[quote user="Pierre"]
Thank you for your suggestions but I as I mentioned I am looking for an automated solution.
Currently I have a "New mail filtering rule" to "extract" to a file which saves the raw encoded message. I would like a rule that saves the decoded message.
It looks like this is not possible, pity.
Every week I receive a new set of data and I need to be sure the files is always the latest set. A manual save or copy & paste could be forgotten and the file out of date.
As an aside, "extract" should be renamed "raw save"
I got your point. The "Extract" rule action was meant to plain-text messages only. Strangely Pegasus Mail does have a routine to save encoded content and maybe David H. could make it available as a rule action too. For example, if you mouse right-click your target message and pick "Save message data to file (Ctrl+S)" from the menu, it will save the decode body to the chosen file.
As mentioned behind, Pegasus Mail can save encoded attachments as decoded files. It would be a matter to extend this capability to the message body, I think.
[quote user="Pierre"]<p>Thank you for your suggestions but I as I mentioned I am looking for an automated solution.&nbsp;</p><p>Currently I have a "New mail filtering rule" to "extract" to a file which saves the raw encoded message. I would like a rule that saves the decoded message.</p><p><span style="font-size: 10pt;">It looks like this is not possible, pity.</span></p><p>Every week I receive a new set of data and I need to be sure the files is always the latest set. A manual save or copy &amp; paste<span style="font-size: 10pt;">&nbsp;could </span><span style="font-size: 10pt;">be&nbsp;</span><span style="font-size: 13.3333px;">forgotten</span><span style="font-size: 10pt;">&nbsp;and the file out of date.</span></p><p>As an aside, "extract" should be renamed "raw save"</p><p>[/quote]</p><p>I got your point. The "Extract" rule action was meant to plain-text messages only. Strangely Pegasus Mail does have a routine to save encoded content and maybe David H. could make it available as a rule action too. For example, if you mouse right-click your target message and pick "Save message data to file (Ctrl+S)" from the menu, it will save the decode body to the chosen file.</p><p>As mentioned behind, Pegasus Mail can save encoded attachments as decoded files. It would be a matter to extend this capability to the message body, I think.
