I have been using Pegasus mail for many years, since at least 1996. I have moved my email from one ISP to another many times. I recently had a HD crash and have decided to reinstall Pegasus to a different location after my crash. During this process, all my mail is working just fine but I have discovered that my Help system is not. Since I don't access the help system frequently, I am not sure if it was working prior to my crash. I am using W10.
I have read the thread from Tom Barkas from 1/31/23 and still cannot get things working. The weird thing is that if I launch Pegasus from an old mailbox, the help system functions properly. But if I launch it from my currently used mailbox, it does not.
I have confirmed that if I drag winpm-32.phc onto showhelp.exe, it launches the help system. This is visible in Task Manager. However, if I try to invoke the help system from within my current mailbox, nothing happens. An entry is created in Task Manager but it contains no data on the line. Where the data should be is completely blank.
I am attaching the info screens from both mailboxes. "oliveral" (help works) is the old mailbox and "indynet" (help does not work) is the current mailbox. Besides comparing the info screens, I have also examined the PMAIL.INI files from both mailboxes. The old oliveral INI file contains some references to non existant directories. There are references to C:\PROGRAM FILES\PMAIL\MAIL\oliveral. I believe that was the recommended location for files many years ago. But I don't see how that would cause the help system to work.
----oliveral info screen (help works)----
Copyright (C) 1992-2022, David Harris, all rights reserved
WinPMail version: Version 4.80.1028, Jan 16 2022, build ID 1028
User name and ID: oliveral, 0
Home mailbox location: C:\PMAIL\MAIL\oliveral
New mailbox location: C:\PMAIL\MAIL\oliveral
TMP environment variable: C:\Users\aoliv\AppData\Local\Temp
TEMP environment variable: C:\Users\aoliv\AppData\Local\Temp
- WINSOCK path: WSOCK32.DLLCommandline: -A -I oliveralActive -Z options: 32768PMR variable: (None)PML variable: (None)MAI variable: (None)NB variable: (None)Autofiltering folders: 0 (0 active, 0 inactive)Last new mail count: 21Message size soft limit: 0 bytesMessage size hard limit: 0 bytesAttachment size soft limit: 0 bytesAttachment size hard limit: 0 bytes
----indynet info screen (help does not work)---- Pegasus Mail for Microsoft WindowsCopyright (C) 1992-2022, David Harris, all rights reservedElectronic mail to support@pmail.gen.nz.
WinPMail version: Version 4.80.1028, Jan 16 2022, build ID 1028Language resources: Standard UK English resources (EN,0,LL)Extension Manager version: 1.14Operating mode: StandaloneUser name and ID: indynet, 0Windows version: 6.2Windows flag word: 0WINPMAIL.EXE directory: C:\PMAIL\ProgramsHome mailbox location: C:\PMAIL\MAIL\indynetNew mailbox location: C:\PMAIL\MAIL\indynetTMP environment variable: C:\Users\aoliv\AppData\Local\TempTEMP environment variable: C:\Users\aoliv\AppData\Local\TempLAN-based SMTP support: N, N, NNetWare MHS support: N, N, NBuilt-in TCP/IP support: Enabled
- WINSOCK path: WSOCK32.DLLCommandline: -A -I indynetActive -Z options: 32768PMR variable: (None)PML variable: (None)MAI variable: (None)NB variable: (None)Autofiltering folders: 0 (0 active, 0 inactive)Last new mail count: 165Message size soft limit: 0 bytesMessage size hard limit: 0 bytesAttachment size soft limit: 0 bytesAttachment size hard limit: 0 bytes
Does anybody have any ideas how to get this working again?
NB variable: (None)
NB variable: (None)
