DNSBL Help
Do a 'file compare' on your two mercury folders and play 'spot the difference' [:D]
<p>Do a 'file compare' on your two mercury folders and play 'spot the difference' [:D]</p><p> </p>
Hi..
I am currently stuck with Mercury32 not working with the dnsbl.
Mercury32, Bind and wrbldnsd all running on same machine with single IP with firewall off.
A) I have installed wrbldnsd to listen to port 54. ie 192.168.10.10/54.
 Update xbl, pbl and sbl were successful.
B) I have install Bind on the same machine with the named.conf as follows:
options {
 Directory "C:\windows\system32\dns\etc";
zone "dnsbl" {
        type forward;
        forward only;
        forwarders {
                192.168.10.10 port 54;
C) When I try dig I get.
dig A 2.0.0.127.sbl.dnsbl
;; ANSWER SECTION:
2.0.0.127.sbl.dnsbl.    300     IN      A       127.0.0.2
dig A 2.0.0.127.zen.dnsbl
;; ANSWER SECTION:
2.0.0.127.zen.dnsbl.    300     IN      A       127.0.0.2
2.0.0.127.zen.dnsbl.    300     IN      A       127.0.0.4
2.0.0.127.zen.dnsbl.    300     IN      A       127.0.0.10
I get 3 answers with zen.. dunno why.
D) Under MercuryS->SpamControl, I created a new blacklist entry "Spamhaus" with hostname "zen.dnsbl".
 Testing using nelson-sbl-test@crynwr.com email fails.
Tried looking the the MercuryS logfiles but not too helpful.
Any pointers on this... please?
Kenny
<DIV class=ForumPostContentText id=ctl00_ctl01_bcr_ctl00___PostRepeater_ctl01_PostViewWrapper> <P>Hi..</P> <P>I am currently stuck with Mercury32 not working with the dnsbl. Mercury32, Bind and wrbldnsd all running on same machine with single IP with firewall off.</P> <P>A) I have installed wrbldnsd to listen to port 54. ie 192.168.10.10/54.  Update xbl, pbl and sbl were successful.</P> <P>B) I have install Bind on the same machine with the named.conf as follows:</P> <P>options {  Directory "C:\windows\system32\dns\etc"; };</P> <P>zone "dnsbl" {         type forward;         forward only;         forwarders {                 192.168.10.10 port 54;         }; };</P> <P>C) When I try dig I get.</P> <P>dig A 2.0.0.127.sbl.dnsbl ;; ANSWER SECTION: 2.0.0.127.sbl.dnsbl.    300     IN      A       127.0.0.2</P> <P>dig A 2.0.0.127.zen.dnsbl ;; ANSWER SECTION: 2.0.0.127.zen.dnsbl.    300     IN      A       127.0.0.2 2.0.0.127.zen.dnsbl.    300     IN      A       127.0.0.4 2.0.0.127.zen.dnsbl.    300     IN      A       127.0.0.10</P> <P>I get 3 answers with zen.. dunno why.</P> <P>D) Under MercuryS->SpamControl, I created a new blacklist entry "Spamhaus" with hostname "zen.dnsbl".  Testing using <A href="mailto:nelson-sbl-test@crynwr.com"><FONT color=#02469b>nelson-sbl-test@crynwr.com</FONT></A> email fails.  </P> <P>Tried looking the the MercuryS logfiles but not too helpful. Any pointers on this... please? Kenny</P></DIV>
Can you get it working when querying Spamhaus direct?
Initially it worked. But I think they blocked my ip due to high traffic.
Now I am evaluating the 30 days trial data feed.
<P>Initially it worked. But I think they blocked my ip due to high traffic.</P> <P>Now I am evaluating the 30 days trial data feed.</P>
I have managed to get it working. This is what I did.
1) Install fresh mercury32 on a new dir.
2) Manually copy the usermail folders.
3) Config the spamhaus filter to query zen.dnsbl -> still not working.
4) Change local networking setting to add 127.0.0.1 dns enry. Restart mercury -> WORKING!
5) Try running the previous installation of mercury32 with same spamhaus filter settings -> not working - duh!
6) Change back to new mer32 installation. Working but mystery not totally solved.
<P>I have managed to get it working. This is what I did.</P> <P>1) Install fresh mercury32 on a new dir.</P> <P>2) Manually copy the usermail folders.</P> <P>3) Config the spamhaus filter to query zen.dnsbl -> still not working.</P> <P>4) Change local networking setting to add 127.0.0.1 dns enry. Restart mercury -> WORKING!</P> <P>5) Try running the previous installation of mercury32 with same spamhaus filter settings -> not working - duh!</P> <P>6) Change back to new mer32 installation. Working but mystery not totally solved.</P>
