[quote user="domiz"]
Hi all!
I installed mercury pop3 client, imap and smtp. And all works fine in my local lan. But now i want to use it from the internet. I want to connect to my mailserver through my xxx.dyndns.org address. Now my question is, where must i enter my local network address and where my dnydns address? i tried some configurations but nothing did help. All needed ports are definitly open. if anyone could help me, please do so.
Domiz
You say the ports are open.  What happens when you try to telnet into ports 25, 110 and 143?  Can you see activity on the console?  If not then your dynamic NDS type address is not pointing to the system running Mercury/32.  FWIW, mercury automatically binds to all of the interfaces available and so if you can't get it from the outside then it looks like you are not connecting to the system.
        [quote user="domiz"]<p>Hi all!</p><p>I installed mercury pop3 client, imap and smtp. And all works fine in my local lan. But now i want to use it from the internet. I want to connect to my mailserver through my xxx.dyndns.org address. Now my question is, where must i enter my local network address and where my dnydns address? i tried some configurations but nothing did help. All needed ports are definitly open. if anyone could help me, please do so.</p><p>Domiz&nbsp;</p><p>[/quote]</p><p>&nbsp;</p><p>You say the ports are open.&nbsp; What happens when you try to telnet into ports 25, 110 and 143?&nbsp; Can you see activity on the console?&nbsp; If not then your dynamic NDS type address is not pointing to the system running Mercury/32.&nbsp; FWIW, mercury automatically binds to all of the interfaces available and so if you can't get it from the outside then it looks like you are not connecting to the system.</p><p>&nbsp;</p><p>&nbsp;</p>
