Problem with pop-up window
Hi all,
I have a problem that somehow must have come up with using two monitors, or maybe some other reason I do not know (but it occured also with another program in a similar way).
I seems that in some cases (concrete: when I want to create a new folder in my mailbox or also, when I get asked if I want a copy of my outgoing mail) the pop-up window must be displayed somwhere, but not on my visible monitor. Pmail gives a "gong" goes in the background and every klick on the screen leads to another "gong". In the two cases the pop-up window for the folder to be created, or the folder where it should be saved, respectively should appear on the screen. When I type <esc> the pmail screen returns to normal.
However, not all pop-ups from inside pmail have the same behavior.
Any clue? Thanks for any help.
Peter
Hi all, I have a problem that somehow must have come up with using two monitors, or maybe some other reason I do not know (but it occured also with another program in a similar way). I seems that in some cases (concrete: when I want to create a new folder in my mailbox or also, when I get asked if I want a copy of my outgoing mail) the pop-up window must be displayed somwhere, but not on my visible monitor. Pmail gives a &quot;gong&quot; goes in the background and every klick on the screen leads to another &quot;gong&quot;. In the two cases the pop-up window for the folder to be created, or the folder where it should be saved, respectively should appear on the screen. When I type &lt;esc&gt; the pmail screen returns to normal. However, not all pop-ups from inside pmail have the same behavior. Any clue? Thanks for any help. Peter
I believe that it is opening offscreen as you suspect. What I am recommending applies to the popup when creating a new message. I don't know if it also applies to the copyself popup.
The popup window coordinates are stored in STATE.PMJ.
  • With Pegasus Mail closed, make a safety copy of it and then open in with a text editor.
  • Search for this section: [NAMERF]. It will contain an entry "Default=" which contains the coordinates. You should see some absurd values. Use these instead: DEFAULT=250,214,600,588
  • Save then close.
  • Start Pegasus Mail and test.
Hope that helps.
I believe that it is opening offscreen as you suspect. What I am recommending applies to the popup when creating a new message. I don&#039;t know if it also applies to the copyself popup. The popup window coordinates are stored in STATE.PMJ. - With Pegasus Mail closed, make a safety copy of it and then open in with a text editor. - Search for this section: [NAMERF]. It will contain an entry &quot;Default=&quot; which contains the coordinates. You should see some absurd values. Use these instead: DEFAULT=250,214,600,588 - Save then close. - Start Pegasus Mail and test. Hope that helps.
Hi Brian,
thanks for the hint.
The new Mailfolder worked with the [NAMEREF].
For the saving of the Reply it was the [SOLREF], which I found by trial and error.
Wonder how these got screwed up like that.
Thanks much!
Peter
Hi Brian, thanks for the hint. The new Mailfolder worked with the [NAMEREF]. For the saving of the Reply it was the [SOLREF], which I found by trial and error. Wonder how these got screwed up like that. Thanks much! Peter
I am glad you have it sorted out.
The logical explanation is that the popups were last on the second monitor resulting in invalid screen coordinates for a single monitor. Misplaced windows have also happened without a second monitor. The cause of those remains a mystery.
I am glad you have it sorted out. [quote=&quot;pid:55955, uid:11730&quot;]Wonder how these got screwed up like that.[/quote] The logical explanation is that the popups were last on the second monitor resulting in invalid screen coordinates for a single monitor. Misplaced windows have also happened without a second monitor. The cause of those remains a mystery.
