After some tests, let me clarify a few things.
The message is viewed properly on the email server's Web Mail viewed under both Firefox and IE11. When I extract the raw format and save it to a .EML file, it is properly rendered under Thunderbird and Windows Live Mail.
When I view that message in P-Mail, it is rendered with that malformity. When I tell P-Mail to view the message in Firefox and IE11 it is rendered with that malformity.
I resent email to Martin. In it I sent the RAW Format extracted from the Web Mail server in TXT and EML format also the the RAW Format extracted from P-Mail also in .TXT and EML Format,
One malformed and one that isn't to see what P-Mail is doing to that email.
Now in theory the RAW Format extracted from the web server and the RAW format extracted from P-Mail should be the same. But they are different. I attached them in a ZIP file. And when you see the four files ( 2 x TXT and 2 x EML ) listed in WinZIP it shows that the file size and CRC is different meaning there is a difference between the RAW formats extracted from the web server vs. the RAW format extracted from P-Mail.
<p>After some tests, let me clarify a few things.</p><p>The message is viewed properly on the email server's Web Mail viewed under both Firefox and IE11.&nbsp; When I extract the raw format and save it to a .EML file, it is properly rendered under Thunderbird and Windows Live Mail.</p><p>When I view that message in P-Mail, it is rendered with that malformity.&nbsp; When I tell P-Mail to view the message in Firefox and IE11 it is rendered with that malformity.</p><p>&nbsp;</p><p>I resent email to Martin.&nbsp; In it I sent the RAW Format extracted from the Web Mail server&nbsp; in TXT and EML format also the the RAW Format extracted from P-Mail also in .TXT and EML Format,&nbsp;
</p><p>One malformed and one that isn't to see what P-Mail is doing to that email.
Now in theory the RAW Format extracted from the web server and the RAW format extracted from P-Mail should be the same.&nbsp; But they are different.&nbsp; I attached them in a ZIP file. And when you see the four files ( 2 x TXT and 2 x EML ) listed in WinZIP it shows that the file size and CRC is different meaning there is a difference between the RAW formats extracted from the web server vs. the RAW format extracted from P-Mail.
</p><p>&nbsp;</p>
