Greetings!
Thank you for the suggestions. I followed them and tried a new search. The search processed, but no results window appeared at all. I tried again and same result. So I closed Pegasus and re-opened and tried again, still no search results window at all. I tried the Window Cascade menu option...no help. Finally, I opened up the Folders window and check the Recent Searches Folder and there were all my searches and yes the column sizes were as I had hoped. [:D] I tried another search and this time the search window appeared. Ummmm. I closed the Folder Window and tried another test search .... no search window show, but it does when the Folders Window is opened.
So thank you for your answer. I usually always have the Folders Window opened, but others may not. Don't know if this is by design or a bug. [*-)] I can live with it this way, but it seems that if you are able to perform a search the results should appear whether or not you have the Folders Window open.
Again, many thanks for your solution!!
Best Regards
<P>Greetings!</P>
<P>&nbsp;Thank you for the suggestions.&nbsp; I followed them and tried a new search.&nbsp; The search processed, but no results window appeared at all.&nbsp; I tried again and same result.&nbsp; So I closed Pegasus and re-opened and tried again, still no search results window at all.&nbsp; I tried the Window Cascade menu option...no help.&nbsp; Finally, I opened up the Folders window and check the Recent Searches Folder and there were all my searches and yes the column sizes were as I had hoped.&nbsp;[:D] I tried another search and this time the search window appeared.&nbsp; Ummmm.&nbsp; I closed the Folder Window and tried another test search .... no search window show, but it does when the Folders Window is opened.</P>
<P>&nbsp;So thank you for your answer.&nbsp; I usually always have the Folders Window opened, but others may not.&nbsp; Don't know if this is by design or a bug.&nbsp;[*-)] I can live with it this way, but it seems that if you are able to perform a search the results should appear whether or not you have the Folders Window open.</P>
<P>Again,&nbsp;many thanks for your&nbsp;solution!!</P>
<P>&nbsp;Best Regards&nbsp;</P>
<P mce_keep="true">&nbsp;</P>
