MercuryE - connection error during handshake with 212.227.15.9
Thanks a lot for the tip...
I will also have to work arround with SPF's for other vhosts on this testing server, before installing on the production server...
One more time thanks a lot.....
With the best regards of Aquiles Crespo
<p>Thanks a lot for the tip...</p><p>I will also have to work arround with SPF's for other vhosts on this testing server, before installing on the production server... </p><p>One more time thanks a lot..... </p><p>With the best regards of Aquiles Crespo </p>
Hello ....
i am configuring a send mail in a webhost test server of the company were i am making my education
in this configuration i use the MercuryS and MercuryE and the mail problem is when i try to send a mail to the GMX servers somehow i get :
"connection error during handshake with 212.227.15.9"
"connection error during handshake with 212.227.15.5"
everytime i try to gmx.de.
when i send to GMAIL, HOTMAIL, OUTLOOK etc etc , the mail is sended without errors. so i think that everything is configured correctly. Or am i missing something?
here is a copy of mine .ini from mercury.
<p>Hello .... </p><p>i am configuring a send mail in a webhost test server of the company were i am making my education  </p><p>in this configuration i use the MercuryS and MercuryE and <span style="font-size: 10pt;">the mail problem is when i try to send a mail to the GMX servers somehow i get :</span></p><p>"connection error during handshake with 212.227.15.9"</p><p>"connection error during handshake with 212.227.15.5"</p><p>everytime i try to gmx.de.</p><p>when i send to GMAIL, HOTMAIL, OUTLOOK etc etc , the mail is sended without errors. so i think that everything is configured correctly. Or am i missing something?</p><p><span style="font-size: 10pt;">here is a copy of mine .ini from mercury.</span></p><p><span style="font-size: 10pt;"> </span></p>
Yes actually, my first conf was without ssl and everything was working except sending for gmx also... So after I tryed to activate the ssl because I thought that could be the problem...
I am in the school now. So Later when I am back in the house I can post more error info with the session logs... There was giving some more info, and I think there us maybe missing the ptr ... I am not sure. .
<p>Yes actually, my first conf was without ssl and everything was working except sending for gmx also... So after I tryed to activate the ssl because I thought that could be the problem...</p><p>I am in the school now. So Later when I am back in the house I can post more error info with the session logs... There was giving some more info, and I think there us maybe missing the ptr ... I am not sure. .</p>
ok... here are my last log sessions.... this one is from sending to GMX
and this one to google... Sorry to send in separeted posts but i could not send the 2 attachements together
This is probably the reason: "554 invalid DNS PTR resource record, IP=81.209.184.2"
They are doing a reverse DNS lookup on the IP address and based on the result they refuse the connection. Try asking your ISP to add a PTR record to solve it!
<p>This is probably the reason: "<span style="font-size: 10pt; white-space: pre-wrap;">554 invalid DNS PTR resource record, IP=81.209.184.2"</span></p><p>They are doing a reverse DNS lookup on the IP address and based on the result they refuse the connection. Try asking your ISP to add a PTR record to solve it!</p>
