I don't have a Win10 machine here to look at but I recall some control of sound in Settings > Notifications & actions but don't recall whether this controls notification sounds only or whether the delete sound is considered "notification" sound.
I checked my Win7 machine and find the delete sound to be the system sound associated with an Exclamation event. You should be able to confirm whether it's the same on your machine and have the option of assigning a different sound file. I don't know of a way to turn it off from within Pegasus Mail.
<p>I don't have a Win10 machine here to look at but I recall some control of sound in Settings &gt; Notifications &amp; actions but don't recall whether this controls notification sounds only or whether the delete sound is considered "notification" sound.&nbsp;</p><p> I checked my Win7 machine and find the delete sound to be the system sound associated with an Exclamation event.&nbsp; You should be able to confirm whether it's the same on your machine and have the option of assigning a different sound file.&nbsp; I don't know of a way to turn it off from within Pegasus Mail.
