All I get is "message not successfully sent."If you turn on session logging in Configuration | MercuryS then each TCP/IP transaction will be logged in a TCP[4 hex digits].MS Point the session logging to drive:\mercury\logs\mercuryS and then make sure the directory exists.Is there a way of finding out why? Without this, it becomes rather impossible to debugg & fix.
Am I supposed to do some set-up work first?
1. Verify that mercury/32 is properly setup to receive the mail via MercuryS.
2. Read up a bit on SMTP transfers to ensure you can tell a good TCP/IP session from a bad one.
3. Read the Mercury manual to figure out how it's supposed to be configured.
<blockquote>All I get is "message not successfully sent."
Is there a way of finding out why? Without this, it becomes rather impossible to debugg &amp; fix.
</blockquote>If you turn on session logging in Configuration | MercuryS then each TCP/IP transaction will be logged in a TCP[4 hex digits].MS&nbsp; Point the session logging to drive:\mercury\logs\mercuryS and then make sure the directory exists. <blockquote>Am I supposed to do some set-up work first?
</blockquote><p>1.&nbsp;&nbsp;&nbsp; Verify that mercury/32 is properly setup to receive the mail via MercuryS.&nbsp;</p><p>2.&nbsp;&nbsp;&nbsp; Read up a bit on SMTP transfers to ensure you can tell a good TCP/IP session from a bad one. &nbsp;</p><p>3.&nbsp;&nbsp;&nbsp; Read the Mercury manual to figure out how it's supposed to be configured.&nbsp;</p>
