VOICEMAIL ATTACHMENT PROBLEM HELP HELP HELP
Could you forward one of those voicemail messages to me at support@tstephenson.com for analysis?  I would like a copy of the cnm file from the new mail directory zipped if possible.
<p>Could you forward one of those voicemail messages to me at support@tstephenson.com for analysis?  I would like a copy of the cnm file from the new mail directory zipped if possible.</p><p> </p><p> </p>
My wifes voivemail is now being routed to her email as well as on her phone messages, but pegasus can't handle the attachment,
 it must be an odd or messed up wav file. The problem is that once read and deleted from the server, it is also deleted from her voicemail.
There is a way to create filtering in Outlook Express to not read this email and leave it on the server, but I can't find a way to handle this in Pegasus.
She is comfortable with pegasus, so I don't want to swsitch from Pegasus, the learning curve would be a problem.
Is there a filtering rule, add on or other solution I'm not aware of?
Selective mail download is not a solution, since it's manual, she gets a ton of email from this server that includes the bogus voicemail message.
Thanks for any help you can give me..
Looking forwarded to 5.0
<P>My wifes voivemail is now being routed to her email as well as on her phone messages, but pegasus can't handle the attachment,</P> <P> it must be an odd or messed up wav file. The problem is that once read and deleted from the server, it is also deleted from her voicemail.</P> <P>There is a way to create filtering in Outlook Express to not read this email and leave it on the server, but I can't find a way to handle this in Pegasus.</P> <P>She is comfortable with pegasus, so I don't want to swsitch from Pegasus, the learning curve would be a problem.</P> <P>Is there a filtering rule, add on or other solution I'm not aware of?</P> <P>Selective mail download is not a solution, since it's manual, she gets a ton of email from this server that includes the bogus voicemail message.</P> <P>Thanks for any help you can give me..</P> <P>Looking forwarded to 5.0</P>
1. Tools/Mail filtering/Create POP3 ruleset which leaves those messages on server
2. Tools/Internet options/POP3/Edit your definition, and attach the ruleset to Download controls.
<P>1. Tools/Mail filtering/Create POP3 ruleset which leaves those messages on server</P> <P>2. Tools/Internet options/POP3/Edit your definition, and attach the ruleset to Download controls.</P> <P mce_keep="true"> </P>
Thanks for your help, I got it working. This was a lot easier than retraing the wife...
