[quote user="StanH"]
Q - Are these startup times unusual?
Startup time desktop: 2 sec
Startup time laptop: 50 sec
(15sec to display Pegasus)
(25 more sec to begin folder window -- this is reduced to 10 sec by not using the mapped drive approach.)
(10 more sec to display newmail list)
Too long. There are two known issues that impact Pegasus Mail performance:
1. Printer driver - which you have addressed
2. Winsock - In Tools > Options > General settings > Advanced settings ensure that the "Load Windows Internet Services" option is set to "Always"
There was a second question in my email notice from the forum that has not appeared here which was:
[quote user="StanH"]Q2 - What settings control startup configuration: Like start with [Mail
folders..] closed, and when opened, have My Mailbox selected, or make My
Mailbox and Gmail open together?[/quote]
Tools > Options > General settings > Basic settings > Save the Pegasus Mail desktop state between sessions. Read the help files for details about what this saves.
Most configuration settings, including this one, are mailbox specific so keep in mind that you are accessing the Admin mailbox from two machines so changes made on one machine will be reflected on the other machine. You can enable the "Save desktop state" option, configure things as you like, close Pegasus Mail to save, then reopen and disable that setting so things don't get altered but that setting must be disabled on both machines. Also, there is a method of using a different .ini file by each machine but it doesn't offer much in the way of control (different main window sizes & specifying a different temp directory are the only ones that come to mind).
<p>[quote user="StanH"]
[/quote]</p><p>Too long.&nbsp; There are two known issues that impact Pegasus Mail performance:</p><p>1. Printer driver - which you have addressed</p><p>2. Winsock - In Tools &gt; Options &gt; General settings &gt; Advanced settings&nbsp; ensure that the "Load Windows Internet Services" option is set to "Always"</p><p>&nbsp;</p><p>There was a second question in my email notice from the forum that has not appeared here which was:
</p><p>[quote user="StanH"]Q2 - What settings control startup configuration: Like start with [Mail
Mailbox and Gmail open together?[/quote] </p><p>Tools &gt; Options &gt; General settings &gt; Basic settings &gt; Save the Pegasus Mail desktop state between sessions.&nbsp; Read the help files for details about what this saves.&nbsp; </p><p>Most configuration settings, including this one, are mailbox specific so keep in mind that you are accessing the Admin mailbox from two machines so changes made on one machine will be reflected on the other machine.&nbsp; You can enable the "Save desktop state" option, configure things as you like, close Pegasus Mail to save, then reopen and disable that setting so things don't get altered but that setting must be disabled on both machines.&nbsp; Also, there is a method of using a different .ini file by each machine but it doesn't offer much in the way of control (different main window sizes &amp; specifying a different temp directory are the only ones that come to mind).&nbsp;
</p><p>&nbsp;</p>
