Pegasus is minimized on taskbar, but is not possible maximize
Hi
I solved it. Problem was in file  PMAIL.INI
There was
Application window rectangle              = -32000 -32000 160 39
in old backuped file was
Application window rectangle              = -8 -8 1936 1056
But I do not know how it happened
Thank you
<p>Hi</p><p>I solved it. Problem was in file  PMAIL.INI</p><p>There was</p><p>Application window rectangle              = -32000 -32000 160 39 </p><p>in old backuped file was</p><p>Application window rectangle              = -8 -8 1936 1056</p><p>But I do not know how it happened </p><p>Thank you </p>
I have Windows 10
Pagasus last version
I worked with Pegasus without problems. Then I leave computer. It lock screen. After I log to windows again, Pegasus was   minimized on taskbar.
It is not possible  maximize it. Restart computer does not help.
I start Pegasus again. I see splashscreen with pegasus horse, Starting up, please wait..
Then splas go to minimize to task bar.
<p>I have Windows 10</p><p>Pagasus last version</p><p>I worked with Pegasus without problems. Then I leave computer. It lock screen. After I log to windows again, Pegasus was   minimized on taskbar.</p><p>It is not possible  maximize it. Restart computer does not help.</p><p>I start Pegasus again. I see splashscreen with pegasus horse, Starting up, please wait..</p><p>Then splas go to minimize to task bar. </p><p>Martin </p>
The Pegasus Mail main window may be open offscreen.  With Pegasus Mail running, close all other windows then right click on the taskbar and select "Cascade windows" to see if that brings it into view.
Hi
It does not help. Nothing happends.
Have I reinstall  Pmail? Will not delete my old emails?
<p>Hi</p><p>It does not help. Nothing happends.</p><p>Have I reinstall  Pmail? Will not delete my old emails? </p><p>Martin </p>
