Hello Thomas,
using LDAP synony doesn't mean to implement LDAP on your Server. David calld it (I think so) that way, because the attribute was introduced with the LDAP Support of NDS. Pmail / Mercury use native NDS call to access that attributes. My tests also show, that both programs use the same Attribute: Internet EMAil Address in NDS Schema, which is mapped to the LDAP interface of NDS to the Ldap Attribute mail.
I recommend to either not load NLDAP.NLM if you don't use it (no Imanager, no Ldap contextless Login, no ....) or to configure your Firewall (FILTCFG.NLM) to not allow Ldap from outside. The last is what I do.
Klaus
<P>Hello Thomas,</P>
<P>&nbsp;using LDAP synony doesn't mean to implement LDAP on&nbsp;your Server. David calld it (I think so)&nbsp;that way, because the attribute was introduced with the LDAP Support of NDS. Pmail / Mercury use native NDS call to access that attributes. My tests also show, that both programs use the same Attribute: Internet EMAil Address in NDS Schema, which is mapped to the LDAP interface of NDS to the Ldap Attribute mail. </P>
<P>I recommend to either not load NLDAP.NLM if you don't use it (no Imanager, no Ldap contextless Login, no ....) or to configure your Firewall (FILTCFG.NLM) to not allow Ldap from outside. The last is what I do.</P>
<P>&nbsp;Klaus</P>
