Add-ons for Mercury
Display Control Daemon for Mercury/32 v. 0.9.4
This is a small Daemon for Mercury/32 that disables the close button for the various module windows, and adds a Display control sub menu under Configuration. Hiding a window will not close it, only make it invisible. This should otherwise not affect the functionality of Mercury in any way.
When you need to access the dialog window for a module again just select it in the menu and it will reappear.This version of the Daemon is updated for Mercury 4.7x and 4.80.
DlgCtrl.zip
This is a small Daemon for Mercury/32 that disables the close button for the various module windows, and adds a Display control sub menu under Configuration. Hiding a window will not close it, only make it invisible. This should otherwise not affect the functionality of Mercury in any way. When you need to access the dialog window for a module again just select it in the menu and it will reappear.This version of the Daemon is updated for Mercury 4.7x and 4.80. [DlgCtrl.zip](serve/attachment&path=60fa17fa3094c)
edited Jul 23 '21 at 2:16 am
