[quote user="Greenman"][quote user="David Obdrzalek"]Also, it would be nice to have an option to delete some attachments from received messages.
You can do this, but the message needs to be in your new mail folder. When the message is in the new mail folder it is transformed into a single file (a .cnm). Open the Attachments tab, highlight the attachment and click the Delete button.
When the message is in a folder, it is merged with all the other messages in that folder, which is actually a file (a .pmm). You then lose the ability to remove attachments. So, just move the message(s) into your new mail folder to delete attachments from those messages.
What??? Miracle!!! I'm using Pegasus for decades but didn't know.
I
typically want to do it when the message is in my Inbox folder but I mean
inbox at the server (IMAP connected). I simply ignored that button,
maybe I realized it does not work ages ago and my brain wipes it off.
But it makes sense it works when the file is in my local inbox as .CNM file only, it is the easiest to do it there (as I foggily remember the IMPA/POP3 protocols, it is not possible to do it on the server, and when the file is stored in a local folder, then it would create a gap which could be compacted similarly as deleted messages, but that would require extra handling in addition to whole email deletions - so no wonder attachment deletions do not work there either).
Thanks for your guru hint!
[quote user="Greenman"][quote user="David Obdrzalek"]Also, it would be nice to have an option to delete some attachments from <i>received</i> messages.
<p>[/quote]</p><p>You can do this, but the message needs to be in your new mail folder. When the message is in the new mail folder it is transformed into a single file (a .cnm). Open the Attachments tab, highlight the attachment and click the Delete button.</p><p>When the message is in a folder, it is merged with all the other messages in that folder, which is actually a file (a .pmm). You then lose the ability to remove attachments. So, just move the message(s) into your new mail folder to delete attachments from those messages.&nbsp;</p><p>[/quote]</p><p>What??? Miracle!!! I'm using Pegasus for decades but didn't know. </p><p>&nbsp;</p><p>I
maybe I realized it does not work ages ago and my brain wipes it off.</p><p>But it makes sense it works when the file is in my local inbox as .CNM file only, it is the easiest to do it there (as I foggily remember the IMPA/POP3 protocols, it is not possible to do it on the server, and when the file is stored in a local folder, then it would create a gap which could be compacted similarly as deleted messages, but that would require extra handling in addition to whole email deletions - so no wonder attachment deletions do not work there either).</p><p>Thanks for your guru hint!
