Thanks for the reply. That was exactly the problem. The split bar was at the top of the pane. I pulled it down and its all ok now.
Thanks again.
<p>Thanks for the reply. That was exactly the problem. The split bar was at the top of the pane. I pulled it down and its all ok now.</p><p>Thanks again.
