What about using the filtering rules to identify mails to correct users, identify correct attachments, and extract said attachments to a folder (maybe network folder on a machine with .pdf & .doc readers installed if you don't want to encumber your mail server with such).
Then have a resident process or scheduled task (on the network machine not the server) to run a batchfile that polls the folder for new files and prints them as desired.
Ah, good idea! That should work well. If the applications for printing the formats are installed on the same machine, even without using a scheduled task by using a ruleset like:
If header "T" contains "user@yourdomain" LogicalAnd ""
If attachment ExtnPart contains "pdf" Goto "pdf"
If attachment ExtnPart contains "doc" Goto "doc"
Label "pdf"
If attachment ExtnPart contains "pdf" SaveAttmt "c:\\mercury\\to_print\\temp.pdf"
Always Run "command-to-print-temp.pdf"
Always Exit ""
Label "doc"
If attachment ExtnPart contains "doc" SaveAttmt "c:\\mercury\\to_print\\temp.doc"
Always Run "command-to-print-temp.doc"
Always Exit ""
Best regards
Nico
[quote user="dilberts_left_nut"]<P>What about using the filtering rules to identify mails to correct users, identify correct attachments, and extract said attachments to a folder (maybe network folder on a machine with .pdf &amp; .doc readers installed if you don't want to encumber your mail server with such).</P>
Label "pdf"
Always Exit ""
Label "doc"
Always Exit ""
Best regards
Nico
