Hi, I will keep it simple and get to the point.
On MercuryS SMTP Server in the IP Interface to use, if I enter 127.0.0.1 it will send mail from my computer to anywhere internal network or outside of the network(internet) but will not receive incomming mail.
If I change the IP Interface to listen on 192.168.1.2 (the computer which hosts the mail server) it will receive mail from anywhere but not send mail at all outside of the network.
My router has ports setup for 25, 110, and forwarded to IP 192.268.1.2.
My OS is windows 10 64bit and I am using  Mercuty v4.62 (because newer versions will not work properly on this machine).
Any help would be much appreciated, thanks
        <p>Hi, I will keep it simple and get to the point.</p><p>On MercuryS SMTP Server in the IP Interface to use, if I enter 127.0.0.1 it will send mail from my computer to anywhere internal network or outside of the network(internet) but will not receive incomming mail. </p><p>If I change the IP Interface to listen on 192.168.1.2 (the computer which hosts the mail server) it will receive mail from anywhere but not send mail at all outside of the network.&nbsp;</p><p>My router has ports setup for 25, 110, and forwarded to IP 192.268.1.2. </p><p>My OS is windows 10 64bit and I am using&nbsp; Mercuty v4.62 (because newer versions will not work properly on this machine).</p><p>Any help would be much appreciated, thanks
