IMAP logging in and out too many times
Glad it worked for you.
Enjoy
<p>Glad it worked for you.</p><p>Enjoy</p><p> </p>
I'm trying to use IMAP to transfer messages from Pegasus to Outlook. I
am dragging the messages from Pegasus to fastmail.fm's server via IMAP, then
dragging them from that IMAP folder into Outlook.
The problem I'm having is that Pegasus is logging out and logging in
for every single message, which is causing headaches for fastmail, who
will suspend my account if I keep having 200+ logins per hour. Is there
any way to get Pegasus to keep the connection open and just move all
the messages with one login? (I did check the box under "performance"
that says "Keep a utility connection open when this definition is
active," but obviously that hasn't done the trick.)
If it isn't possible to do this, then does anyone know of an IMAP
provider that won't mind such frequent logins? I have thousands upon
thousands of messages to transfer.
Thanks in advance for any suggestions.
<P>I'm trying to use IMAP to transfer messages from Pegasus to Outlook. I </P> <P>am dragging the messages from Pegasus to fastmail.fm's server via IMAP, then </P> <P>dragging them from that IMAP folder into Outlook. </P> <P>The problem I'm having is that Pegasus is logging out and logging in </P> <P>for every single message, which is causing headaches for fastmail, who </P> <P>will suspend my account if I keep having 200+ logins per hour. Is there </P> <P>any way to get Pegasus to keep the connection open and just move all </P> <P>the messages with one login? (I did check the box under "performance" </P> <P>that says "Keep a utility connection open when this definition is </P> <P>active," but obviously that hasn't done the trick.)</P> <P>If it isn't possible to do this, then does anyone know of an IMAP </P> <P>provider that won't mind such frequent logins? I have thousands upon </P> <P>thousands of messages to transfer.</P> <P>Thanks in advance for any suggestions.</P>
I have just used the same procedure transferring 1500 emails from another client into Pegasus via Fastmail. Will doublecheck my IMAP settings to see if there is something there.
I did use 'select all' from the old client then COPY to the FastMail mailbox (InBox\Draft). This was repeated via Pegasus 'Select All' copy from FastMail (Inbox\Draft) to the local filestore. Once the copy was completed I Control-Delete the email on fastmail.
<p>I have just used the same procedure transferring 1500 emails from another client into Pegasus via Fastmail. Will doublecheck my IMAP settings to see if there is something there.</p><p> </p><p>I did use 'select all' from the old client then COPY to the FastMail mailbox (InBox\Draft). This was repeated via Pegasus 'Select All' copy from FastMail (Inbox\Draft) to the local filestore. Once the copy was completed I Control-Delete the email on fastmail. </p>
Interesting, thanks for the reply! I tried using the copy button on the toolbar and found it did what I desired, moved all the messages using one connection. So then I used the move button on the toolbar, and it also worked! It's only when I drag and drop onto the folder list that it opens and closes between each message. So the problem is solved and I thank you greatly for the info.
