Hi guys,
I have a problem. I'm using Pegasus 4.4 and I have a set of old PINE messages I'd like to import into Pegasus. I've used the trick of exporting the PINE messages to a file, copying the file over to my laptop, renaming that file with a .mbx extension, and then using the Add Folder to List option as directed on the website. For the most part it works beautifully---except that for certain messages (it looks like they are the longer ones) the message gets split in half, with one of the messages picking up the relevant attributions and the others being orphaned with no subject line, sender, etc. This is not terribly convenient (sometimes it's just a few messages, but for one folder it was about 100 of them).
Does anyone know how to prevent or fix this?
Amanda
<p>Hi guys,</p><p>&nbsp;</p><p>&nbsp;&nbsp; I have a problem.&nbsp; I'm using Pegasus 4.4 and I have a set of old PINE messages I'd like to import into Pegasus.&nbsp; I've used the trick of exporting the PINE messages to a file, copying the file over to my laptop, renaming that file with a .mbx extension, and then using the Add Folder to List option as directed on the website.&nbsp; For the most part it works beautifully---except that for certain messages (it looks like they are the longer ones) the message gets split in half, with one of the messages picking up the relevant attributions and the others being orphaned with no subject line, sender, etc.&nbsp; This is not terribly convenient (sometimes it's just a few messages, but for one folder it was about 100 of them).</p><p>&nbsp;&nbsp; Does anyone know how to prevent or fix this?</p><p>&nbsp;</p><p>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Thanks,</p><p>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Amanda
&nbsp; </p><p>&nbsp;&nbsp;</p><p>&nbsp;
&nbsp; </p>
