help on lgin
Brian,
thank you very much for the support. Pmail is running like it dit before,
thanks again
Niek
<p>Brian,</p><p>thank you very much for the support. Pmail is running like it dit before, </p><p>thanks again</p><p>Niek </p>
Hello there,
I had my password on P-mail changed at my provider internlnet.
I use pegasus email program  for some 20 years now. Always very pleased working with p-mail.
Login on the webmail: no problem, However retrieving email from the server to my PC pegasus applicatieon gives the following error:
<!--[if gte mso 9]><xml> </p><p> <o:OfficeDocumentSettings> </p><p> <o:AllowPNG/> </p><p> </o:OfficeDocumentSettings> </p><p></xml><![endif]--><!--[if gte mso 9]><xml> </p><p> <w:WordDocument> </p><p> <w:View>Normal</w:View> </p><p> <w:Zoom>0</w:Zoom> </p><p> <w:TrackMoves/> </p><p> <w:TrackFormatting/> </p><p> <w:HyphenationZone>21</w:HyphenationZone> </p><p> <w:PunctuationKerning/> </p><p> <w:ValidateAgainstSchemas/> </p><p> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> </p><p> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> </p><p> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> </p><p> <w:DoNotPromoteQF/> </p><p> <w:LidThemeOther>NL</w:LidThemeOther> </p><p> <w:LidThemeAsian>X-NONE</w:LidThemeAsian> </p><p> <w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript> </p><p> <w:Compatibility> </p><p> <w:BreakWrappedTables/> </p><p> <w:SnapToGridInCell/> </p><p> <w:WrapTextWithPunct/> </p><p> <w:UseAsianBreakRules/> </p><p> <w:DontGrowAutofit/> </p><p> <w:SplitPgBreakAndParaMark/> </p><p> <w:EnableOpenTypeKerning/> </p><p> <w:DontFlipMirrorIndents/> </p><p> <w:OverrideTableStyleHps/> </p><p> </w:Compatibility> </p><p> <m:mathPr> </p><p> <m:mathFont m:val="Cambria Math"/> </p><p> <m:brkBin m:val="before"/> </p><p> <m:brkBinSub m:val="&#45;-"/> </p><p> <m:smallFrac m:val="off"/> </p><p> <m:dispDef/> </p><p> <m:lMargin m:val="0"/> </p><p> <m:rMargin m:val="0"/> </p><p> <m:defJc m:val="centerGroup"/> </p><p> <m:wrapIndent m:val="1440"/> </p><p> <m:intLim m:val="subSup"/> </p><p> <m:naryLim m:val="undOvr"/> </p><p> </m:mathPr></w:WordDocument> </p><p></xml><![endif]--><!--[if gte mso 9]><xml> </p><p> <w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="false" </p><p> DefSemiHidden="false" DefQFormat="false" DefPriority="99" </p><p> LatentStyleCount="375"> </p><p> <w:LsdException Locked="false" Priority="0" QFormat="true" Name="Normal"/> </p><p> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 1"/> </p><p> <w:LsdException Locked="false" Priority="9" SemiHidden="true" </p><p> UnhideWhenUsed="true" QFormat="true" Name="heading 2"/> </p><p> <w:LsdException Locked="false" Priority="9" SemiHidden="true" </p><p> UnhideWhenUsed="true" QFormat="true" Name="heading 3"/> </p><p> <w:LsdException Locked="false" Priority="9" SemiHidden="true" </p><p> UnhideWhenUsed="true" QFormat="true" Name="heading 4"/> </p><p> <w:LsdException Locked="false" Priority="9" SemiHidden="true" </p><p> UnhideWhenUsed="true" QFormat="true" Name="heading 5"/> </p><p> <w:LsdException Locked="false" Priority="9" SemiHidden="true" </p><p> UnhideWhenUsed="true" QFormat="true" Name="heading 6"/> </p><p> <w:LsdException Locked="false" Priority="9" SemiHidden="true" </p><p> UnhideWhenUsed="true" QFormat="true" Name="heading 7"/> </p><p> <w:LsdException Locked="false" Priority="9" SemiHidden="true" </p><p> UnhideWhenUsed="true" QFormat="true" Name="heading 8"/> </p><p> <w:LsdException Locked="false" Priority="9" SemiHidden="true" </p><p> UnhideWhenUsed="true" QFormat="true" Name="heading 9"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="index 1"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="index 2"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="index 3"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="index 4"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="index 5"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="index 6"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="index 7"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="index 8"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="index 9"/> </p><p> <w:LsdException Locked="false" Priority="39" SemiHidden="true" </p><p> UnhideWhenUsed="true" Name="toc 1"/> </p><p> <w:LsdException Locked="false" Priority="39" SemiHidden="true" </p><p> UnhideWhenUsed="true" Name="toc 2"/> </p><p> <w:LsdException Locked="false" Priority="39" SemiHidden="true" </p><p> UnhideWhenUsed="true" Name="toc 3"/> </p><p> <w:LsdException Locked="false" Priority="39" SemiHidden="true" </p><p> UnhideWhenUsed="true" Name="toc 4"/> </p><p> <w:LsdException Locked="false" Priority="39" SemiHidden="true" </p><p> UnhideWhenUsed="true" Name="toc 5"/> </p><p> <w:LsdException Locked="false" Priority="39" SemiHidden="true" </p><p> UnhideWhenUsed="true" Name="toc 6"/> </p><p> <w:LsdException Locked="false" Priority="39" SemiHidden="true" </p><p> UnhideWhenUsed="true" Name="toc 7"/> </p><p> <w:LsdException Locked="false" Priority="39" SemiHidden="true" </p><p> UnhideWhenUsed="true" Name="toc 8"/> </p><p> <w:LsdException Locked="false" Priority="39" SemiHidden="true" </p><p> UnhideWhenUsed="true" Name="toc 9"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Normal Indent"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="footnote text"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="annotation text"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="header"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="footer"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="index heading"/> </p><p> <w:LsdException Locked="false" Priority="35" SemiHidden="true" </p><p> UnhideWhenUsed="true" QFormat="true" Name="caption"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="table of figures"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="envelope address"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="envelope return"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="footnote reference"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="annotation reference"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="line number"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="page number"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="endnote reference"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="endnote text"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="table of authorities"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="macro"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="toa heading"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="List"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="List Bullet"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="List Number"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="List 2"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="List 3"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="List 4"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="List 5"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="List Bullet 2"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="List Bullet 3"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="List Bullet 4"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="List Bullet 5"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="List Number 2"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="List Number 3"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="List Number 4"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="List Number 5"/> </p><p> <w:LsdException Locked="false" Priority="10" QFormat="true" Name="Title"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Closing"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Signature"/> </p><p> <w:LsdException Locked="false" Priority="1" SemiHidden="true" </p><p> UnhideWhenUsed="true" Name="Default Paragraph Font"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Body Text"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Body Text Indent"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="List Continue"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="List Continue 2"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="List Continue 3"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="List Continue 4"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="List Continue 5"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Message Header"/> </p><p> <w:LsdException Locked="false" Priority="11" QFormat="true" Name="Subtitle"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Salutation"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Date"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Body Text First Indent"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Body Text First Indent 2"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Note Heading"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Body Text 2"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Body Text 3"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Body Text Indent 2"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Body Text Indent 3"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Block Text"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Hyperlink"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="FollowedHyperlink"/> </p><p> <w:LsdException Locked="false" Priority="22" QFormat="true" Name="Strong"/> </p><p> <w:LsdException Locked="false" Priority="20" QFormat="true" Name="Emphasis"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Document Map"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Plain Text"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="E-mail Signature"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="HTML Top of Form"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="HTML Bottom of Form"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Normal (Web)"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="HTML Acronym"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="HTML Address"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="HTML Cite"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="HTML Code"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="HTML Definition"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="HTML Keyboard"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="HTML Preformatted"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="HTML Sample"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="HTML Typewriter"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="HTML Variable"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Normal Table"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="annotation subject"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="No List"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Outline List 1"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Outline List 2"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Outline List 3"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Simple 1"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Simple 2"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Simple 3"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Classic 1"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Classic 2"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Classic 3"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Classic 4"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Colorful 1"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Colorful 2"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Colorful 3"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Columns 1"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Columns 2"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Columns 3"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Columns 4"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Columns 5"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Grid 1"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Grid 2"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Grid 3"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Grid 4"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Grid 5"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Grid 6"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Grid 7"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Grid 8"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table List 1"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table List 2"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table List 3"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table List 4"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table List 5"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table List 6"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table List 7"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table List 8"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table 3D effects 1"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table 3D effects 2"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table 3D effects 3"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Contemporary"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Elegant"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Professional"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Subtle 1"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Subtle 2"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Web 1"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Web 2"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Web 3"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Balloon Text"/> </p><p> <w:LsdException Locked="false" Priority="39" Name="Table Grid"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Table Theme"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" Name="Placeholder Text"/> </p><p> <w:LsdException Locked="false" Priority="1" QFormat="true" Name="No Spacing"/> </p><p> <w:LsdException Locked="false" Priority="60" Name="Light Shading"/> </p><p> <w:LsdException Locked="false" Priority="61" Name="Light List"/> </p><p> <w:LsdException Locked="false" Priority="62" Name="Light Grid"/> </p><p> <w:LsdException Locked="false" Priority="63" Name="Medium Shading 1"/> </p><p> <w:LsdException Locked="false" Priority="64" Name="Medium Shading 2"/> </p><p> <w:LsdException Locked="false" Priority="65" Name="Medium List 1"/> </p><p> <w:LsdException Locked="false" Priority="66" Name="Medium List 2"/> </p><p> <w:LsdException Locked="false" Priority="67" Name="Medium Grid 1"/> </p><p> <w:LsdException Locked="false" Priority="68" Name="Medium Grid 2"/> </p><p> <w:LsdException Locked="false" Priority="69" Name="Medium Grid 3"/> </p><p> <w:LsdException Locked="false" Priority="70" Name="Dark List"/> </p><p> <w:LsdException Locked="false" Priority="71" Name="Colorful Shading"/> </p><p> <w:LsdException Locked="false" Priority="72" Name="Colorful List"/> </p><p> <w:LsdException Locked="false" Priority="73" Name="Colorful Grid"/> </p><p> <w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="61" Name="Light List Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 1"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" Name="Revision"/> </p><p> <w:LsdException Locked="false" Priority="34" QFormat="true" </p><p> Name="List Paragraph"/> </p><p> <w:LsdException Locked="false" Priority="29" QFormat="true" Name="Quote"/> </p><p> <w:LsdException Locked="false" Priority="30" QFormat="true" </p><p> Name="Intense Quote"/> </p><p> <w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="70" Name="Dark List Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="61" Name="Light List Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="70" Name="Dark List Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="61" Name="Light List Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="70" Name="Dark List Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="61" Name="Light List Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="70" Name="Dark List Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="61" Name="Light List Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="70" Name="Dark List Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="61" Name="Light List Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="70" Name="Dark List Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="19" QFormat="true" </p><p> Name="Subtle Emphasis"/> </p><p> <w:LsdException Locked="false" Priority="21" QFormat="true" </p><p> Name="Intense Emphasis"/> </p><p> <w:LsdException Locked="false" Priority="31" QFormat="true" </p><p> Name="Subtle Reference"/> </p><p> <w:LsdException Locked="false" Priority="32" QFormat="true" </p><p> Name="Intense Reference"/> </p><p> <w:LsdException Locked="false" Priority="33" QFormat="true" Name="Book Title"/> </p><p> <w:LsdException Locked="false" Priority="37" SemiHidden="true" </p><p> UnhideWhenUsed="true" Name="Bibliography"/> </p><p> <w:LsdException Locked="false" Priority="39" SemiHidden="true" </p><p> UnhideWhenUsed="true" QFormat="true" Name="TOC Heading"/> </p><p> <w:LsdException Locked="false" Priority="41" Name="Plain Table 1"/> </p><p> <w:LsdException Locked="false" Priority="42" Name="Plain Table 2"/> </p><p> <w:LsdException Locked="false" Priority="43" Name="Plain Table 3"/> </p><p> <w:LsdException Locked="false" Priority="44" Name="Plain Table 4"/> </p><p> <w:LsdException Locked="false" Priority="45" Name="Plain Table 5"/> </p><p> <w:LsdException Locked="false" Priority="40" Name="Grid Table Light"/> </p><p> <w:LsdException Locked="false" Priority="46" Name="Grid Table 1 Light"/> </p><p> <w:LsdException Locked="false" Priority="47" Name="Grid Table 2"/> </p><p> <w:LsdException Locked="false" Priority="48" Name="Grid Table 3"/> </p><p> <w:LsdException Locked="false" Priority="49" Name="Grid Table 4"/> </p><p> <w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark"/> </p><p> <w:LsdException Locked="false" Priority="51" Name="Grid Table 6 Colorful"/> </p><p> <w:LsdException Locked="false" Priority="52" Name="Grid Table 7 Colorful"/> </p><p> <w:LsdException Locked="false" Priority="46" </p><p> Name="Grid Table 1 Light Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="51" </p><p> Name="Grid Table 6 Colorful Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="52" </p><p> Name="Grid Table 7 Colorful Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="46" </p><p> Name="Grid Table 1 Light Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="51" </p><p> Name="Grid Table 6 Colorful Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="52" </p><p> Name="Grid Table 7 Colorful Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="46" </p><p> Name="Grid Table 1 Light Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="51" </p><p> Name="Grid Table 6 Colorful Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="52" </p><p> Name="Grid Table 7 Colorful Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="46" </p><p> Name="Grid Table 1 Light Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="51" </p><p> Name="Grid Table 6 Colorful Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="52" </p><p> Name="Grid Table 7 Colorful Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="46" </p><p> Name="Grid Table 1 Light Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="51" </p><p> Name="Grid Table 6 Colorful Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="52" </p><p> Name="Grid Table 7 Colorful Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="46" </p><p> Name="Grid Table 1 Light Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="51" </p><p> Name="Grid Table 6 Colorful Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="52" </p><p> Name="Grid Table 7 Colorful Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="46" Name="List Table 1 Light"/> </p><p> <w:LsdException Locked="false" Priority="47" Name="List Table 2"/> </p><p> <w:LsdException Locked="false" Priority="48" Name="List Table 3"/> </p><p> <w:LsdException Locked="false" Priority="49" Name="List Table 4"/> </p><p> <w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark"/> </p><p> <w:LsdException Locked="false" Priority="51" Name="List Table 6 Colorful"/> </p><p> <w:LsdException Locked="false" Priority="52" Name="List Table 7 Colorful"/> </p><p> <w:LsdException Locked="false" Priority="46" </p><p> Name="List Table 1 Light Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="51" </p><p> Name="List Table 6 Colorful Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="52" </p><p> Name="List Table 7 Colorful Accent 1"/> </p><p> <w:LsdException Locked="false" Priority="46" </p><p> Name="List Table 1 Light Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="51" </p><p> Name="List Table 6 Colorful Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="52" </p><p> Name="List Table 7 Colorful Accent 2"/> </p><p> <w:LsdException Locked="false" Priority="46" </p><p> Name="List Table 1 Light Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="51" </p><p> Name="List Table 6 Colorful Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="52" </p><p> Name="List Table 7 Colorful Accent 3"/> </p><p> <w:LsdException Locked="false" Priority="46" </p><p> Name="List Table 1 Light Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="51" </p><p> Name="List Table 6 Colorful Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="52" </p><p> Name="List Table 7 Colorful Accent 4"/> </p><p> <w:LsdException Locked="false" Priority="46" </p><p> Name="List Table 1 Light Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="51" </p><p> Name="List Table 6 Colorful Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="52" </p><p> Name="List Table 7 Colorful Accent 5"/> </p><p> <w:LsdException Locked="false" Priority="46" </p><p> Name="List Table 1 Light Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="51" </p><p> Name="List Table 6 Colorful Accent 6"/> </p><p> <w:LsdException Locked="false" Priority="52" </p><p> Name="List Table 7 Colorful Accent 6"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Mention"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Smart Hyperlink"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Hashtag"/> </p><p> <w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" </p><p> Name="Unresolved Mention"/> </p><p> </w:LatentStyles> </p><p></xml><![endif]--><!--[if gte mso 10]> </p><p><style> </p><p> /* Style Definitions */ </p><p> table.MsoNormalTable </p><p> {mso-style-name:Standaardtabel; </p><p> mso-tstyle-rowband-size:0; </p><p> mso-tstyle-colband-size:0; </p><p> mso-style-noshow:yes; </p><p> mso-style-priority:99; </p><p> mso-style-parent:""; </p><p> mso-padding-alt:0cm 5.4pt 0cm 5.4pt; </p><p> mso-para-margin-top:0cm; </p><p> mso-para-margin-right:0cm; </p><p> mso-para-margin-bottom:8.0pt; </p><p> mso-para-margin-left:0cm; </p><p> line-height:107%; </p><p> mso-pagination:widow-orphan; </p><p> font-size:11.0pt; </p><p> font-family:"Calibri",sans-serif; </p><p> mso-ascii-font-family:Calibri; </p><p> mso-ascii-theme-font:minor-latin; </p><p> mso-hansi-font-family:Calibri; </p><p> mso-hansi-theme-font:minor-latin; </p><p> mso-bidi-font-family:"Times New Roman"; </p><p> mso-bidi-theme-font:minor-bidi; </p><p> mso-fareast-language:EN-US;} </p><p></style> </p><p><![endif]-->
14:17:31.073: --- 8 Mar 2019, 14:17:31.073 ---
14:17:31.073: Connect to 'pop.inter.nl.net', timeout 30
seconds.
14:17:32.104: >> +OK Hello there.
14:17:32.104: << USER nborsboo
14:17:32.104: >> +OK Password required.
<< 0015 PASS XXXXXXXX
14:17:37.120: >> -ERR Login failed.
Sometimes after this the files stored at the smtp server are tranferred to my PC, sometimes the stay at the server.
Support center of internlnet tried for more than one hour to solve this problem, However no succes.
PLEASE HELP
Niek
&lt;p&gt;Hello there,&lt;/p&gt;&lt;p&gt;I had my password on P-mail changed at my provider internlnet.&amp;nbsp;&lt;/p&gt;&lt;p&gt;I use pegasus email program&amp;nbsp; for some 20 years now. Always very pleased working with p-mail. &lt;/p&gt;&lt;p&gt;Login on the webmail: no problem, However retrieving email from the server to my PC pegasus applicatieon gives the following error:&lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;&lt;!--[if gte mso 9]&gt;&lt;xml&gt; &lt;o:OfficeDocumentSettings&gt; &lt;o:AllowPNG/&gt; &lt;/o:OfficeDocumentSettings&gt; &lt;/xml&gt;&lt;![endif]--&gt;&lt;!--[if gte mso 9]&gt;&lt;xml&gt; &lt;w:WordDocument&gt; &lt;w:View&gt;Normal&lt;/w:View&gt; &lt;w:Zoom&gt;0&lt;/w:Zoom&gt; &lt;w:TrackMoves/&gt; &lt;w:TrackFormatting/&gt; &lt;w:HyphenationZone&gt;21&lt;/w:HyphenationZone&gt; &lt;w:PunctuationKerning/&gt; &lt;w:ValidateAgainstSchemas/&gt; &lt;w:SaveIfXMLInvalid&gt;false&lt;/w:SaveIfXMLInvalid&gt; &lt;w:IgnoreMixedContent&gt;false&lt;/w:IgnoreMixedContent&gt; &lt;w:AlwaysShowPlaceholderText&gt;false&lt;/w:AlwaysShowPlaceholderText&gt; &lt;w:DoNotPromoteQF/&gt; &lt;w:LidThemeOther&gt;NL&lt;/w:LidThemeOther&gt; &lt;w:LidThemeAsian&gt;X-NONE&lt;/w:LidThemeAsian&gt; &lt;w:LidThemeComplexScript&gt;X-NONE&lt;/w:LidThemeComplexScript&gt; &lt;w:Compatibility&gt; &lt;w:BreakWrappedTables/&gt; &lt;w:SnapToGridInCell/&gt; &lt;w:WrapTextWithPunct/&gt; &lt;w:UseAsianBreakRules/&gt; &lt;w:DontGrowAutofit/&gt; &lt;w:SplitPgBreakAndParaMark/&gt; &lt;w:EnableOpenTypeKerning/&gt; &lt;w:DontFlipMirrorIndents/&gt; &lt;w:OverrideTableStyleHps/&gt; &lt;/w:Compatibility&gt; &lt;m:mathPr&gt; &lt;m:mathFont m:val=&quot;Cambria Math&quot;/&gt; &lt;m:brkBin m:val=&quot;before&quot;/&gt; &lt;m:brkBinSub m:val=&quot;&amp;#45;-&quot;/&gt; &lt;m:smallFrac m:val=&quot;off&quot;/&gt; &lt;m:dispDef/&gt; &lt;m:lMargin m:val=&quot;0&quot;/&gt; &lt;m:rMargin m:val=&quot;0&quot;/&gt; &lt;m:defJc m:val=&quot;centerGroup&quot;/&gt; &lt;m:wrapIndent m:val=&quot;1440&quot;/&gt; &lt;m:intLim m:val=&quot;subSup&quot;/&gt; &lt;m:naryLim m:val=&quot;undOvr&quot;/&gt; &lt;/m:mathPr&gt;&lt;/w:WordDocument&gt; &lt;/xml&gt;&lt;![endif]--&gt;&lt;!--[if gte mso 9]&gt;&lt;xml&gt; &lt;w:LatentStyles DefLockedState=&quot;false&quot; DefUnhideWhenUsed=&quot;false&quot; DefSemiHidden=&quot;false&quot; DefQFormat=&quot;false&quot; DefPriority=&quot;99&quot; LatentStyleCount=&quot;375&quot;&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;0&quot; QFormat=&quot;true&quot; Name=&quot;Normal&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; QFormat=&quot;true&quot; Name=&quot;heading 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; QFormat=&quot;true&quot; Name=&quot;heading 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; QFormat=&quot;true&quot; Name=&quot;heading 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; QFormat=&quot;true&quot; Name=&quot;heading 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; QFormat=&quot;true&quot; Name=&quot;heading 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; QFormat=&quot;true&quot; Name=&quot;heading 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; QFormat=&quot;true&quot; Name=&quot;heading 7&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; QFormat=&quot;true&quot; Name=&quot;heading 8&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;9&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; QFormat=&quot;true&quot; Name=&quot;heading 9&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;index 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;index 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;index 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;index 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;index 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;index 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;index 7&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;index 8&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;index 9&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;toc 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;toc 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;toc 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;toc 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;toc 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;toc 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;toc 7&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;toc 8&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;toc 9&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Normal Indent&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;footnote text&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;annotation text&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;header&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;footer&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;index heading&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;35&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; QFormat=&quot;true&quot; Name=&quot;caption&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;table of figures&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;envelope address&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;envelope return&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;footnote reference&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;annotation reference&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;line number&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;page number&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;endnote reference&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;endnote text&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;table of authorities&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;macro&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;toa heading&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;List&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;List Bullet&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;List Number&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;List 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;List 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;List 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;List 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;List Bullet 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;List Bullet 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;List Bullet 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;List Bullet 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;List Number 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;List Number 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;List Number 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;List Number 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;10&quot; QFormat=&quot;true&quot; Name=&quot;Title&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Closing&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Signature&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;1&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Default Paragraph Font&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Body Text&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Body Text Indent&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;List Continue&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;List Continue 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;List Continue 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;List Continue 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;List Continue 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Message Header&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;11&quot; QFormat=&quot;true&quot; Name=&quot;Subtitle&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Salutation&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Date&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Body Text First Indent&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Body Text First Indent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Note Heading&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Body Text 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Body Text 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Body Text Indent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Body Text Indent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Block Text&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Hyperlink&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;FollowedHyperlink&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;22&quot; QFormat=&quot;true&quot; Name=&quot;Strong&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;20&quot; QFormat=&quot;true&quot; Name=&quot;Emphasis&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Document Map&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Plain Text&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;E-mail Signature&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;HTML Top of Form&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;HTML Bottom of Form&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Normal (Web)&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;HTML Acronym&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;HTML Address&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;HTML Cite&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;HTML Code&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;HTML Definition&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;HTML Keyboard&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;HTML Preformatted&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;HTML Sample&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;HTML Typewriter&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;HTML Variable&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Normal Table&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;annotation subject&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;No List&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Outline List 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Outline List 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Outline List 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Simple 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Simple 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Simple 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Classic 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Classic 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Classic 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Classic 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Colorful 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Colorful 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Colorful 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Columns 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Columns 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Columns 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Columns 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Columns 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Grid 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Grid 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Grid 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Grid 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Grid 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Grid 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Grid 7&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Grid 8&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table List 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table List 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table List 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table List 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table List 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table List 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table List 7&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table List 8&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table 3D effects 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table 3D effects 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table 3D effects 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Contemporary&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Elegant&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Professional&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Subtle 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Subtle 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Web 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Web 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Web 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Balloon Text&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; Name=&quot;Table Grid&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Table Theme&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; Name=&quot;Placeholder Text&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;1&quot; QFormat=&quot;true&quot; Name=&quot;No Spacing&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; Name=&quot;Light Shading&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; Name=&quot;Light List&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; Name=&quot;Light Grid&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; Name=&quot;Medium Shading 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; Name=&quot;Medium Shading 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; Name=&quot;Medium List 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; Name=&quot;Medium List 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; Name=&quot;Medium Grid 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; Name=&quot;Medium Grid 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; Name=&quot;Medium Grid 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; Name=&quot;Dark List&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; Name=&quot;Colorful Shading&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; Name=&quot;Colorful List&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; Name=&quot;Colorful Grid&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; Name=&quot;Light Shading Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; Name=&quot;Light List Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; Name=&quot;Light Grid Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; Name=&quot;Medium Shading 1 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; Name=&quot;Medium Shading 2 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; Name=&quot;Medium List 1 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; Name=&quot;Revision&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;34&quot; QFormat=&quot;true&quot; Name=&quot;List Paragraph&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;29&quot; QFormat=&quot;true&quot; Name=&quot;Quote&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;30&quot; QFormat=&quot;true&quot; Name=&quot;Intense Quote&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; Name=&quot;Medium List 2 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; Name=&quot;Medium Grid 1 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; Name=&quot;Medium Grid 2 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; Name=&quot;Medium Grid 3 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; Name=&quot;Dark List Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; Name=&quot;Colorful Shading Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; Name=&quot;Colorful List Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; Name=&quot;Colorful Grid Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; Name=&quot;Light Shading Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; Name=&quot;Light List Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; Name=&quot;Light Grid Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; Name=&quot;Medium Shading 1 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; Name=&quot;Medium Shading 2 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; Name=&quot;Medium List 1 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; Name=&quot;Medium List 2 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; Name=&quot;Medium Grid 1 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; Name=&quot;Medium Grid 2 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; Name=&quot;Medium Grid 3 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; Name=&quot;Dark List Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; Name=&quot;Colorful Shading Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; Name=&quot;Colorful List Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; Name=&quot;Colorful Grid Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; Name=&quot;Light Shading Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; Name=&quot;Light List Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; Name=&quot;Light Grid Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; Name=&quot;Medium Shading 1 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; Name=&quot;Medium Shading 2 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; Name=&quot;Medium List 1 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; Name=&quot;Medium List 2 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; Name=&quot;Medium Grid 1 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; Name=&quot;Medium Grid 2 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; Name=&quot;Medium Grid 3 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; Name=&quot;Dark List Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; Name=&quot;Colorful Shading Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; Name=&quot;Colorful List Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; Name=&quot;Colorful Grid Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; Name=&quot;Light Shading Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; Name=&quot;Light List Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; Name=&quot;Light Grid Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; Name=&quot;Medium Shading 1 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; Name=&quot;Medium Shading 2 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; Name=&quot;Medium List 1 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; Name=&quot;Medium List 2 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; Name=&quot;Medium Grid 1 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; Name=&quot;Medium Grid 2 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; Name=&quot;Medium Grid 3 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; Name=&quot;Dark List Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; Name=&quot;Colorful Shading Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; Name=&quot;Colorful List Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; Name=&quot;Colorful Grid Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; Name=&quot;Light Shading Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; Name=&quot;Light List Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; Name=&quot;Light Grid Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; Name=&quot;Medium Shading 1 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; Name=&quot;Medium Shading 2 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; Name=&quot;Medium List 1 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; Name=&quot;Medium List 2 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; Name=&quot;Medium Grid 1 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; Name=&quot;Medium Grid 2 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; Name=&quot;Medium Grid 3 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; Name=&quot;Dark List Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; Name=&quot;Colorful Shading Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; Name=&quot;Colorful List Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; Name=&quot;Colorful Grid Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;60&quot; Name=&quot;Light Shading Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;61&quot; Name=&quot;Light List Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;62&quot; Name=&quot;Light Grid Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;63&quot; Name=&quot;Medium Shading 1 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;64&quot; Name=&quot;Medium Shading 2 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;65&quot; Name=&quot;Medium List 1 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;66&quot; Name=&quot;Medium List 2 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;67&quot; Name=&quot;Medium Grid 1 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;68&quot; Name=&quot;Medium Grid 2 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;69&quot; Name=&quot;Medium Grid 3 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;70&quot; Name=&quot;Dark List Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;71&quot; Name=&quot;Colorful Shading Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;72&quot; Name=&quot;Colorful List Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;73&quot; Name=&quot;Colorful Grid Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;19&quot; QFormat=&quot;true&quot; Name=&quot;Subtle Emphasis&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;21&quot; QFormat=&quot;true&quot; Name=&quot;Intense Emphasis&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;31&quot; QFormat=&quot;true&quot; Name=&quot;Subtle Reference&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;32&quot; QFormat=&quot;true&quot; Name=&quot;Intense Reference&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;33&quot; QFormat=&quot;true&quot; Name=&quot;Book Title&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;37&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Bibliography&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;39&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; QFormat=&quot;true&quot; Name=&quot;TOC Heading&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;41&quot; Name=&quot;Plain Table 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;42&quot; Name=&quot;Plain Table 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;43&quot; Name=&quot;Plain Table 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;44&quot; Name=&quot;Plain Table 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;45&quot; Name=&quot;Plain Table 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;40&quot; Name=&quot;Grid Table Light&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;46&quot; Name=&quot;Grid Table 1 Light&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;47&quot; Name=&quot;Grid Table 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;48&quot; Name=&quot;Grid Table 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;49&quot; Name=&quot;Grid Table 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;50&quot; Name=&quot;Grid Table 5 Dark&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;51&quot; Name=&quot;Grid Table 6 Colorful&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;52&quot; Name=&quot;Grid Table 7 Colorful&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;46&quot; Name=&quot;Grid Table 1 Light Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;47&quot; Name=&quot;Grid Table 2 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;48&quot; Name=&quot;Grid Table 3 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;49&quot; Name=&quot;Grid Table 4 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;50&quot; Name=&quot;Grid Table 5 Dark Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;51&quot; Name=&quot;Grid Table 6 Colorful Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;52&quot; Name=&quot;Grid Table 7 Colorful Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;46&quot; Name=&quot;Grid Table 1 Light Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;47&quot; Name=&quot;Grid Table 2 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;48&quot; Name=&quot;Grid Table 3 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;49&quot; Name=&quot;Grid Table 4 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;50&quot; Name=&quot;Grid Table 5 Dark Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;51&quot; Name=&quot;Grid Table 6 Colorful Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;52&quot; Name=&quot;Grid Table 7 Colorful Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;46&quot; Name=&quot;Grid Table 1 Light Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;47&quot; Name=&quot;Grid Table 2 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;48&quot; Name=&quot;Grid Table 3 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;49&quot; Name=&quot;Grid Table 4 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;50&quot; Name=&quot;Grid Table 5 Dark Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;51&quot; Name=&quot;Grid Table 6 Colorful Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;52&quot; Name=&quot;Grid Table 7 Colorful Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;46&quot; Name=&quot;Grid Table 1 Light Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;47&quot; Name=&quot;Grid Table 2 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;48&quot; Name=&quot;Grid Table 3 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;49&quot; Name=&quot;Grid Table 4 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;50&quot; Name=&quot;Grid Table 5 Dark Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;51&quot; Name=&quot;Grid Table 6 Colorful Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;52&quot; Name=&quot;Grid Table 7 Colorful Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;46&quot; Name=&quot;Grid Table 1 Light Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;47&quot; Name=&quot;Grid Table 2 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;48&quot; Name=&quot;Grid Table 3 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;49&quot; Name=&quot;Grid Table 4 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;50&quot; Name=&quot;Grid Table 5 Dark Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;51&quot; Name=&quot;Grid Table 6 Colorful Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;52&quot; Name=&quot;Grid Table 7 Colorful Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;46&quot; Name=&quot;Grid Table 1 Light Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;47&quot; Name=&quot;Grid Table 2 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;48&quot; Name=&quot;Grid Table 3 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;49&quot; Name=&quot;Grid Table 4 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;50&quot; Name=&quot;Grid Table 5 Dark Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;51&quot; Name=&quot;Grid Table 6 Colorful Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;52&quot; Name=&quot;Grid Table 7 Colorful Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;46&quot; Name=&quot;List Table 1 Light&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;47&quot; Name=&quot;List Table 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;48&quot; Name=&quot;List Table 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;49&quot; Name=&quot;List Table 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;50&quot; Name=&quot;List Table 5 Dark&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;51&quot; Name=&quot;List Table 6 Colorful&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;52&quot; Name=&quot;List Table 7 Colorful&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;46&quot; Name=&quot;List Table 1 Light Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;47&quot; Name=&quot;List Table 2 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;48&quot; Name=&quot;List Table 3 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;49&quot; Name=&quot;List Table 4 Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;50&quot; Name=&quot;List Table 5 Dark Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;51&quot; Name=&quot;List Table 6 Colorful Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;52&quot; Name=&quot;List Table 7 Colorful Accent 1&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;46&quot; Name=&quot;List Table 1 Light Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;47&quot; Name=&quot;List Table 2 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;48&quot; Name=&quot;List Table 3 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;49&quot; Name=&quot;List Table 4 Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;50&quot; Name=&quot;List Table 5 Dark Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;51&quot; Name=&quot;List Table 6 Colorful Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;52&quot; Name=&quot;List Table 7 Colorful Accent 2&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;46&quot; Name=&quot;List Table 1 Light Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;47&quot; Name=&quot;List Table 2 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;48&quot; Name=&quot;List Table 3 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;49&quot; Name=&quot;List Table 4 Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;50&quot; Name=&quot;List Table 5 Dark Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;51&quot; Name=&quot;List Table 6 Colorful Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;52&quot; Name=&quot;List Table 7 Colorful Accent 3&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;46&quot; Name=&quot;List Table 1 Light Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;47&quot; Name=&quot;List Table 2 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;48&quot; Name=&quot;List Table 3 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;49&quot; Name=&quot;List Table 4 Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;50&quot; Name=&quot;List Table 5 Dark Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;51&quot; Name=&quot;List Table 6 Colorful Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;52&quot; Name=&quot;List Table 7 Colorful Accent 4&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;46&quot; Name=&quot;List Table 1 Light Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;47&quot; Name=&quot;List Table 2 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;48&quot; Name=&quot;List Table 3 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;49&quot; Name=&quot;List Table 4 Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;50&quot; Name=&quot;List Table 5 Dark Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;51&quot; Name=&quot;List Table 6 Colorful Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;52&quot; Name=&quot;List Table 7 Colorful Accent 5&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;46&quot; Name=&quot;List Table 1 Light Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;47&quot; Name=&quot;List Table 2 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;48&quot; Name=&quot;List Table 3 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;49&quot; Name=&quot;List Table 4 Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;50&quot; Name=&quot;List Table 5 Dark Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;51&quot; Name=&quot;List Table 6 Colorful Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; Priority=&quot;52&quot; Name=&quot;List Table 7 Colorful Accent 6&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Mention&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Smart Hyperlink&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Hashtag&quot;/&gt; &lt;w:LsdException Locked=&quot;false&quot; SemiHidden=&quot;true&quot; UnhideWhenUsed=&quot;true&quot; Name=&quot;Unresolved Mention&quot;/&gt; &lt;/w:LatentStyles&gt; &lt;/xml&gt;&lt;![endif]--&gt;&lt;!--[if gte mso 10]&gt; &lt;style&gt; /* Style Definitions */ table.MsoNormalTable {mso-style-name:Standaardtabel; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:&quot;&quot;; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:8.0pt; mso-para-margin-left:0cm; line-height:107%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:&quot;Calibri&quot;,sans-serif; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:&quot;Times New Roman&quot;; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;} &lt;/style&gt; &lt;![endif]--&gt; &lt;/p&gt;&lt;p class=&quot;MsoNormal&quot;&gt;14:17:31.073: --- 8 Mar 2019, 14:17:31.073 ---&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;14:17:31.073: Connect to &#039;pop.inter.nl.net&#039;, timeout 30 seconds.&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;14:17:32.104: &amp;gt;&amp;gt; +OK Hello there.&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;14:17:32.104: &amp;lt;&amp;lt; USER nborsboo&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;14:17:32.104: &amp;gt;&amp;gt; +OK Password required.&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&amp;lt;&amp;lt; 0015 PASS XXXXXXXX&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;14:17:37.120: &amp;gt;&amp;gt; -ERR Login failed.&lt;/p&gt;&lt;p class=&quot;MsoNormal&quot;&gt;Sometimes after this the files stored at the smtp server are tranferred to my PC, sometimes the stay at the server.&lt;/p&gt;&lt;p class=&quot;MsoNormal&quot;&gt;Support center of internlnet tried for more than one hour to solve this problem, However no succes.&amp;nbsp; &lt;/p&gt;&lt;p class=&quot;MsoNormal&quot;&gt;PLEASE HELP&lt;/p&gt;&lt;p class=&quot;MsoNormal&quot;&gt;&amp;nbsp;&lt;/p&gt;&lt;p class=&quot;MsoNormal&quot;&gt;Niek &lt;/p&gt;&lt;p class=&quot;MsoNormal&quot;&gt;&amp;nbsp;&lt;/p&gt;&lt;p class=&quot;MsoNormal&quot;&gt;&amp;nbsp;&lt;/p&gt;&lt;p class=&quot;MsoNormal&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p&gt;&amp;nbsp;&lt;/p&gt;
The failure is due to a missing or invalid password which is stored in the POP3 and/or IMAP profile, depending on which one you are using.
To access the POP3 profiles go to Tools > Internet options > Receiving(POP3) tab.  Select the POP3 host listed there then click the Edit button.  Click OK through the shared definition warning window if it pops up.  Set the password field to the new password.
For IMAP go to Tools > IMAP profiles.  Select the appropriate profile then click Edit.  You will find the password field in the Connection tab.
&lt;p&gt;The failure is due to a missing or invalid password which is stored in the POP3 and/or IMAP profile, depending on which one you are using.&amp;nbsp; &lt;/p&gt;&lt;p&gt;To access the POP3 profiles go to Tools &amp;gt; Internet options &amp;gt; Receiving(POP3) tab.&amp;nbsp; Select the POP3 host listed there then click the Edit button.&amp;nbsp; Click OK through the shared definition warning window if it pops up.&amp;nbsp; Set the password field to the new password.&lt;/p&gt;&lt;p&gt;For IMAP go to Tools &amp;gt; IMAP profiles.&amp;nbsp; Select the appropriate profile then click Edit.&amp;nbsp; You will find the password field in the Connection tab. &lt;/p&gt;
