You may have trouble if the drive letter changes, lots of parameters in Mercury setup require a full path.
You can set the assigned drive letter in the 'Disk Management' snapin in MMC. This will need to be done on each 'new' machine.
You should set it to a "high" letter (X,Y,or Z) so there is more chance of the drive letter being available on any particular machine. (E, F & so on are commonly grabbed by extra HDD's or DVD drives, camera's etc).
Or maybe M: would be more appropriate [:D]
<p>You may have trouble if the drive letter changes, lots of parameters in Mercury setup <b>require</b> a full path.
</p><p>You can set the assigned drive letter in the 'Disk Management' snapin in MMC. This will need to be done on each 'new' machine.
</p><p>You should set it to a "high" letter (X,Y,or Z) so there is more chance of the drive letter being available on any particular machine. (E, F &amp; so on are commonly grabbed by extra HDD's or DVD drives, camera's etc).</p><p>Or maybe M: would be more appropriate [:D]&nbsp;</p>
