[quote user="brainstuff"]
I am testing Pegasus Mail with a test account.and had some beginner problems. I would like if the developpers will take note that users from outlook or thunderbird will have at the beginning some trubles.
1) since the automatic configuration I had a warning message ... pegasus says that it will not accept usernames = email addresses (=username with the @ sign in it) but this does not create any problem.
2) I do not find the folder where Pegasus stores mails who was not send ... [/quote]
Pegasus Mail can configured to immediately send messages of to queue them for sending. If you queue them for sending you can access the queue by going to File > Review queued mail.
[quote user="brainstuff"]3) as a (ex) outlook and thunderbird user I am seeking for the "accounts" to add a second account ... I think I have fund this in tools internetsettings ... but I do not understand the way used by pegasus to link the outgoing SMTP account with the POP3 account.(in my settings the accounts have 2 different names.[/quote]
There are two concepts in Pegasus Mail with which you may want to familiarize yourself with. One is "users" the other is "identities". Configuring Pegasus Mail for multiple users creates a mailbox for each user which keeps the mail activity separate. Under normal muli-user utsage, each user would run their own session of Pegasus Mail accessing their own Pegasus Mail mailbox and configuration settings. "Identities" allow you to retrieve mail from multiple hosted mailboxes into one Pegasus Mail mailbox. Each can be configured so you appear to be that person (if you had a gmail & an yahoo account you could configure it such that messages and replies come from the appropriate email address). Most configuration settings are unique to each identity so configuration of each identity must be done while working as the identity you wish to configure. Each POP and SMTP host can be used by multiple identities so part of identify configuration includes adding the hosts you wish to use for that identity.
[quote user="brainstuff"]Probably Pegasus Mail will not solve a very stupid problem, what I have with our Web-Server! The server staff has developped a very stupid idea to avoid "spoofing" .. It is not possible to send witht thunderbird mails from xxxx@yyyy.com with the SMTP account of zzzz@yyy.com and it seems that Pegasus can aso not do this;
00:30:46.325: >> 235 Authentication succeeded
00:30:46.325: << MAIL FROM:<test@xxx.com> SIZE=465
00:30:46.459: >> 250 OK
00:30:46.459: << RCPT TO:<xxxxx@zzzzz.com>
00:30:46.926: >> 250 Accepted
00:30:46.926: << DATA
00:30:47.075: >> 354 Enter message, ending with "." on a line by itself
00:30:48.640: >> 550-Your FROM address ( test@xxx.com , test@xxx.com )must match your
00:30:48.641: >> 550-authenticated email user (test-out@xxx.com).Treating this as a spoofed
00:30:48.642: >> 550 email.
(I have set the settings in Pegasus on the pop3 server to the account text@xxx.com and on the SMTP Server to an other (existing account) (login to the SMTP Server using the following details: test-out@xxx.com and then the related password) but it seems that our stupid server will not accept this). [/quote]
This type of restriction is not uncommon. It prevents use of the SMTP server by anyone with a From address that is not of the authorized domain. Unfortunately this prevents xxxx@yyyy.com from sending if only the yyy.com domain is allowed even if xxxx@yyyy.com has the proper SMTP credentials.
[quote user="brainstuff"]<p>Hi,</p><p>I am testing Pegasus Mail with a test account.and had some beginner problems. I would like if the developpers will take note that users from outlook or thunderbird will have at the beginning some trubles.&nbsp;</p><p>1) since the automatic configuration I had a warning message ... pegasus says that it will not accept usernames = email addresses (=username with the @ sign in it) but this does not create any problem.&nbsp;</p><p>2) I do not find the folder where Pegasus stores mails who was not send ... [/quote]</p><p>Pegasus Mail can configured to immediately send messages of to queue them for sending.&nbsp; If you queue them for sending you can access the queue by going to File &gt; Review queued mail.
</p><p>[quote user="brainstuff"]3) as a (ex) outlook and thunderbird user I am seeking for the "accounts" to add a second account ... I think I have fund this in tools internetsettings ... but I do not understand the way used by pegasus to link the outgoing SMTP account with the POP3 account.(in my settings the accounts have 2 different names.[/quote]</p><p>There are two concepts in Pegasus Mail with which you may want to familiarize yourself with.&nbsp; One is "users" the other is "identities".&nbsp; Configuring Pegasus Mail for multiple users creates a mailbox for each user which keeps the mail activity separate.&nbsp; Under normal muli-user utsage, each user would run their own session of Pegasus Mail accessing their own Pegasus Mail mailbox and configuration settings.&nbsp; "Identities" allow you to retrieve mail from multiple hosted mailboxes into one Pegasus Mail mailbox.&nbsp; Each can be configured so you appear to be that person (if you had a gmail &amp; an yahoo account you could configure it such that messages and replies come from the appropriate email address).&nbsp; Most configuration settings are unique to each identity so configuration of each identity must be done while working as the identity you wish to configure.&nbsp; Each POP and SMTP host can be used by multiple identities so part of identify configuration includes adding the hosts you wish to use for that identity.
</p><p>[quote user="brainstuff"]Probably Pegasus Mail will not solve a very stupid problem, what I have with our Web-Server! The server staff has developped a very stupid idea to avoid "spoofing" ..&nbsp; It is not possible to send witht thunderbird mails from xxxx@yyyy.com with the SMTP account of zzzz@yyy.com &nbsp; and it seems that Pegasus can aso not do this;</p><p>00:30:46.325: &gt;&gt; 235 Authentication succeeded
00:30:46.325: &lt;&lt; MAIL FROM:&lt;test@xxx.com&gt; SIZE=465
00:30:46.459: &gt;&gt; 250 OK
00:30:46.459: &lt;&lt; RCPT TO:&lt;xxxxx@zzzzz.com&gt;
00:30:46.926: &gt;&gt; 250 Accepted
00:30:46.926: &lt;&lt; DATA
00:30:47.075: &gt;&gt; 354 Enter message, ending with "." on a line by itself
00:30:48.640: &gt;&gt; 550-Your FROM address ( test@xxx.com , test@xxx.com )must match your
00:30:48.641: &gt;&gt; 550-authenticated email user (test-out@xxx.com).<b>Treating this as a spoofed</b>
00:30:48.642: &gt;&gt; 550 email.&nbsp;&nbsp;
</p><p>(I have set the settings in Pegasus on the pop3 server to the account text@xxx.com and on the SMTP Server to an other (existing account) (login to the SMTP Server using the following details: test-out@xxx.com and then the related password) but it seems that our stupid server will not accept this). [/quote]</p><p>This type of restriction is not uncommon.&nbsp; It prevents use of the SMTP server by anyone with a From address that is not of the authorized domain.&nbsp; Unfortunately this prevents xxxx@yyyy.com from sending if only the yyy.com domain is allowed even if xxxx@yyyy.com has the proper SMTP credentials.
