[quote user="geoff in SA"]
No, I use only one identity.
Without any further intervention on my part, I was later able to send e-mails again. Either an intermittent software or hardware fault on my side (unlikely) or a problem with my service provider.
IMHO it is not Pmail's fault. Either a server-side problem or a client-side misconfiguration. Due to its intermittency I'm sticking to the prior.
I've not yet found a way to block the "Telltale" messages popping up. Shutting my system down and rebooting does not help, and the box for requesting Telltale is definitely not clicked.
Telltale is set/unset via Tools > Options... > User interface > Reporting/logging > New mail reporting. If you uncheck the first checkbox there'll be no Telltale. The other block options are less "intrusive" manners to alert you of new mail in your inbox. I use them all, including a soft sound announcing new mail arriving I borrowed from Sylpheed (I think).
Anyway, I don't dislike the telltale at all. Maybe you're finding its default placement improper. Click and hold teltale's title bar with your mouse and drag it to a more convenient position of your screen. Once there, click the "X" close button to save its window position and you're done.
[quote user="geoff in SA"]<p>No, I use only one identity.</p><p>Without any further intervention on my part, I was later able to send e-mails again. Either an intermittent software or hardware fault on my side (unlikely) or a problem with my service provider.
</p>[/quote]<p>IMHO it is not Pmail's fault. Either a server-side problem or a client-side misconfiguration. Due to its intermittency I'm sticking to the prior.
</p><p>[quote user="geoff in SA"]</p><p>I've not yet found a way to block the "Telltale" messages popping up. Shutting my system down and rebooting does not help, and the box for requesting Telltale is definitely not clicked.
</p><p>[/quote]</p><p>Telltale is set/unset via <span style="background-color: rgb(255, 255, 0);">Tools &gt; Options... &gt; User interface &gt; Reporting/logging &gt; New mail reporting<span style="background-color: rgb(255, 255, 255);">. If you uncheck the first checkbox there'll be no Telltale. The other block options are less "intrusive" manners to alert you of new mail in your inbox. I use them all, including a soft sound announcing new mail arriving I borrowed from Sylpheed (I think).</span></span></p><p>Anyway, I don't dislike the telltale at all. Maybe you're finding its default placement improper. Click and hold teltale's title bar with your mouse and drag it to a more convenient position of your screen. Once there, click the "X" close button to save its window position and you're done.
