Hi Johannes,
With us Mercury is used as local mail server only, means it is retrieving all mail from our ISP Mail Provider and provide it locally to the local user mailboxes. Direct user access from outside (internet) is not possible. If our streetworkes would like to check their mails they have to dial-in to Company LAN via VPN first to reach the internal mail server.
That's why we do not need to setup any additional special encryption when local users are accessing Mercury within our company LAN. But nevertheless a simple authentication with username and PW is necessary.
But of course, when connecting to german Mail ISPs, Mercury has to follow their minimum connection requirements as follows:
- Mercury C (SMTP Client for delivering locally submitted mails to ISP): "SSL encryption via STARTTLS command" over port 587, using one (1) ISP user mailbox credentials for authentication and submitting of all user mails
- Mercury D (POP3 Client for retrieving mails from ISP mailboxes): "SSL encryption via STARTTLS command" over port 110, using each single ISP mailbox credentials for authentication of each ISP mailbox.
So far the external connection to ISP.
For internal mail submission from Pmail, Thunderbird, Roundcube (or other IT equipment which is sending mails, like firewalls, IP cameras, etc.) to Mercury S (internal SMTP Server) we do not use any additional security settings. Every application can use the SMTP server to submit mails without authentication.
For the internal LAN connection from Pmail, Thunderbird or Roundcube to Mercury I (IMAP Server for accessing the local user mailboxes) also no additional connection control or SSL is activated but the username and PW has to be used. And this is indeed a try and error game, everytime I setup a new Thunderbird Client. Often only the third or fourth attempt succeeded, since I have to say TB to don't use any automatically discovered mail connection but to use our special local IP address of Mercury, the (shortened) local username from Synonym database and PW. Using the right full email address as user name works only sometimes and sometimes not when commissioning a new client. Don't know what it depends on. I prefer using the shortened username from synonym.
But once a connection is established it works great and you don't have to take care of usernames etc.
Hi Johannes,
With us Mercury is used as local mail server only, means it is retrieving all mail from our ISP Mail Provider and provide it locally to the local user mailboxes. **Direct user access from outside (internet) is not possible**. If our streetworkes would like to check their mails they have to dial-in to Company LAN via VPN first to reach the internal mail server.
But once a connection is established it works great and you don't have to take care of usernames etc. :)
edited Apr 12 '23 at 11:08 am
