8987.aspx">Linux : <em>Wine</em> and pegasus beta</a>‎ - <span class="f">15 posts</span> - <span class="f">16 Oct 2008</span>
<a href="http://community.pmail.com/forums/thread/8988.aspx">Mailbox definition in Pegasus and <em>Wine</em>.</a>‎ - <span class="f">4 posts</span> - <span class="f">31 May 2008</span>
<p style="margin:.3em 0 0 0"><a href="http://www.google.com/search?hl=en&amp;client=ubuntu&amp;hs=QRN&amp;channel=fs&amp;q=+site:community.pmail.com+wine+pegasus+mail" class="fl">More results from community.pmail.com&nbsp;»</a></p></div></div></div><span style="padding-top: 0px;" title="Use the up and down arrow keys to select each result. Press Enter to go to the selection." id="knavm">►</span></li><li class="g w0 knavi" id="mbb2"><div class="vsc"><span class="tl"><h3 class="r"><a href="http://wiki.pmail.com/index.php?title=KB:Pegasus_Mail/Using_Pegasus_Mail_under_Linux" class="l">KB:<em>Pegasus Mail</em>/Using <em>Pegasus Mail</em> under Linux - WikiPmail</a></h3></span><div class="s">23 Feb 2009 <b>...</b> Then click OK, exit and restart <em>Pegasus Mail</em>. Here are <b>...</b>
<span class="f"><cite>wiki.p<b>mail</b>.com/index.php?...<b>Pegasus</b>_<b>Mail</b>/...<b>Pegasus</b>_<b>Mail</b>...</cite> - <span class="gl"><a href="http://webcache.googleusercontent.com/search?q=cache:lVb_6f2YdhIJ:wiki.pmail.com/index.php%3Ftitle%3DKB:Pegasus_Mail/Using_Pegasus_Mail_under_Linux+wine+pegasus+mail&amp;cd=2&amp;hl=en&amp;ct=clnk&amp;client=ubuntu&amp;source=www.google.com">Cached</a> - </span><span class="gl"><a href="http://www.google.com/search?hl=en&amp;client=ubuntu&amp;hs=QRN&amp;channel=fs&amp;q=related:wiki.pmail.com/index.php%3Ftitle%3DKB:Pegasus_Mail/Using_Pegasus_Mail_under_Linux+wine+pegasus+mail&amp;tbo=1&amp;sa=X&amp;ei=IUwETsPBK8bO-Qa2y6m7DQ&amp;ved=0CC0QHzAB">Similar</a></span></span></div></div><div class="mbl"><div class="bl"><span class="ch" id="mbl2" style="display:inline-block"><a href="http://www.google.com/search?client=ubuntu&amp;channel=fs&amp;q=wine+pegasus+mail&amp;ie=utf-8&amp;oe=utf-8#" class="mblink">Show more results from pmail.com</a></span></div></div><div style="padding-top: 0px;" id="mbf2"><span></span></div></li><li class="g w0 knavi"><div class="vsc"><span class="tl"><h3 class="r"><a href="http://www.bytebot.net/geekdocs/pmail-wine.html" class="l"><em>Pegasus Mail</em> on Linux (or an intro to <em>WINE</em>)</a></h3></span><div class="s">So
a great piece of software, that does e-mail really well - its <em>Pegasus Mail</em>. <b>...</b>
<span class="f"><cite>www.bytebot.net/geekdocs/p<b>mail</b>-<b>wine</b>.html</cite> - <span class="gl"><a href="http://webcache.googleusercontent.com/search?q=cache:RTJTxaX5KCAJ:www.bytebot.net/geekdocs/pmail-wine.html+wine+pegasus+mail&amp;cd=3&amp;hl=en&amp;ct=clnk&amp;client=ubuntu&amp;source=www.google.com">Cached</a> - </span><span class="gl"><a href="http://www.google.com/search?hl=en&amp;client=ubuntu&amp;hs=QRN&amp;channel=fs&amp;q=related:www.bytebot.net/geekdocs/pmail-wine.html+wine+pegasus+mail&amp;tbo=1&amp;sa=X&amp;ei=IUwETsPBK8bO-Qa2y6m7DQ&amp;ved=0CDUQHzAC">Similar</a></span></span></div></div></li><li class="g w0 knavi"><div class="vsc"><span class="tl"><h3 class="r"><a href="http://en.wikipedia.org/wiki/File:Pegasus_Mail_Wine.png" class="l">File:<em>Pegasus Mail Wine</em>.png - Wikipedia, the free encyclopedia</a></h3></span><div class="s">File:<em>Pegasus Mail Wine</em>.png. Size of this preview: 800 × 579 pixels <b>...</b> <em>Pegasus Mail</em> 4.52 running in <em>Wine</em> 1.1.42 on Ubuntu Linux 10.04 - screenshot taken by <b>...</b>
<span class="f"><cite>en.wikipedia.org/wiki/File:<b>Pegasus</b>_<b>Mail</b>_<b>Wine</b>.png</cite> - <span class="gl"><a href="http://webcache.googleusercontent.com/search?q=cache:narumwIo_ncJ:en.wikipedia.org/wiki/File:Pegasus_Mail_Wine.png+wine+pegasus+mail&amp;cd=4&amp;hl=en&amp;ct=clnk&amp;client=ubuntu&amp;source=www.google.com">Cached</a></span><span class="gl"></span></span></div></div></li><li class="g w0 knavi" style="margin-bottom:8px;"><div class="vsc"><span class="tl"><h3 class="r"><a href="http://appdb.winehq.org/objectManager.php?sClass=version&amp;iId=6462&amp;iTestingId=20595" class="l">WineHQ - <em>Pegasus Mail</em> 4.41</a></h3></span><div class="s">Open Source Software for running Windows applications on other operating systems<wbr>.
<span class="f"><cite><span class="bc">appdb.winehq.org › ... › <a href="http://www.google.com/url?url=http://appdb.winehq.org/objectManager.php%3FsClass%3Dcategory%26iId%3D35%26sAction%3Dview%26sTitle%3DBrowse%2BApplications&amp;rct=j&amp;sa=X&amp;ei=IUwETsPBK8bO-Qa2y6m7DQ&amp;ved=0CEEQ6QUoADAE&amp;q=wine+pegasus+mail&amp;usg=AFQjCNGNYqEspYnBxOFYSMl_0FVfHyr0qg">Email, news and Groupware</a> › <a href="http://www.google.com/url?url=http://appdb.winehq.org/objectManager.php%3FsClass%3Dapplication%26iId%3D284&amp;rct=j&amp;sa=X&amp;ei=IUwETsPBK8bO-Qa2y6m7DQ&amp;ved=0CEIQ6QUoATAE&amp;q=wine+pegasus+mail&amp;usg=AFQjCNHYgTZpXrT6OqTmtmCx55VtjmRKEA">Pegasus Mail</a></span></cite> - <span class="gl"><a href="http://webcache.googleusercontent.com/search?q=cache:lNqHl3KYr4kJ:appdb.winehq.org/objectManager.php%3FsClass%3Dversion%26iId%3D6462%26iTestingId%3D20595+wine+pegasus+mail&amp;cd=5&amp;hl=en&amp;ct=clnk&amp;client=ubuntu&amp;source=www.google.com">Cached</a></span><span class="gl"></span></span></div></div></li><li class="g w0 knavi" id="mbb6"><div class="vsc"><span class="tl"><h3 class="r"><a href="http://www.winehq.org/pipermail/wine-users/2004-September/015116.html" class="l">[<em>Wine</em>]<em>Pegasus Mail</em> sometimes says no HD-memory free, but that's <b>...</b></a></h3></span><div class="s">14 Sep 2004 <b>...</b> [<em>Wine</em>]<em>Pegasus Mail</em> sometimes says no HD-memory free, but <b>...</b>
<span class="f"><cite>www.<b>wine</b>hq.org/piper<b>mail</b>/<b>wine</b>-users/2004.../015116.html</cite> - <span class="gl"><a href="http://webcache.googleusercontent.com/search?q=cache:WDAJEFzg3fEJ:www.winehq.org/pipermail/wine-users/2004-September/015116.html+wine+pegasus+mail&amp;cd=6&amp;hl=en&amp;ct=clnk&amp;client=ubuntu&amp;source=www.google.com">Cached</a></span><span class="gl"></span></span><div class="fc"><a href="http://www.winehq.org/pipermail/wine-users/2011-March/087180.html">[<em>Wine</em>] e-sword and other serious applications via <em>wine</em></a>‎ - <span class="f">3 Mar 2011</span>
<a href="http://www.winehq.org/pipermail/wine-bugs/2010-July/239943.html">[Bug 14797] Setting up SSL Email access in <em>Pegasus Mail</em></a>‎ - <span class="f">18 Jul 2010</span>
<a href="http://www.winehq.org/pipermail/wine-bugs/2008-September/135904.html">[Bug 10213] <em>Pegasus Mail</em>: program closes when sub-program closes</a>‎ - <span class="f">28 Sep 2008</span>
<a href="http://www.winehq.org/pipermail/wine-users/2004-July/014367.html">[<em>Wine</em>]<em>Pegasus Mail</em> hangs during minimizing/maximizing of window</a>‎ - <span class="f">5 Jul 2004</span>
<p style="margin:.3em 0 0 0"><a href="http://www.google.com/search?hl=en&amp;client=ubuntu&amp;hs=QRN&amp;channel=fs&amp;q=+site:winehq.org+wine+pegasus+mail" class="fl">More results from winehq.org&nbsp;»</a></p></div></div></div><div class="mbl"><div class="bl"><span class="ch" id="mbl6" style="display:inline-block"><a href="http://www.google.com/search?client=ubuntu&amp;channel=fs&amp;q=wine+pegasus+mail&amp;ie=utf-8&amp;oe=utf-8#" class="mblink">Show more results from winehq.org</a></span></div></div><div style="padding-top: 0px;" id="mbf6"><span></span></div></li><li class="g w0 knavi"><div class="vsc"><span class="tl"><h3 class="r"><a href="http://pmail.praktit.se/forums/1/15404/ShowThread.aspx" class="l"><em>Pegasus Mail</em> &amp; Mercury - Linux : <em>Wine</em> and pegasus beta</a></h3></span><div class="s">I had no luck with <em>Pegasus</em> and <em>Wine</em> (neither version 0.9.59, nor 0.9.61, nor 1.0 RC2). When I close a window (compose <em>mail</em>, for exemple), <em>pegasus</em> just <b>...</b>
<span class="f"><cite>p<b>mail</b>.praktit.se/forums/1/15404/ShowThread.aspx</cite><span class="gl"></span></span></div></div></li><li class="g w0 knavi"><div class="vsc"><span class="b w xsm">[PDF]</span> <span class="tl"><h3 class="r"><a href="http://www.chm.tu-dresden.de/edv/manuals/pmail/pmail441.pdf" class="l"><em>Pegasus Mail</em> Manual.book</a></h3></span><div class="s"><span class="f">File Format:</span> PDF/Adobe Acrobat
<em>Pegasus Mail</em> under the <em>WINE</em> emulator on a linux system). I occasionally see messages appearing in my new mail folder from “Unknown” with no sub- <b>...</b>
<span class="f"><cite>www.chm.tu-dresden.de/edv/manuals/p<b>mail</b>/p<b>mail</b>441.pdf</cite> - <span class="gl"><a href="http://www.google.com/search?hl=en&amp;client=ubuntu&amp;hs=QRN&amp;channel=fs&amp;q=related:www.chm.tu-dresden.de/edv/manuals/pmail/pmail441.pdf+wine+pegasus+mail&amp;tbo=1&amp;sa=X&amp;ei=IUwETsPBK8bO-Qa2y6m7DQ&amp;ved=0CFwQHzAH">Similar</a></span></span></div></div></li><li class="g w0 knavi"><div class="vsc"><span class="tl"><h3 class="r"><a href="http://ubuntuforums.org/archive/index.php/t-1709335.html" class="l">[ubuntu] Looking for networked email client like <em>Pegasus mail</em> <b>...</b></a></h3></span><div class="s"><div class="f">13 posts&nbsp;-&nbsp;2 authors&nbsp;-&nbsp;Last post:&nbsp;7 May</div>After much wrangling as to which way to go I relented and installed <em>Wine</em> and <em>Pegasus Mail</em>. I installed <em>Wine</em> using the Synaptic package <b>...</b>
<span class="f"><cite><span class="bc">ubuntuforums.org › ... › <a href="http://www.google.com/url?url=http://ubuntuforums.org/archive/index.php/f-327.html&amp;rct=j&amp;sa=X&amp;ei=IUwETsPBK8bO-Qa2y6m7DQ&amp;ved=0CGQQ6QUoADAI&amp;q=wine+pegasus+mail&amp;usg=AFQjCNHRKWGGUZx7YJN_x_w6RHZPSlpEFQ">Main Support Categories</a> › <a href="http://www.google.com/url?url=http://ubuntuforums.org/archive/index.php/f-331.html&amp;rct=j&amp;sa=X&amp;ei=IUwETsPBK8bO-Qa2y6m7DQ&amp;ved=0CGUQ6QUoATAI&amp;q=wine+pegasus+mail&amp;usg=AFQjCNGwALOYGn4TP5gq0LVwk5NbZfDqiw">General Help</a></span></cite> - <span class="gl"><a href="http://webcache.googleusercontent.com/search?q=cache:Xd99cJFeEt4J:ubuntuforums.org/archive/index.php/t-1709335.html+wine+pegasus+mail&amp;cd=9&amp;hl=en&amp;ct=clnk&amp;client=ubuntu&amp;source=www.google.com">Cached</a></span><span class="gl"></span></span></div></div></li><li class="g w0 knavi"><div class="vsc"><span class="tl"><h3 class="r"><a href="http://www.mombu.com/microsoft/wine-windows-emulator/t-pegasus-mail-and-wine-1577633.html" class="l"><em>Pegasus Mail</em> and <em>wine</em> - Mombu the Microsoft Forum</a></h3></span><div class="s">I used <em>Pegasus Mail</em> and <em>wine</em> and everything was ok. But after system reinstall (<wbr>mdk 9.2) I have some problem. I tried a few <em>wine</em> versions and <b>...</b>
<span class="f"><cite>www.mombu.com/.../<b>wine</b>.../t-<b>pegasus</b>-<b>mail</b>-and-<b>wine</b>-1577633.html</cite> - <span class="gl"><a href="http://webcache.googleusercontent.com/search?q=cache:OL2frGiE8zIJ:www.mombu.com/microsoft/wine-windows-emulator/t-pegasus-mail-and-wine-1577633.html+wine+pegasus+mail&amp;cd=10&amp;hl=en&amp;ct=clnk&amp;client=ubuntu&amp;source=www.google.com">Cached</a></span></span></div></div></li></ol><p>&nbsp;</p>
