I use this command string to open PM 4.6 from external drive: x:/pmail/winpm-32.exe -a -roam -I admin
First I get a msg saying MAILBOX IS LOCKED blahblah, EXIT or CONTINUE. As I'm offline and the only one connected to that drive, no one else can possibly be accessing the mailbox. But just to be sure, I unplugged the drive, turned it off and then on, and restarted my computer. Same deas. So I hit CONTINUE.
Next up, AUTOSAVED MESSAGES FOUND, then OPEN or CONTINUE. I've been getting this msg for a year or more. But this time when I hit CONTINUE,  I get the dreaded (NOT RESPONDING)  msg. I can see some of the mailboxes in the background. Other times I can see a screen full of them. But no matter how many times I repeat this process, the program never fully opens.
At bottom left it says APPLYING MAIL FILTERING RULES...
If I just leave it and don't click CONTINUE or OPEN, nothing happens. It just hangs. 26GB left on the external drive, though I do have a massive number of emails going back probably 15 years.
Everything else works normally; only Pegasus freezes.
Have already checked hang, freeze, and crash threads mentioned here: http://community.pmail.com/forums/thread/31478.aspx
Kinda need access to keep making a living...
Thanks for any help!
Windows 8.1 (Also tried using Windows 10 computer; same thing)
PM 4.6
        <p>I use this command string to open PM 4.6 from external drive: x:/pmail/winpm-32.exe -a -roam -I admin
Everything else works normally; only Pegasus freezes.</p><p>Have already checked hang, freeze, and crash threads mentioned here:&nbsp;http://community.pmail.com/forums/thread/31478.aspx
PM 4.6
