Can not send messages after upgrading machine from dialup to ethernet connection
Alright - that's fixed. I called Earthlink tech support. Great that they answer phones on Sunday and were willing to dig in a bit. They took over my machine remotely. Tech had never heard of Pegasus but it was all in the settings for Sending Mail, including some Security settings.
Weirdest thing just happened - Pegagus said it had to close and would send an error report. I get back in, continuing to delete old mgs, etc, was going to look at the settings to mention here, and they are gone.
But it still works.
<p>Alright - that's fixed. I called Earthlink tech support. Great that they answer phones on Sunday and were willing to dig in a bit. They took over my machine remotely. Tech had never heard of Pegasus but it was all in the settings for Sending Mail, including some Security settings.</p><p>Weirdest thing just happened - Pegagus said it had to close and would send an error report. I get back in, continuing to delete old mgs, etc, was going to look at the settings to mention here, and they are gone.</p><p>But it still works. </p>
testing new install of Peg on new machine.
I have been using Peg 4.21 on an old WIN98 machine with a dialup modem - worked fine for many years.
But now I have moved to a faster internet as a first step in getting rid on landline.
I have installed new Peg 4.73 on a newer machine with XP.
Connecting to internet OK with ethernet cable plugged into new modem/router.
I have another machine also plugged in and working fine, but do not use email there.
After struggling to move old mail over to new Peg install, I try to send a test msg and get this -
SMTP Send Mail Error - you do not have an active SMPT definition....
I went there and entered by SMTP address - mail.earthlink.net
also ran the setup wizard - still does not work (Firefox is working)
<p>testing new install of Peg on new machine.</p><p>I have been using Peg 4.21 on an old WIN98 machine with a dialup modem - worked fine for many years.</p><p>But now I have moved to a faster internet as a first step in getting rid on landline.</p><p>I have installed new Peg 4.73 on a newer machine with XP.</p><p>Connecting to internet OK with ethernet cable plugged into new modem/router.</p><p>I have another machine also plugged in and working fine, but do not use email there.</p><p>After struggling to move old mail over to new Peg install, I try to send a test msg and get this -</p><p>SMTP Send Mail Error - you do not have an active SMPT definition....</p><p>I went there and entered by SMTP address - mail.earthlink.net</p><p>also ran the setup wizard - still does not work (Firefox is working) </p><p> </p><p> </p><p> </p>
