Attachments not showing
A serious and urgent issue: my emails have suddenly stopped showing attachments, even for older emails. The emails show the larger size but the "Attachments" page empty. I found _compmail.pegasus-mail.ms-windows.narkive.com/blRdiWXT/attachments-not-showing-up but that was 18 years ago. I don't have a state.pmj**; it may have been accidentally deleted. What should I do to safely fix the problem?
Jim
A serious and urgent issue: my emails have suddenly stopped showing attachments, even for older emails. The emails show the larger size but the "Attachments" page empty. I found _**compmail.pegasus-mail.ms-windows.narkive.com/blRdiWXT/attachments-not-showing-up but that was 18 years ago. I don't have a **state.pmj**; it may have been accidentally deleted. What should I do to safely fix the problem? Jim
edited Feb 11 '23 at 12:27 pm
There is a divider bar in the attachment tab that might be raised so high that it is hiding the list of attachments. The screen shot below is of a message that has a plain text part and an HTML part. You can see the bar just below the HTML text entry. If yours is at the top of the pane, grab it and drag it down.
As for state.pmj, it will be in your Home mailbox directory. If it was deleted Pegasus Mail would create a new one on next startup.
63e7a2e2cdb45
There is a divider bar in the attachment tab that might be raised so high that it is hiding the list of attachments. The screen shot below is of a message that has a plain text part and an HTML part. You can see the bar just below the HTML text entry. If yours is at the top of the pane, grab it and drag it down. As for state.pmj, it will be in your Home mailbox directory. If it was deleted Pegasus Mail would create a new one on next startup. ![63e7a2e2cdb45](serve/attachment&path=63e7a2e2cdb45)
