Just a couple things that I would be concerned with.
- Would have to leave Pegasus open, and would have to have it set to auto-download.
- Would be concerned that it might forward messages again and again if rule didn't move messages to another folder after forwarding.
Another option, might be to use a tool like vnc or other remote access to connect to your PC. Generally, doing that with a phone has limitations. With a notebook, I've had no problems. But setting it up is a little work.
I currently am access 6 machines that are 7 timezones away from my location using vnc. 4 are linux, but two are windows 11.
Never used IMAP, and don't know of phone app. Could also use webmail if your provider offers it.
Good Luck.
1. Would have to leave Pegasus open, and would have to have it set to auto-download.
2. Would be concerned that it might forward messages again and again if rule didn't move messages to another folder after forwarding.
Good Luck.
