CURSOR PROBLEMS
I use WinXP and Pegasus 4.41 without the cursor/focus problem you experience.
This may be a long shot. In Tools |  Options... | User interface | Reporting/logging  there is a checkbox controlling a "Telltale" notification about new email. Perhaps the telltale window steals focus from the active window? Unless there is a problem with the POP3 connection (in which case you
get an error dialog) the new mail notification would be a prime suspect. This is just my best guess, though, because I don't use the telltale window myself.
There's another ongoing thread about the font problem in Vista; I think maybe you already posted there.
Erik
<p>I use WinXP and Pegasus 4.41 without the cursor/focus problem you experience.</p><p>This may be a long shot. In <i>Tools |  Options... | User interface | Reporting/logging  </i>there is a checkbox controlling a "Telltale" notification about new email. Perhaps the telltale window steals focus from the active window? Unless there is a problem with the POP3 connection (in which case you get an error dialog) the new mail notification would be a prime suspect. This is just my best guess, though, because I don't use the telltale window myself. </p><p>There's another ongoing thread about the font problem in Vista; I think maybe you already posted there. </p><p>Erik</p>
 Here is my first Post!
 I have two issues. I am using Windows Xp on one computer, and Vista Premium on the other, and I am using the latest Pegasus Version.
 1. On the Windows XP computer, I have this problem. I have noticed this problem also occurs in other programs, but is directly related to Pegasus. About 50% of the time, when I start typing a reply in Pegasus (and sometimes Word) when Pegasus checks the mail servor for mail, or does does any activity, I loose my cursor. I have to use the mouse and click where I left off, typing can then resume, until Pegasus attempts to connect to my servor again, and the cursor is lost again. Very frustrating.
 2. On my Vista Computer, I can not change the font size in the sender, subject, cc dialog box when sending mail. The font size is extremely small. I was able to increase font size and style in all other areas of Pegasus, just not in the sender, subject, or cc dialog boxes? What controls this font style and size?
Thanks.
Please copy your email to 2000@vineyard.net
<P> Here is my first Post!</P> <P> I have two issues. I am using Windows Xp on one computer, and Vista Premium on the other, and I am using the latest Pegasus Version.</P> <P> 1. On the Windows XP computer, I have this problem. I have noticed this problem also occurs in other programs, but is directly related to Pegasus. About 50% of the time, when I start typing a reply in Pegasus (and sometimes Word) when Pegasus checks the mail servor for mail, or does does any activity, I loose my cursor. I have to use the mouse and click where I left off, typing can then resume, until Pegasus attempts to connect to my servor again, and the cursor is lost again. Very frustrating.</P> <P> 2. On my Vista Computer, I can not change the font size in the sender, subject, cc dialog box when sending mail. The font size is extremely small. I was able to increase font size and style in all other areas of Pegasus, just not in the sender, subject, or cc dialog boxes? What controls this font style and size?</P> <P>Thanks.</P> <P>Please copy your email to <A href="mailto:2000@vineyard.net">2000@vineyard.net</A></P> <P mce_keep="true"> </P> <P mce_keep="true"> </P>
Sorry - I don't use Vista so have no idea how to do this.
Windows Xp and latest 4.41
 I already reported loosing my cursor almost every time Pegasus was checking the mail POP for new mail.
I just went into  Network Options, and increased time from default 12 seconds to 45 seconds, for checking POP for mail. Now, I can type for 45 seconds, without loosing my cxirsor?
 What is going on?
Also, on my Vista computer, why is the "to, subject,  etc"  in extremely small fonts, that I can't see? No way to change this setting???
4.41 is not a good update for me.
paul adler
2000@vineyard.net
<p>Windows Xp and latest 4.41 </p><p> I already reported loosing my cursor almost every time Pegasus was checking the mail POP for new mail.</p><p>I just went into  Network Options, and increased time from default 12 seconds to 45 seconds, for checking POP for mail. Now, I can type for 45 seconds, without loosing my cxirsor?</p><p> What is going on?</p><p> </p><p>Also, on my Vista computer, why is the "to, subject,  etc"  in extremely small fonts, that I can't see? No way to change this setting???</p><p>  4.41 is not a good update for me. </p><p> </p><p>paul adler</p><p>2000@vineyard.net </p><p> </p>
