[quote user="Heini_net"]
i let all my Mails on my MercuryMail-Server. but after it has changed the timezone to Winter-Time so my E-MailClient download all e-Mails again. whats wrong ?
[/quote]It's only quite recently that I've been able to work out exactly why this was happening. It turns out the problem is a clear bug in Windows - see this link for more: http://www.codeproject.com/datetime/dstbugs.asp. It turns out that Windows incorrectly applies timezone variations even to files that were not modified when that timezone variation applied! In other words, a file modified at 9am before daylight savings time will appear to have been modified at 10am after daylight savings comes in, even though that's obviously nonsensical.
I'm trying to find a solution for this, but it is likely that the solution will cause some initial pain - i.e, the first time you switch to the new method, you'll probably get all your mail offered to you again, but it will be the last time it will happen. The solution will be available in v4.53, which will be out before the end of the year.
-- David --
[quote user="Heini_net"]<p>i let all my Mails on my MercuryMail-Server. but after it has changed the timezone to Winter-Time so my E-MailClient download all e-Mails again. whats wrong ? </p>[/quote]
It's only quite recently that I've been able to work out exactly why this was happening. It turns out the problem is a clear bug in Windows - see this link for more: <a href="http://www.codeproject.com/datetime/dstbugs.asp" title="Windows DST Bugs" target="_blank" mce_href="http://www.codeproject.com/datetime/dstbugs.asp">http://www.codeproject.com/datetime/dstbugs.asp</a>. It turns out that Windows incorrectly applies timezone variations even to files that were not modified when that timezone variation applied! In other words, a file modified at 9am before daylight savings time will appear to have been modified at 10am after daylight savings comes in, even though that's obviously nonsensical.
-- David --
