Hi all,
I have a problem that somehow must have come up with using two monitors, or maybe some other reason I do not know (but it occured also with another program in a similar way).
I seems that in some cases (concrete: when I want to create a new folder in my mailbox or also, when I get asked if I want a copy of my outgoing mail) the pop-up window must be displayed somwhere, but not on my visible monitor. Pmail gives a "gong" goes in the background and every klick on the screen leads to another "gong". In the two cases the pop-up window for the folder to be created, or the folder where it should be saved, respectively should appear on the screen. When I type <esc> the pmail screen returns to normal.
However, not all pop-ups from inside pmail have the same behavior.
Any clue? Thanks for any help.
Peter
Hi all,
Peter
