BIG HUGS FOR YOU! Funny how if you never use something you forget that it is even there. Thanks. I suppose I should go back and "fix" the pconfig file ...
Um ....not getting it to work ... does Pegasus Mail need to be on the root of the removable drive? Here is the current location of mine:
F:\_stored\PMail\Programs\winpm-32.exe
Tried it both leaving the config file ..\mail\~8 and editing back to the original c:\pmail\mail\~8
I'll look to see if I need to use some other command line options as well.
<p>BIG HUGS FOR YOU!&nbsp; Funny how if you never use something you forget that it is even there.&nbsp; Thanks. I suppose I should go back and "fix" the pconfig file ...</p><p>&nbsp;Um ....not getting it to work ... does Pegasus Mail need to be on the root of the removable drive?&nbsp; Here is the current location of mine:</p><p>F:\_stored\PMail\Programs\winpm-32.exe</p><p>&nbsp;Tried it both leaving the config file ..\mail\~8 and editing back to the original c:\pmail\mail\~8</p><p>I'll look to see if I need to use some other command line options as well.
&nbsp;</p>
