Did you (or some other software) change the default printer?
The program has recently introduced a delay of several seconds when I tell it to begin a new message or reply to one. I don't notice slowness in other programs. I'm running Pegasus v4.7 under Winodws 10. Does anyone else have this problem?
Yes. Free disk space is 254 GB. Here is what Task Manager reports about Memory:
Other programs are running without delays. The slowness in Pegasus began a week or so ago. It is most noticeable when beginning a new message and after the command to send all messages in the queue.
How many messages are sending at once? Have you kept Task Manager open on the Performance tab and monitored system resources when you do this?
Are you using 4.73? http://www.pmail.com/downloads_s3_t.htm
