Greetings,
After all these years using Pegasus, I have found a recent need to establish several identities to address different addy requirements in running websites.
My understanding in reading the help files is that parameters unique to that entity will be saved and I will be able to skip or toggle between these Identities when answering emails.
It appears to be a simple process, but my settings do not "stick" permanently. eg  My return address in the General Tab (My internet address is) often reverts back to the default setting. Under the Tools-> Options-> Advanced Settings the selection box for "Allow multiple file selection..." also loses its setting.
I change, apply, save but then after several toggles between Identities, I have to reset again.
Welcome your input and solution. Thanks.
        <p>Greetings,</p><p>After all these years using Pegasus, I have found a recent need to establish several identities to address different addy requirements in running websites.</p><p>My understanding in reading the help files is that parameters unique to that entity will be saved and I will be able to skip or toggle between these Identities when answering emails. </p><p>It appears to be a simple process, but my settings do not "stick" permanently. eg&nbsp; My return address in the General Tab (My internet address is) often reverts back to the default setting. Under the Tools-&gt; Options-&gt; Advanced Settings the selection box for "Allow multiple file selection..." also loses its setting.</p><p>I change, apply, save but then after several toggles between Identities, I have to reset again.</p><p>Welcome your input and solution. Thanks.
</p><p>&nbsp;
</p><p>&nbsp;</p>
