I have used Pegasus close to 30 years sending 3 dozen emails daily, and benefited greatly for this forum for many different problems.
This is my first time that I can't find a solution on your forum for a Pegasus problem.
After changing POP3 and STMP settings following a change in ISP, the copy to self stopped working even as sending or receiving messages worked.
Thanks to a post by regner on 2011-01-23, I was able to fix the copy to self problem by removing autofilter on three folders. Now the copy to self works fine, but the messages themselves do not go out. They enter the queue; get "Final form" if I click on "Send now"; the status bar shows "Connect to " and "Message sent", but the messages do not really go out and stay in the queue. I tried different things such as having messages sent immediately without being in queue, but the result is the same.
I upgraded to Pegasus 4.7 from 4.6 with no improvement. My Pegasus runs on Windows 7.
Please help.
John Petroff
<p>Hi,</p><p>I have used Pegasus close to 30 years sending 3 dozen emails daily, and benefited greatly for this forum for many different problems.&nbsp;</p><p>&nbsp;This is my first time that I can't find a solution on your forum for a Pegasus problem.</p><p>After changing POP3 and STMP settings following a change in ISP, the copy to self stopped working even as sending or receiving messages worked.</p><p>Thanks to a post by regner on 2011-01-23, I was able to fix the copy to self problem by removing autofilter on three folders. Now the copy to self works fine, but the messages themselves do not go out. They enter the queue; get "Final form" if I click on "Send now"; the status bar shows "Connect to " and "Message sent", but the messages do not really go out and stay in the queue. I tried different things such as having messages sent immediately without being in queue, but the result is the same. &nbsp; </p><p>I upgraded to Pegasus 4.7 from 4.6 with no improvement. My Pegasus runs on Windows 7.</p><p>Please help.</p><p>John Petroff
