"socket read timeout" failure on MercuryC with SSL
Solved!
My IT right hand man assured me that port 465 was open but he was only thinking of the router.  It was being blocked by Windows firewall.
<p>Solved!  </p><p>My IT right hand man assured me that port 465 was open but he was only thinking of the router.  It was being blocked by Windows firewall. </p>
I have been trying to get MercuryC to connect using SSL but can't get past "socket read timeout" failures.  I have confirmed the server and port settings with my domain host.  Any other suggestions?  Might the beta version help?
As far as i know this error means no connection possible. Do you have checked your firewall settings?
Another point could be that your partner silently changed port, ssl-access (starttls) or the format of the username (username@example.com instead of username).
<p><span style="font-size: 13.3333px;">As far as i know this error means no connection possible. Do you have checked your firewall settings?</span></p><p><span style="font-size: 13.3333px;">Another point could be that your partner silently changed port, ssl-access (starttls) or the format of the username (username@example.com instead of username).</span></p>
Our Mercury C runs without problems with following settings:
Smart Host Name:        smtp.ionos.de          (smtp server of our ISP)
Port:                            587  /  SSL encryption via STARTTLS command
Announce myself as:    domain.com     (our internet doamin, used for our external e-mail addresses)
Forced SMTP sender:   empty
Login Username:          one of our ISP email account usernames (e-mail address)
Except the general logging settings, the rest of the "credential settings for SMTP authentication" remain unchecked/disabled
<p>Our Mercury C runs without problems with following settings:</p><p>Smart Host Name:        smtp.ionos.de          (smtp server of our ISP) </p><p>Port:                            587  /  SSL encryption via STARTTLS command</p><p>Announce myself as:    <i>domain.com</i>     (our internet doamin, used for our external e-mail addresses)</p><p>Forced SMTP sender:  <i> empty</i> </p><p>Login Username:          one of our ISP email account usernames (e-mail address)</p><p> </p><p>Except the general logging settings, the rest of the "credential settings for SMTP authentication" remain unchecked/disabled </p><p> </p>
