Mercury 4.9 forwarding to gmail - no PTR...
Hi Guys,
Wondered if someone could guide me please.
I have Mercury set to forward one email address here to a gmail account. Until I enabled SSL in Mercury E, everything was working fine. Now I'm getting this:
The attached message has failed delivery and has been referred
to you as postmaster. The following error report or reports
were given to explain the problem:
*** [redacted]@gmail.com
550-5.7.25 [redacted] The IP address sending this message does not have a PTR
It this something I have to do in Mercury, or is it a DNS setting with the provider through which I have my main domain?
Hi Guys, Wondered if someone could guide me please. I have Mercury set to forward one email address here to a gmail account. Until I enabled SSL in Mercury E, everything was working fine. Now I'm getting this: ```` The attached message has failed delivery and has been referred to you as postmaster. The following error report or reports were given to explain the problem: *** [redacted]@gmail.com 550-5.7.25 [redacted] The IP address sending this message does not have a PTR ```` It this something I have to do in Mercury, or is it a DNS setting with the provider through which I have my main domain?
A mail transfer agent is expected to have PTR record assigned to the IP address, and as you say you will need to ask your Internet Service Provider to create one.
