To Brian Fluet:
Thanks, the thread you sent me looked very similar to my problem. So I tried to follow your instructions and found the following:
1.- I could not find a PMAIL.INI file. in the main PMAIL directory
2.- So I looked at C;\PMAIL\MAIL\ADMIN and found PMAILINI.OLD
3.- I opened it with WordPad and found
Application Window Rectangle = -1615 188 1189 852
I assumed that the pairs of numbers correspond to the Surface Pro-3 Screen and the other to an external 28" monitor. I assumed the first number should NOT be negative so I changed it to 1615. Is that OK?
Then I tried to open Pegasus Mail but still it does not work well.
Then I realized that perhaps my problem is not identical to the other fellow's problem. My PMAIL starts OK in the sense that a window opens ("Autosaved messages found'), with a RED exclamation mark in the blue rectangle with the horse asks if I want to open saved messages or continue, I click "continue" and get the "Autosaved messages found" again but with an additional note : (Not Responding) and the rest of text become bold, a YELLOW exclamation mark appears under the Pegasus horse logo and when I click on "Continue" , the circle clock appears and finally the window closes and the Pegasus main windows does not appear. But an icon in the task bar shows that it has opened...
In the last two trials, I got no additional icon in the task bar.
Another thing I notice is that when I look into the properties of the Shortcut icon, the "start in" space is empty. Is this OK?
<p>To Brian Fluet:</p><p>Thanks, the thread you sent me looked very similar to my problem. So I tried to follow your instructions and found the following:</p><p>1.- I could not find a PMAIL.INI &nbsp;file. in the main PMAIL directory &nbsp;</p><p>2.- So I looked at C;\PMAIL\MAIL\ADMIN &nbsp;and found &nbsp;PMAILINI.OLD</p><p>3.- I opened it with WordPad and found &nbsp; &nbsp;</p><p>&nbsp; &nbsp; Application Window Rectangle &nbsp;= &nbsp;-1615 &nbsp; 188 &nbsp; 1189 &nbsp; 852</p><p>&nbsp; I assumed that the pairs of numbers correspond to the Surface Pro-3 Screen and the other to an external 28" monitor. I assumed the first number should NOT be negative so I changed it to &nbsp;1615. &nbsp;Is that OK?</p><p>Then I tried to open Pegasus Mail but still it does not work well.</p><p>Then I realized that perhaps my problem is not identical &nbsp;to the other fellow's problem. My PMAIL starts OK in the sense that a window opens ("Autosaved messages found'), with a RED exclamation mark in the blue rectangle with the horse asks if I want to open saved messages or continue, I click "continue" and get the "Autosaved messages found" again but with an additional note : &nbsp;(Not Responding) &nbsp;and the rest of text become bold, a YELLOW exclamation mark appears under the Pegasus horse logo and when I click on "Continue" , the circle clock appears and finally the window closes and the Pegasus main windows does not appear. But an icon in the task bar shows that it has opened...&nbsp;</p><p>In the last two trials, I &nbsp;got no additional icon in the task bar.</p><p>Another thing I notice is that when I look into the properties of the Shortcut icon, the "start in" space is empty. Is this OK?&nbsp;</p>
